Results 1 to 5 of 5
    Alfine 8 casette joint problem
    please help,i took my alfine 8 apart, Cleaned it with kerosene,then ATFed it and regreased it,but i might have put it back together wrong......i can pedal in 1 2 3 4(the yellow dots line up)5 6 7 and 8 th gear but when i shift from 8 down to 7 6 5 4 the yellow dots dont line up ...basicly the cassete joint doesnt spring back all the way(on the down shifts) unless i help push it back with my finger...does anyone have an idea what may be causing this problem????my shifter and cable are working very smoothly...i think its in the joint not the cable or shifter......thanks
    Reputation: Corporal Punishment's Avatar
    If you're positive its not a cable issue then try greasing the cassette joint for smoother operation.
    J-7
    J-7 is offline
    The two parts that rotate against each other can be pulled apart. Pull it apart and clean it real well then try some lube. My guess is that instead of grease something like a wax chain lube or even graphite for locks is probably ideal. I don't remember off hand but there is a little screw on the cassette joint that might need to be removed to separate the two parts.
    Frt Range, CO
    Reputation: pursuiter's Avatar
    The cassette joint's back plate should cup downward (towards the spokes), not upward. If you put it in backwards the cassette joint will stick.
    Dec 2014
    Quote Originally Posted by mntbkr68 View Post
    Did you find a fix for this? I have the same problem. Was it this: "The cassette joint's back plate should cup downward (towards the spokes), not upward. If you put it in backwards the cassette joint will stick."
  1. Alfine 11 mud in cassette joint
    By presslab in forum Internal Gear Hubs
    Last Post: 03-17-2013, 03:14 PM
  2. Alfine Rotating Cassette Joint Issue
    By bsdc in forum Internal Gear Hubs
    Last Post: 04-29-2010, 10:41 AM
  3. Newbie-- Alfine problem
    By lonnierenda in forum Internal Gear Hubs
    Last Post: 04-07-2010, 03:51 PM
  4. Alfine chain problem
    By mntbkr68 in forum Internal Gear Hubs
    Last Post: 05-10-2009, 01:20 PM
  5. Casette/chain problem
    By Akuma in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-21-2006, 12:13 PM
