    Jun 2012
    Does Rohloff have to use special cranks?
    Do you have to use special cranks with a Rohloff or could I just use the inner ring on my double cranks?
    Music & Bikes
    Reputation: fokof's Avatar
    It's a 54mm chainline , so basicaly your big ring should do it.
    "There is a big difference between kneeling down and bending over" -FZ
    Dec 2012
    Yeah, chainline is whats important. So its dependent on chain-ring position and bottom bracket length.
    I use a Thorn crank-set and utilise the middle ring position and a 113mm bottom bracket.
    This position will not work with all crank-sets and some bikes will need a longer/shorter bottom bracket.
    The specification sheet for most brands of crankset will tell you what bottom bracket length for a set chainline.
    From that info you should be able to tell how best to proceed (whether to get a longer/shorter BB or chainring spacers)
    Feb 2005
    Usually the outer ring on a MTB triple crankset is very close to the correct 54mm chainline - or it was back when the standard chainline (measured at the middle ring) was 47.5mm instead of the 50mm current now.
    FWIW, I ended up using a square taper double road crankset with a longer BB (110 instead of 103mm), a 3mm spacer behind the RH cup and with the 2mm Rohloff chainring spacers between the spider and ring. This gives a 54mm chainline with the absolute minimum Q possible on the frame I have, and used a set of cranks that weren't doing anything else.
    Although you may be able to get the correct chainline (or close enough) using a more modern crankset, square taper cranks allow much easier customisation of chainline, and of the Q factor(s) on both LHS & RHS.
  1. Replies: 2
    Last Post: 05-06-2013, 12:38 PM
  2. Truvative XX cranks and Shimano XT cranks- Chainguide?
    By hiawatha-de in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-24-2012, 09:31 AM
  3. Ring/bash guard for Hollowtech II cranks with Rohloff hub?
    By sbruton7 in forum General Discussion
    Last Post: 09-23-2012, 03:36 PM
  4. Shimano M737 cranks vs M950 cranks!
    By cyberbackpacker in forum Singlespeed
    Last Post: 12-15-2011, 12:23 PM
  5. SS Cranks that work with Rohloff chainline?
    By mbeardsl in forum Internal Gear Hubs
    Last Post: 03-09-2011, 05:44 PM
