Results 1 to 5 of 5
    Alfine chain problem
    I love my alfine hub but on a 6 in travel bike,Im constantly dropping my chain,(even on small drops} and then shear off the shifter cable at the cassette joint.My chain line is good and my chain is pretty tight.Do i need a stronger chain tensioner or will a chainguide (e13) fix this problem?......thanks
    What chain tensioner are you currently using? You really need a double pulley on a full suspension bike.
    thanx
    i use a $20 rear chain tensioner but i was thinking i need something better ,when schmucker means double pulley ,what does he mean,something like E13,sorry im new to tensioners and chain guides,can anyone tell me a good brand to go with,i just dont want chain derailment anymore....thanks alot...............peter
    Reputation: biketuna's Avatar
    post a picture of what you have.
    _______________
    1x10 IS SO FINE on my 21.9 lbs IBIS SL-R
    11-36 XTR in the rear, 36T wide-narrow upfront
    The Rohloff tensioner, Paul Melvin... those types.
