Results 1 to 6 of 6
    MPU
    MPU is offline
    Alfine8; which non-turn washers for horiz. dropouts?
    Hello,
    I have a cruiser-style frame under construction (see Framebuilding). I'm going to use Alfine8 rear wheel on it. I'd like to route the gear cable via top tube and seat stay. What colour non-turn washers are correct for this use? The frame has horizontal dropouts.
    Thanks,
    Marko
    Reputation: Wombat's Avatar
    I think that's difficult to achieve. I first ran my Alfine with horizontal dropouts on an SE Stout and had to run the cable along the chainstay. From memory none of the available non-turn washers would allow me to run the cable along the seatstay.
    I now use it with vertical dropouts and the cable runs along the seatstay.
    Tim
    Rhymes with fartmaster
    The white one and the chromed one are for horizontal dropouts. Here is the chart from Sheldon Brown:
    Using these ones, your shifter cable will run parallel to your chainstays rather than your seatstays.
    Dec 2008
    Blue and green, they are intended for vertical dropouts and chainstay routing. But if you use them in horizontal dropouts you get the acceptable angle for seatstay cable routing.
    Frt Range, CO
    Reputation: pursuiter's Avatar
    I run white on the right, grey in the left:
    Reputation: thasingletrackmastah's Avatar
    6 or 7 are the best choice.
    I used #7(black/grey) on my Inbred 29.
    At first I used the std blue/green, but with hor.dropouts this routes the cable 90 degrees up, to much of a good thing.
    PS: I did not need a chaintug.
    The hub stayed in place with only the washers (steel frame).
    Belgian beer and Scotch whisky.
  1. Tuggnuts with non-turn washers, problem and solution.
    By Drew Diller in forum Fat bikes
    Last Post: 09-27-2010, 08:45 AM
  2. Element Horiz. TT length
    By glorth2 in forum Rocky Mountain
    Last Post: 05-09-2008, 06:16 AM
  3. Running Gears on Horiz Dropouts?
    By OneEyeMan in forum 29er Bikes
    Last Post: 04-03-2008, 03:36 PM
  4. Welding on horiz. drop outs
    By duotone in forum Frame Building
    Last Post: 08-20-2007, 02:18 AM
  5. disc brakes and horiz dropouts
    By ricer in forum Singlespeed
    Last Post: 12-05-2005, 07:25 AM
