Results 1 to 2 of 2
    Jun 2010
    XX1 and chainstay clearance on the Hard Eddie
    Hi,
    I have a Hard Eddie in size M. Currently I'm using an XX crankset with 26/39 chainrings. Q-factor is 156, and arm length 175mm.
    Clearance between crankarms and the frame is about 7-8 mm. Clearance between the chainrings and the chainstay is even smaller. Probably about 5-6 mm.
    I'm considering switching to XX1, and from what I can see from the frame fit specifications from SRAM, clearance is event tighter with XX1. According to the specs the single chainring on the XX1 crankset is spaced only 2 mm further out from the center of the frame than the inner ring on the XX crankset.
    The XX1 chainrings are considerably larger than the 26T inner ring I am using now, so I'm concerned the larger XX1 chainrings may rub on the chainstay.
    Anyone on here having successfully used XX1 on their Eddie?
    Quote Originally Posted by torsteinvh View Post
    Hi,
    Hi, just bought a XX1 groupset for my H.E, but the Q-Factor that I choose is 168, I thinks is more according for this bike. This week I will build the groupset and will add some pics.
  1. Need feedback - Hard Eddie vs. Air 9 RDO
    By Killowatt in forum 29er Bikes
    Last Post: 09-18-2014, 10:43 AM
  2. my Hard Eddie 29
    By wignacio in forum 29er Bikes
    Last Post: 05-08-2013, 11:52 AM
  3. My Hard Eddie 2013
    By colnago888 in forum Intense
    Last Post: 01-15-2013, 11:21 AM
  4. Looking for Feedback on Hard Eddie
    By Bbbrad in forum 29er Bikes
    Last Post: 09-18-2012, 12:11 PM
  5. Hard/Fast Eddie
    By reydin in forum 29er Bikes
    Last Post: 09-05-2011, 11:54 AM
