Results 1 to 15 of 15
    Reputation: OFFcourse's Avatar
    Gear Ratio's for Fatbikes
    Trying to work out ratio's for a Fatbike build with a IGH.
    If I did the inputs right....
    First is what I'm running ATM, I spin out occasionally but it's only on downhill's where I'm not very concerned with pedalling I could do with something a little lower for some of the climbs in this area.
    For a fatbike I imagine I could lose a little on the high end no problem but would want to add a bit to the low end? So maybe the 8speed Alfine would be fine? (it's damm cheap)
    Attached Thumbnails Attached Thumbnails Gear Ratio's for Fatbikes-current.png
    Reputation: Corporal Punishment's Avatar
    I have my alfine 8 (HT/XC) running 32/22. I like the low gearing for short steep climbs. I never spin out on the trail - only when I leave from my buddy's place where there is a bit of flat road riding to get to the trail. Then again, I'm not exactly a hammerhead.
    The cogs are cheap ($10 or less), so don't worry about the ratio until you try them out. You'll probably want to start with a 20T or higher. I think you can get them as large as 23T. You'll know after 1 ride if you want to change the size.
    Reputation: vikb's Avatar
    I'm running 32T x 21T on my Alfine 8 - going on 3yrs+ with no issues. On the CDN GDR with 4 panniers and a week's worth of camping gear my buddy and I would walk our Pugsleys up the steepest hills once or twice per day. Usually one person stayed on the bike and the walker wasn't going much slower.
    On the downhills I never felt like I needed a higher gear.
    It's been flawless for us even though it's been abused a ton.
    Safe riding,
    Vik
    www.vikapproved.com
    Sounds like all the convincing I need when comparing the pricing difference between the rohloff and alfine11speed
    Just to be sure I'm reading/using the calculator correctly would a kind person check the outputs on a 32t 32-11c on a 26" vs a 32t 22 on a fatbike?
    The 2.0 (Custom Cass) I see compared to the 1.7 (Both Alfines) is going to be lower, right?
    BTW are there grip shifters available for the alfine8 ?
    Quote Originally Posted by OFFcourse View Post
    To be fair to the Rohloff it has a service life and record of performance that the Alfine 11 does not.
    There are Grip shifters for the Nexus 8/Alfine 8 - same shifter for both hubs.
    Safe riding,
    Vik
    www.vikapproved.com
    Great grip shifters and yes I'm sure the Rohloff is the nuts but it's way out of my budget.
    Rohloff's are expensive for sure which makes an Alfine 8 or 11 a worthy option.That was the reason I got an Alfine 8 on my Pugs.
    Alfine 11 snuff pics
    Looking at the thread above and other Alfine 11 posts online it seems like some 11's are not working out too well. I have an Alfine 11 which I will try out, but if you want higher reliability the 8's have a better track record and I haven't felt the need for more gears.
    Safe riding,
    Vik
    www.vikapproved.com
    I pored over most of the alfine threads over the weekend and read as much, can you recommend any good wheel builders? (Inter Shipping)
    I was thinking Rolling Darryls with the Alpine not sure what hub to put on the front but nothing to expensive, what about holes 32 or 36 what did you go with?
    A Surly Maverick
    Reputation: Dr Feelygood !'s Avatar
    Does anyone have any thoughts about using a Nuvinci instead of an Alfine ?
    I'm a bit intrigued by them as they appear bombproof and I like the idea of a continuously variable gear spread without big 'steps' in the range.
    I do like my Alfine 8.......... but for beach riding, I cannot help but think about the Nuvinci.
    Life IS a Beach and then you Corrode
    It's quite a big gain in weight 1590g for the alfine to 2500g for the Nuvinci 360
    Quote Originally Posted by Dr Feelygood ! View Post
    I've tried a couple Nuvinci IGHs on demo bikes and never been thrilled. I was offered one at cost to review and I declined.
    Safe riding,
    Vik
    www.vikapproved.com
    I use a 32H IGH on my Big Dummy cargo bike and routinely carry myself and 100-200lbs on it. I've never had an issue with that wheel.
    I also use a 32H Alfine on my Pugs. A 32H symmetric wheel is very strong [if properly built].
    Safe riding,
    Vik
    www.vikapproved.com
    Reputation: mikeyonthemadone's Avatar
    Quote Originally Posted by vikb View Post
    Any particular reason(s)? Just curious.
    Mikey
    Quote Originally Posted by mikeyonthemadone View Post
    Mikey
    They are heavy, not great gear range and I didn't enjoy how they shifted when I demo'd them twice
    I've had good experience with Rohloffs and Alfine/Nexus IGH.
    Even with the hub at cost a Nuinvci wheel is hundreds of $$$ once you buy a rim and get it all built up.
    Safe riding,
    Vik
    www.vikapproved.com
    All good points...thanks for the info.
    Mikey
  1. Bikepacking Gear for Fatbikes
    By FarNorth in forum Bikepacking and Bike Expedition
    Last Post: 03-05-2011, 01:04 AM
  2. Leverage Ratio's / Charts - Permalink ?
    By The_Lecht_Rocks in forum Nicolai
    Last Post: 02-19-2011, 05:35 AM
  3. Fatbikes
    By husaberg in forum California - Socal
    Last Post: 04-16-2008, 08:21 PM
  4. 6ish" travel frames with low leverage ratio's
    By mravery in forum Downhill - Freeride
    Last Post: 02-15-2008, 02:27 PM
  5. 2x post..susp. guru's: are lower leverage ratio's
    By brook_63@yahoo.com in forum Shocks and Suspension
    Last Post: 03-01-2007, 09:09 AM
