Results 1 to 6 of 6
    Reputation: bluechair84's Avatar
    An Alfine 11 measurement plese
    Hi guys, I'm doing some thinking about building a shed frame based around an Alfine and I'd like to know the distance between the disc rotor and the drive sprocket. Would someone just put a tape measure to theirs and give me a rough idea?It'll help me work a few things out on the frame dimensions.
    Feb 2006
    I got 3.90" from the inside face of the rotor to the inside face of the sprocket.
    The sprocket is dished so it can be installed to the inside or outside of the hub.
    Also, I found this if it helps.
    Shimano Alfine SG-S700 (11-spd) 135mm Rear hub dimensions | Freespoke | Freespoke
    d
    Quote Originally Posted by synthesis View Post
    Is this to help with chainline? Thanks for the measurement
    Maybe these will help?
    Amazing, yes they will
    No sweat. You realize that they were the first two results of a google image search for "Alfine dimensions".
    I'll send you my bill.
  1. Which leg for sag measurement?
    By taylo in forum Shocks and Suspension
    Last Post: 07-24-2012, 10:00 PM
  2. Replies: 2
    Last Post: 06-06-2012, 04:20 AM
  3. BB Measurement
    By Brakebreaker101 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-19-2012, 06:47 AM
  4. Replies: 5
    Last Post: 01-06-2012, 10:36 AM
  5. Seatpost measurement
    By SpringsRubicon in forum General Discussion
    Last Post: 03-11-2011, 08:18 AM
