    Help a IGH Noob pick drivetrain?
    Thanks for any help in advance.
    I'm 6'5 250lb and I recently got a 23" Raleigh Passage 4.0 frame for super cheap.
    I was thinking I'd like to build it up as a commuter that may see a few hills as well as a little bit of dirt/gravel. I am really attracted to the Alfine 8sp hub. My questions are:
    <STRIKE>Will I need a tensioner, can you recommend one?</STRIKE>
    What manufacturers should I be looking at in terms of the BB and crank set?
    I was thinking a "1x8" maybe a 32t or 34t in the front?
    What other parts am I forgetting?
    Please don't laugh at my ignorance, lol thanks for any help!
    Most specs here: BIKE INFO
    BB 68mm/122mm
    Verticle drop outs
    I Require a 180 mm crank arm
    will rant for food
    Best vertical dropout tensioner I've used is a Yess ETR-V.
    I'd go with a NuVinci N360 if I had to do it over again. Riding on an Alfine 8 right now.
    Thanks, I was originally thinking about going with a Surly Sigleator but the reviews on the Yess seem very positive.
    Id really love some recommendations on a strong 180mm crank set and BB. I haven't had much luck pointing myself in the right direction as far as knowing what to use with a IGH.
    will rant for food
    Yes, I had mixed results with the Singleator. In some cases it worked really well. The Yess ETR-V has *always* worked for me.
    If you want a *strong* 180mm crankset... well, it's not insanely expensive, but is a bit pricey once you're all done, check out Profile Racing.
    Profile Racing E-Store
    Notice the crank length options?
    Read the product details carefully, you still need a bottom bracket and spider. I'd go with these:
    So the deal with Profiles is that you can set the chainline and drive line "however" you want within reason. Look closely at how the cranks interface with the spindle - they are a close-tolerance telescoping spline-driven sort of thing. You can slides the cranks along the spindle's length to set your own Q factor and chain line, using spacers.
    Basically: a bit heavy, a bit expensive, but *really* adjustable, lots of length options, and really strong.
