Results 1 to 5 of 5
    May 2014
    Which to choose?
    Need some help making a decision here...
    I have a mountain bike and I have been interested in these internal gear hubs but I really don't understand the gearing mumbo jumbo. From reading the forum for the last 45min I think I want either the N360 or the Alfine SGS501 8 speed, but I do not know because I don't understand the gearing information too well.
    I like my 21 speeds fine, it give me a good low low and I could use maybe a bit higher high for road driving but it is ok as is. I got a 7 gear rear hub and I drive trails with rocky muddy stretches water crossings loose gravel and dirt. Not a lot of hills but I do hit the occasional climb.
    Which one is going to last? How will the gears compare to what I am running? (I don't know my specific tooth counts and what not but I am pretty sure it is a department store bike with standard out of box gearing and kit) Any options I am over looking?
    Thanks for the help.
    _CJ
    _CJ is offline
    membership renounced
    May 2014
    From what I've been able to gather, the only IGH that'll have a similar gear spread to a standard MTB with tripple rings up front is a Rohloff...at about $1500.00. The Alfine8 and other similar units will only have a gear spread similar to running one ring in front and 8 speeds in back.
    May 2014
    What about keeping the front 3 speed sprocket in conjunction with the rear IGH? Or will the IGH not handle the 3 speed front sprocket?
    _CJ
    _CJ is offline
    May 2014
    Quote Originally Posted by Tylenol View Post
    Most IGH manufacturers seem to recommend a primary drive ratio in the 1.7:1 range, and much of the gearing in a triple would exceed the torque rating of those recommended ratios.
    Beyond that....a triple front would require a rear derailleur which would negate much of the IGH's advantage.
    Stubby-legged
    I bought the A8 and the A11. If I were to do it again, I'd buy the A11. Good spread of ratios and it has been durable.
  1. Need Help on what MTB to choose?!!?!?!?
    By AZULUZA in forum 29er Bikes
    Last Post: 07-19-2012, 11:15 PM
  2. help me choose my first mtb
    By jblunt791 in forum Beginner's Corner
    Last Post: 04-17-2012, 07:32 PM
  3. Help me choose.
    By swinada in forum Beginner's Corner
    Last Post: 02-23-2012, 11:24 PM
  4. help me choose
    By jesdaco7 in forum Bike and Frame discussion
    Last Post: 10-11-2011, 06:36 PM
  5. if you could choose
    By vqdriver in forum Shocks and Suspension
    Last Post: 08-29-2011, 10:04 AM
