Results 1 to 5 of 5
    emtb.pl
    Reputation: krolik's Avatar
    Alfine 11 - what shifter options?
    I was thinking - anyone offering any alternatives to Alfine 11 shifter?
    Any new 11speed shifters fit?
    Does anyone have any idea what is the shifter cable pull ratio?
    I'd love to run a GS on the Alfine I just purchased
    tia
    Re: Alfine 11 - what shifter options?
    Alfine/other IGH use even pulls between gears, derailleur drivetrains do not, so the only compatible shifters are ones made for it.
    The official word from Shimano is that they will not/have no plans to offer a grip shift. The reasoning from an engineer I spoke with is that the hub can only shift two gears in a row, anyway.
    Currently, shifter options are limited to the Versa integrated shifter (drop bars) or the rapidfire shifter made by Shimano. The only other options are Di2 switches, but the mechanical Alfine hub is not compatible with the Di2 motor unit.
    singlespeed smash brother
    Reputation: shwinboy's Avatar
    Zerode do a modified sram shifter for their dh bikes. You can buy the shifter off them or just the part if you have the correct shifter to convert already.
    emtb.pl
    Zerodebikes - Parts, SRAlfine shifter
    but it's only for 8speed Alfine, right?
    Plus it's a trigger shifter still.
    Whoops yeah. 8 speed only. Sorry. Had a brain fart.
  1. Which Alfine 8 Shifter?
    By eugenemtbing in forum Internal Gear Hubs
    Last Post: 12-10-2014, 01:41 PM
  2. Bar End Shifter for 8sp Alfine
    By klunker2 in forum Internal Gear Hubs
    Last Post: 11-26-2012, 12:16 PM
  3. alfine 11 speed shifter
    By pintwister in forum Internal Gear Hubs
    Last Post: 05-13-2012, 06:07 PM
  4. Is Alfine 8 compatible w/ a bar-con shifter?
    By BIGfatED in forum Internal Gear Hubs
    Last Post: 03-20-2011, 08:04 PM
  5. alfine 11 shifter . . .lemon ??
    By T mon T in forum Internal Gear Hubs
    Last Post: 03-18-2011, 10:16 AM
