    alfine 11 speed shifter
    I have the 11 speed hub with the sl-s700 rapid fire shifter.
    Has anyone had any problems with the shifter shifting to lower gears.
    Sometimes mine requires a full push on the lever to shift. If I try to shift only one gear, it will not shift. This is a random occurrence. If I repeat it a few times, It gets it right.
    Shifting to higher gears is ALWAYS perfect, only shifting to lower gears. I have replaced the cable twice, thinking that could be the problem. I have even adjusted the cable so the indicator is off center. Tried it in both directions. None of this seems to help.
    HELP !!!
    Reputation: FlowinFlo's Avatar
    Sounds like the cable housing could be the problem. Maybe the curves of the housing arenīt "wide" enough and the cable canīt slide so easily to shift down? Just a thought.
    That would also be my first guess. Cable friction problem. Kink somewhere. Sometimes the housing can look fine but a kink on the inner cable will increase friction a lot.
    Looking forward to Di2 !
