    Budget IGH for gravel grinding?
    Can someone recommend an IGH for gravel grinding to be used on a 130mm spaced track-end frame? I have looked at some of the 3 speed options on the market, but all seem to have issues with sealing..and I don't want to tear apart the hub every 2 months. Also don't have the coin for the blingy high-end hubs.
    Is there a reasonable compromise?
    You can find a Handspun Wheel with an Alfine 8 spd and VeloCity Dyad Rim for around $300.
    I ran one for 3+ years on a Karate Monkey with a 26x23 setup. You'd want some higher gears for a gravel grinder, though.
    Plenty of mixed reviews for the Alfine's. I attribute all my success to shifting style. Not only do I NOT shift under load, I don't even spin the cranks while shifting.
    The Sturmey-Archer 3-speed hub has some really nice labyrinth seals that have worked successfully for high-mileage cyclists for the last 110 years. Pack the labyrinths with StaLube Marine Grease.
    Is the S3X with a freewheel a viable option?
  1. New Gravel Grinding Bike
    By How27spd in forum Endurance XC Racing
    Last Post: 04-30-2016, 06:07 PM
  2. Single speed gravel grinding causing knee pain
    By Garrett_ in forum Singlespeed
    Last Post: 08-12-2013, 05:47 AM
  3. Grinding gravel in Weld county
    By HOser in forum Colorado - Front Range
    Last Post: 02-08-2012, 01:03 PM
  4. Budget Gravel Grinder Bike
    By tcmers in forum Endurance XC Racing
    Last Post: 03-30-2011, 01:52 PM
  5. For anyone in Melb interested in Gravel Grinding.
    By chumbox in forum Australia, New Zealand
    Last Post: 01-18-2011, 07:57 PM
