Results 1 to 13 of 13
    will rant for food
    Alternate Alfine 8 shifter from Zerode bikes
    Been running one of these for about two weeks:
    http://www.zerodeusa.com/product/zer...-sram-shifter/
    Basically it's less bulky, a bit - subjectively - more ergonomical, snappier feeling. I was able to better squeeze in a dropper post remote in the same area than before.
    If you've used a SRAM double-thumb shifter, it works like that... because that's mostly what it is.
    Kinda expensive though =/
    dru
    dru is offline
    Yes, expensive but very nice looking! I wish I had splurged on one when I busted the stock one off on my thigh last fall crashing in the mud!
    Drew
    occasional cyclist
    Reputation: Andy R's Avatar
    Nov 2008
    I use one and can confirm that while it is much nicer looking than the stock shifter and has a nicer shift feel it is also less leg friendly. It would have done even more damage to your leg - I speak from experience........
    will rant for food
    Something else to update here: I wouldn't recommend using the little rubber seal boot near the hub actuator that happens to come shipped with this unit (btw you have to run a new cable and housing, it is only designed to reach halfway as with a Zerode bike)
    It may have contributed to blowing up my hub: I blew up an Alfine 8!
    Most Delicious
    Reputation: dr.welby's Avatar
    Have you looked inside to see the mod?
    will rant for food
    Quote Originally Posted by dr.welby View Post
    No sir. Good idea...
    Nov 2008
    What's inside is the replacement eight speed index plate, which you can buy as a separate item from here among other places.
    So, if you manage to find a s/h X9 shifter, you can end up spending a lot less than Zerode charge for a complete converted unit.
    Low stock levels, so if you want one get it ordered now....
    It's easy to see why it's not so leg friendly though.
    dru
    dru is offline
    Ouch! Yes, that more robust metal may not fail like mine. My shifter snapped right off at the clamp. Did yours break, or just mangle you?
    occasional cyclist
    Quote Originally Posted by Andy R View Post
    Two questions.
    1. What is a "s/h X9 shifter"?
    2. Is this a 9-speed shifter as shown here.
    Nov 2008
    Quote Originally Posted by anga View Post
    Two questions.
    Sorry, I just meant a second hand/used SRAM x9 shifter ( the right hand one, obviously).
    Like the one shown.
    Although looking again, that looks like a later version of the X9 - This is the one I have. Still available for $56 +$10 postage (I'm assuming you're in the US, which I'm not, of course).
    Nov 2008
    Quote Originally Posted by dru View Post
    The shifter just shrugged off the impact, unlike my shin, which bled profusely and hurt like hell. Just one of those stupid crashes, not seeing a fallen tree branch covered in long grass and so riding into it at about a 45 degree angle.....
    any idea if a 9 speed XO shifter will work?
    Nov 2008
    Don't they have half the cable pull per shift compared to the X9?
    *edit - Ok, still 1:1 pull ratio but presumably the X0 won't accept the Zerode index plate, which is what makes the X9 usable with the 8 speed Alfine.
    If you were to develop a completely new index plate then yes, I suppose the X0 shifter could be made to work with the Alfine but, unless you've got time on your hands, why not just use the Zerode plate and the X9?
  1. Bar End Shifter for 8sp Alfine
    By klunker2 in forum Internal Gear Hubs
    Last Post: 11-26-2012, 12:16 PM
  2. Zerode Bikes
    By Juklano in forum Downhill - Freeride
    Last Post: 11-11-2012, 02:26 AM
  3. alfine 11 speed shifter
    By pintwister in forum Internal Gear Hubs
    Last Post: 05-13-2012, 06:07 PM
  4. Is Alfine 8 compatible w/ a bar-con shifter?
    By BIGfatED in forum Internal Gear Hubs
    Last Post: 03-20-2011, 08:04 PM
  5. alfine 11 shifter . . .lemon ??
    By T mon T in forum Internal Gear Hubs
    Last Post: 03-18-2011, 10:16 AM
