Results 1 to 9 of 9
Thread: Alfine love..
    Stubby-legged
    Smile Alfine love..
    Loving the A8 and the A11 on our 907 fatbikes.
    Not liking the Surly singulator as a tensioner. Sounds like a front derailer that is out of tune.magic gear doesn't seem to exist.
    Looking at e.thirteen or MRP bottom brackett chain retension device.
    Did I forget to say we love the Alfine?
    Reputation: vikb's Avatar
    Do you have the singulator pushing up or pushing down? I had one on a touring bike pushing up with a Nexus 8 IGH and it was quiet. You can adjust them side to side as well to match your chainline.
    Maybe post a pic of your setup?
    I have had goodluck with the Rohloff dual pulley tensioner on a couple bikes, but it doesn't have the ground clearance of the singlulator.
    Safe riding,
    Vik
    www.vikapproved.com
    will rant for food
    I've also had problems with loud Singleators, up or down mode. I set up one dinglespeed bike with a Singleator and it was fine, and the same concept should apply equally between those two types of drivetrains... I was puzzled.
    I had good luck with the Shimano tensioner which sounds like it was similar to the tensioner vikb mentioned, but it took away my appreciation for the what was supposed to be the general sparseness of the drivetrain.
    Are mini-eccentric bottom brackets for fat bikes getting to be any more affordable or available?
    Stubby-legged
    Both pull up. New drive train. Well oiled chain. I went from silent igh gear on the Pugs to noisy on the 907. The wife went from stick attracting derailers to noisy singulator. I am trying to eliminate dangling, stick prone things on her bike. Looked at shimano, Pauls and others. Surlys up-pull was what attracted me to it.
    Gonna try a BB based chain guide next...
    Stubby-legged
    Mech at the LBS said the chainline distance from the center of the dropout to the center of the chain is far enough to "tilt" the pully wheel, causing the noise.
    Having said all that...last nite's ride resulted in a bang and a pop. The hub went into rattle can mode. Headed back to the LBS today. The last time I had that noise, we took it apart and found nothing.Put it back together and , viola! No noise.
    I still love the hub.
    Quote Originally Posted by 1spd1way View Post
    Can you adjust the chainline of the singulator to match the Pugs?
    Safe riding,
    Vik
    www.vikapproved.com
    will rant for food
    1spd1way, have you gone ahead and tried a BB mounted tensioner just yet? A memory jogged for me, I've tried one. Yo... they're not quiet either. The one I tested was a Yess ETR-B.
    (Incidentally their ETR-V is very strong.)
    It now occurs to me that the drivetrain I set up where a Singleator *was* quiet had a rear cog that was horizontally very near the dropout. An Alfine kinda has a hard time with that given the space taken up by the shifter mech.
    If only there was a way to twist the Singleator so that its own natural twist under tension would even out and put the jockey wheel in an in-line path with the rear cog...
    This situation is stupid enough I thought about some mid-chainstay tensioner. I'll have to look for what people have come up with regarding that idea.
    Stubby-legged
    Late breaking news!
    I brought it in yesterday and the Mech disassembled and greased the singulator. Re-alligned it and it is now very quiet.
    The rattle can sound was from the top of the chain hitting the cable-stop for the shift cable.
    Hammered the bugger on the ride last nite. Quiet, consistent shifting.
    I am going to look at my old Yeti dh frame. It had a mid-stay tensioner. May be able to adapt or re-engineer something.
    will rant for food
    Nice!
  1. Replies: 35
    Last Post: 11-25-2014, 07:32 AM
  2. Replies: 7
    Last Post: 08-15-2013, 05:22 PM
  3. Do you love your Pivot 5.7? Do you love your Turner 5.Spot?
    By nando in forum Bike and Frame discussion
    Last Post: 10-03-2012, 08:23 AM
  4. Replies: 2
    Last Post: 06-06-2012, 04:20 AM
