Which X.0 or Descendent cranks for Socom (150mm)
I'm looking to upgrade the cranks on my Socom frame with the 150mm rear end, but I'm not sure which cranks will fit properly because of the 73mm bb shell. I have the older style LG1 wide chain guide and am running 9spd. I would like either X.0 or Descendent cranks with a 165mm arm length.
Honestly I don't know if the Sram cranks you listed will work or not. Race Face does make a kit so that you can use any of their 83mm BB cranks in a 73mm BB. I have used one a SS1 with 150mm hub spacing and it worked well. I think it was only $14 too. The Atlas cranks are pretty sweet.
- You may not post replies
- You may not edit your posts
Forum Rules
