Results 1 to 7 of 7
    Barend shifter and nexus hub?
    Can a shimano nexus hub be used with a barend shifter? If not what options do you have with drop bars?
    Rich
    Some people have bored out the shifter clamp on Alfine shifters for use on drop bars. Other than that; supposedly J-Tek is finalizing an adapter for STI/bar-end.
    Reputation: vikb's Avatar
    I've heard of this, but I was reluctant to recommend it without having tried it myself. The resistance to shifting between 4&5 that they refer to simply represents the ring-gear shift within the hub, and is not a result of the shifter setup. All-in-all, it looks to be pretty sweet...
    Feb 2006
    Reputation: vsnofjohana's Avatar
    I did this last year with a shimano 8 speed and a Nexus 8and it works great. All you have to do is mount a inline travel agent (achieve the right cable pull), on the chain stay. I also ended up not using the cable guide on the nexus 8 to achieve a strait cable line from the travel agent to the hub.
    bike the planet!
    Dec 2008
    I fabbed up a holder out of some scrap steel I had in my garage. If you weld, this could be a solution...
    I don't have any pics of the adapter before it was installed but I can MS Paint something if you'd like.
