Results 1 to 8 of 8
    Reputation: OFFcourse's Avatar
    Alfine8 Install!
    Hmmm it doesn't look right?
    The entry point for the shifter cable/housing in the cassette joint looks like it will interfere with the cog/chain/chainline. Am I missing something?
    Attached Thumbnails Attached Thumbnails Alfine8 Install!-img_20121107_011230.jpg
    Dec 2008
    Quote Originally Posted by OFFcourse View Post
    Yes, Non-Turn Washer Application Chart
    And if You want seatstay cable routing, look at this thread:
    Anyone try seatstay cable routing with Alfine?
    Ok I thought I had maybe installed the cog the wrong way around
    Nov 2012
    mine looks the same on my pugsley. Actually works out well like that. not a problem. I thought I did it wrong too. Mine is straight up vertical just as you are holding it.
    Reputation: vikb's Avatar
    Alfine 8 on a Pugsley...
    Surly Pugsley - a set on Flickr
    Safe riding,
    Vik
    www.thelazyrando.com
    Nov 2012
    I'm so glad yours is sticking up like that because I thought I did something wrong but I couldn't figure out another way and besides it doesn't bind. Sweet!
    I can't show the pic until I have 10 posts... img811.imageshack.us/img811/887/20121115125103.jpg
    I have vertical dropouts, but I got it like that the other day with some combo of non-turns. Ideas on bending it? Def need to bend it out a bit.
    Reputation: Andy R's Avatar
    Nov 2008
    Take the whole cassette joint assembly off, then remove the plastic components.
    That way you can clamp it it a vice and get a nice bend exactly where you want it without risking any damage to the plastic parts.
Hot Deals
Contests
Latest Mountain Bike Articles
