Results 1 to 3 of 3
    Reputation: singlespeedstu's Avatar
    Alfine Chainline Question.
    I just got my hands on a second hand Alfine.
    I want to run it with an XT HT2 crank with the ring in the middle position.
    So do I have to reverse the sprocket on the Alfine to bring the chainline out to line up with the chainring?
    What about a flat cog on the Alfine. Will that work with the same crank?
    dru
    dru is offline
    Flipped will give 47mm. Unflipped is 42 (I think). Typically the big S recommends 47 to 50 mm chainline for the middle ring. Shouldn't be a problem to work all that out.
    Drew
    occasional cyclist
    Thanks for that.
    stu
