    nimble biker
    Reputation: Picard's Avatar
    Apr 2005
    New question here. can the King headset bearings replace?
    or
    should the headset be replace completely?
    Unhinged Aussie on a 29er
    Reputation: hunter006's Avatar
    IIRC you're supposed to return the headset to the factory for them to do it. It's not like a regular headset, where you can just service it yourself. Talk to your LBS about your options.
    Reputation: vikb's Avatar
    From the Chris King website:
    HEADSET SERVICE:
    In general, headset service should be done at least every two years. In dry climates, service intervals may be longer. In wet climates, service may be necessary as often as every 6 months.
    You may service your Chris King headset while in the frame using a light solvent based lubricant (e.g., Bullshot aerosol or WD-40,) to flush the bearings. If you have access to the correct tools for the proper removal and reinstallation of Chris King bearing cups, we have found it easier and more effective to remove the cups and use a solvent tank.
    Remove snap ring and seal:
    Take a pointed instrument, such as a penknife, insert it at the split in the snap ring, and lift the pointed end out. Once the pointed end is free, the remainder of the ring can be removed easily. Lift out the inner seal. At this point the bearing will be exposed.
    Clean and re-grease the bearings and replace the seal and snap ring:
    With a small brush (e.g., a tooth brush) clean the bearing while rinsing with solvent. If the bearing has been neglected and is frozen, let it soak for a few minutes. Then, rotate the inner race back and forth to work it free. Rinse in solvent and blow dry with an air hose to remove any excess solvent. Test the bearing for smoothness. If the bearing was frozen for too long it may have become damaged or may be too rough and need replacing. However, if the bearing has lost only some of its silky smoothness, it may not be evident at the handlebar once re-greased and reassembled. If bearing replacement is necessary return cup(s) to us to have a new bearing(s) installed.
    Re-grease the bearings using Bullshot or any other waterproof grease. Carefully wipe off the inner seal and reinstall. Finally, insert the pointed end of the snap ring into the snap ring groove, working it around the bearing until the other end seats and a small gap is noticed. Inspect the rest of the parts for any wear. At this time, you are ready to reassemble the headset and adjust.
    Safe riding,
    Vik
    www.vikapproved.com
    Aaah, I was confusing bearing replacement and servicing the headset. Clearly not the same thing. Thanks Vik!
  1. Should I replace my RF X-type bearings before I even install the BB?
    By head in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-13-2013, 06:29 PM
  2. Gambler - Replace bearings
    By Karve in forum Scott Sports
    Last Post: 04-09-2012, 03:32 PM
  3. WTB Speed TCS Replace Bearings / Replacement
    By AXOP in forum Wheels and Tires
    Last Post: 11-24-2011, 09:29 AM
  4. When to replace/service hub bearings?
    By thrasher_s in forum Wheels and Tires
    Last Post: 11-10-2011, 11:36 PM
  5. Replace Bearings or Links on '08 Mojo SL?
    By plantdude in forum Ibis
    Last Post: 02-07-2011, 10:59 PM
