Page 2 of 2 FirstFirst 1 2
Results 26 to 28 of 28
  1. #26
    Alfine 8 cable routing options?
    Hey, Alfine gurus -- I'm getting some time and miles on my new 8 (love it/am buying another one), and every once in awhile I get a ka-klick and a bit of forward motion on the pedals. Mostly in a couple of the higher gears, 7 specifically. Other than that, everything seems perfect.
    I have read about others having phantom symptoms like this. It happens in frequently and is not really a problem. I just wonder if there is more I need to be aware of.
    My yellow dashes are lined up fine on the hub, and I am good about not applying torque to the pedals when shifting. Thanks for any feedback!
  2. #27
    singlespeed smash brother
    Reputation: shwinboy's Avatar
    I found my alfine 8 really finicky to tune so it shifts right all the time. Lining up the yellow markers is the first step but isn't precise enough as I have found a little as 1/4 of a turn on the adjustment barel can cause issues. So to can any bend in the shift cable. I was having problems with it slipping under load in 6 th. I had to rerout my cable to eliminate a bend which helped but didn't fully resolve the issue. Then I just went out and rode an made small adjustments to see what would happen. As I loosened the cable my problem seemed to migrate to gears 7 and 8. So I had to tension the cable more to fix the problem and it was all out 1/ 8 th of a turn on the adjuster that did the trick . More than that and it would skip 6 th on the down shift. I have it dialled now and I've been enjoying my ride a lot more.
  3. #28
    A God Without A Name
    Reputation: Agwan's Avatar
    I've found that I got smoother shifting if I didn't run full length housing. on my Straggler I ran it to the bolt on down-tube mount (effectively giving me two barrel adjusters) then I ran the cable naked all the way back to the chain-stay mount.
    at the chain-stay mount I took a good 45 minutes snipping and filing down a "dog leg" with the most gradual bend I could give it. I kept it clean and well lubed and I never had the sluggish shifts I had with full length housing.
    Once set up, I ONLY used the downtube barrel adjuster, it seems to adjust in smaller, smoother steps.
  1. Cable housing options for internal routing
    By sam-eye-am in forum Ventana
    Last Post: 10-27-2013, 05:41 PM
  2. Replies: 9
    Last Post: 10-03-2013, 05:53 PM
  3. Anyone try seatstay cable routing with Alfine?
    By bikeny in forum Internal Gear Hubs
    Last Post: 11-15-2012, 12:39 AM
  4. Internal cable routing as it relates to cable housing bend?
    By Drew Diller in forum Frame Building
    Last Post: 10-10-2012, 07:44 AM
  5. Cable routing on TBc
    By cornice6 in forum Santa Cruz
    Last Post: 08-20-2012, 05:06 PM
