Results 1 to 8 of 8
    Dual Drive shifting issues
    I just built up a bike for my son using an Sram Dual Drive rear hub and 3 x 9 shifter.
    The Shimano rear derailleur I installed does not shift well at all.
    It skips gears.
    Do I need to use an Sram Dual Drive rear derailleur?
    PCC
    PCC is offline
    Yes, I believe that you need a SRAM rear derailleur for that bike.
    a SRAM shifter will not play well with a shimano derailleur. Their pull rations are different (1:1 vs 2:1) so the indexing doesn't fly. I'm not sure if the dualdrive derailleur has any specific uniqueness in this regard relative to other SRAM derailleurs.
    Rohloff
    Reputation: bsdc's Avatar
    Oh, the horror!!! It's like looking at a picture of a gutted child. Look at those external gears ... exposed to the elements ... bleeding oil ... slowly dying on the trail.
    Sir, if you have any love for your son, you'll get him an internal gear hub.
    Quote Originally Posted by bsdc
    Um... he did. It's right there. It just takes a cassette too. Dual drive. Cassette and internal 3spd.
    Rohloff
    Quote Originally Posted by Schmucker
    What? There's an inny and an outy? I'm confused. A hermaphodite drivetrain?
    Reputation: swift's Avatar
    I think the SRAM Dual Drive is a relabelled X-5. Any SRAM derailer should work for you with that setup.
    Drinking the Slick_Juice
    Reputation: nuck_chorris's Avatar
    is that a mongoose?
    "If women don't find handsome , they should at least find you handy."-Red Green
