    Reputation: OldschoolReloaded's Avatar
    Nov 2012
    Alfine Hybrid Gearing?
    Hi all,
    I was wondering if any of you run a Shimano Alfine 8 IGH with a double chain-ring with derailleur. I have a Surly Pugsley with the Alfine but there are times that I would like to go lower than the gearing allows, such as plowing deep snow. So how does this work as far as gear inches? What chain-rings should I use to get good usable gears without a lot of overlap?
    Thanks in advance!
    Reputation: Wombat's Avatar
    Here's a comparison table I did a while ago with various ring and gear combinations. The ratios column is the Alfine ratios. I ran double chainrings (32/22) with I think an 18 tooth gear and it was low geared, which suited me as I'm fat and unfit. If you search various posts you'll see that there's some contention on how low a ratio the Alfine will handle, but Shimano hasn't set a minimum ratio,and most of the examples of unreliable Alfines are the 11 speed version.
    You'll have to run a chain tensioner with this set up.
    Attached Thumbnails Attached Thumbnails Alfine Hybrid Gearing?-alfine-ratios.jpg
    Nov 2012
    Thanks Wombat!
    Mar 2013
    You can calculate how various drivetrain configurations will work at Sheldon Brown's website.. I first calculated what I had with my 27 gear dérailleur set up because I knew what that felt like and then replicated with the Alfine gearing (minus 3 gears)
  1. best hybrid? anyone make a 29er hybrid?
    By donn12 in forum 29er Bikes
    Last Post: 12-11-2013, 06:25 PM
  2. Replies: 2
    Last Post: 06-06-2012, 04:20 AM
  3. Alfine 11 Gearing for 29er Hardtail MTB...
    By vikb in forum Internal Gear Hubs
    Last Post: 02-15-2012, 09:07 PM
  4. Replies: 2
    Last Post: 05-06-2011, 12:34 PM
  5. Alfine gearing?
    By mtb143 in forum Internal Gear Hubs
    Last Post: 02-21-2011, 11:54 AM
