Results 1 to 5 of 5
    Jun 2013
    VPP maintenece help
    New to VPP suspension, and just need to know if a special grease gun is needed? Intense website doesn't seem to have any info and their link for getting a manual on the bike is a dead. bike is a 2013 Carbine 275 if that makes any difference.
    CTB
    CTB is offline
    Reputation: CTB's Avatar
    It does make a difference. Intense changed the type of zerk fittings they used. My 2009 Tracer VP has the old flush ones that are very small, and I had to buy a special grease needle. Even that works very poorly, so much so that next time I do the bearings, I'm going with sealed bearings. Later bikes have much larger zerk fittings, but again they are the non-ball type. Your Carbine should have the very latest, though I'm not sure what style that is.
    I bought something like this to use with my "normal" compact grease gun:
    Performance Tool W54216 - Grease Gun Needle Adapter | O'Reilly Auto Parts
    You can always take the zerk fitting out and pump grease directly into the chamber.
    Jun 2013
    CTB & mbell thanks for the info, seems a grease gun of any type would work assuming I get the right fitting.
    Reputation: Rojo Grande's Avatar
    Oct 2012
    Is there a wrong type of grease or is anything better than nothing?
    "El Cajon?, that's the anus of San Diego"
