Results 1 to 8 of 8
    Alfine: diff between 500 and 501 labeled hubs?
    My subject is my question... Just curious what the differences are, and if there is a reason to get one over the other.
    Dec 2008
    hei,
    Shimano tech tips say:
    "Roller clutches are used in place of pawls to reduce
    noise. The new hubs are now almost completely silent, there is
    only a ratcheting noise when backpedaling.
    There is also a new torque
    limiter which will make it harder to damage the hub
    with too much pressure from the pedals."
    SG-S500 A-type use 2 roller clutch, and SG-S500 B-type & SG-S501 3 roller clutch.
    How to identify A & B type ?
    A-type is SG-S500 and B-type is labeled SG-S500
    I use both hubs, older A-type 500 and new 501.
    501 is more silent and gear engaging is maybe tiny bit faster.
    But no big difference between hubs.
    Quote Originally Posted by irrah
    Thanks for the info, but you lost me with this part!
    Dec 2008
    That is hilariously not obvious without that pict. Thanks for clarifying.
    On MTBR hiatus :(
    Seriously? An <u>underline</u>. That, right there, is a perfect example of Shimano trying to be sneaky and prevent the consumer from asking any questions of the dealer.
    speedub.nate
    MTBR Hiatus UFN
    That's good info, Thanks. I'm thinking of using the
    501 instead of SS on the steeper rides here in the east bay hills. A different gear or 2 would be nice on the grades of 20 to 35 %.
    Does the 501 handle SS type riding style?
    hei,
    Quote Originally Posted by SnakeCharmer
    Who cares? You need to be the guinea pig anyway. Place your order!
