Results 1 to 14 of 14
    Sep 2013
    Alfine 8 Weird Shifting
    Hey all, this is my first post, and I'm hoping that there are some experts out there on the Alfine 8 (SG-S500, with SL-S500 shifter)
    I bought this hub used, and before I tried it I did the ATF fluid bath. After I reassembled it, it shifted very oddly.
    On the 1st through 4th gears, it shifts up a gear each time, then shifts down a gear or two on 5th, then up again for 6th, then stays constant until 8th gear.
    I believe I did everything per the instructions, and the yellow dots line up and so forth -- is the hub toast? I attached a picture for clarity in case my explanation was hard to follow.
    Attached Thumbnails Attached Thumbnails Alfine 8 Weird Shifting-dsc_0783.jpg
    dru
    dru is offline
    You have the yellow dots lining up in 4th gear?
    Drew
    occasional cyclist
    Sep 2013
    Yeah, the dots line up perfectly in 4th.
    Reputation: OFFcourse's Avatar
    Have a good look at the cable and make sure there are no bends/krimps etc. bad routing, also check that the bolt is attached to the cable at the specified distance.
    Sep 2013
    It's a new cable, and the bolt is connected at 127mm (I'm using the wet weather cassette joint). Thanks for the relplies!
    -Joel
    I didn't know there was a wet weather joint does the regular one have a bolt connection at 100mm BTW? (my manuals in a box somewhere)
    Sep 2013
    Yeah, the normal cassette joint has a distance of 100mm, but the wet weather one has a rubber grommet to keep water out, so the metal arm is longer, hence the longer bolt distance.
    The shifter is working fine, the cable is new, the distance is correct for the cable bolt, and the dots line up when in 4th. I'm thinking that this problem lies inside the hub, as everything else seems to check out... is there a way to assemble the hub wrong so it starts in the wrong gear?
    Tonight when I get home I'll see which gear is direct drive, I doubt it's going to be 5th gear which I believe it's supposed to be. That should give me an idea if I'm off by a few gears or something.
    Here's a link to a file that does an excellent job showing how an alfine 8 works:
    Alfine 8 5th gear, 1 to 1
    Cheers,
    Joel
    Sep 2013
    A little update, all of the gears when cycling through the shifter are lower than direct drive, that is, the cog spins faster than the hub...
    -Joel
    Have you checked that the cable is running clean through ALL the gears.
    I had the rubber boot on my wet weather cable pulled all the way down and when I shifted into the highest gears it would ride between the cable and the cassette joint, pulling the shift mech to a lower gear. That was on my 11-spd though, I would think if that happened on an 8 you'd end up in a higher gear
    Sep 2013
    Yeah, the cable is moving smoothly through each of the gears, and I actually didn't even install the rubber boot because it's not wet out yet and I didn't want to introduce more friction into the system than there already is.
    -Joel
    Sep 2013
    Anyone here know what's going on? I'm about to scrap it and buy a new hub...
    -Joel
    will rant for food
    I *think* there's a second pawl above 5th that manages the overdrive gears - sounds like it's broken.
    Sep 2013
    Is that a replaceable part? I'm going to contact Shimano to see if I can purchase that part.
    -Joel
    will rant for food
    Quote Originally Posted by munsonjo View Post
    -Joel
    Sorry, that's a bit beyond my level of intimate knowledge of the hub. I would be sure to describe how almost half your gears are inaccessible and I bet they'd know what the issue is right off the bat. If you're lucky, warranty and wheel relace would probably be easier.
  1. Weird Shifting on my Scalpel
    By Thatshowiroll in forum Cannondale
    Last Post: 05-21-2013, 06:27 AM
  2. NYC weird bike
    By carlosmontiel in forum Off Camber (off topic)
    Last Post: 11-04-2012, 04:45 AM
  3. Replies: 2
    Last Post: 06-06-2012, 04:20 AM
  4. Weird booster (is it?)
    By dhollman in forum Brake Time
    Last Post: 05-17-2011, 09:39 AM
  5. Fox RP 2 weird click
    By nicoswit in forum Shocks and Suspension
    Last Post: 03-16-2011, 11:47 AM
