Page 4 of 9 FirstFirst 12345678 ... LastLast
Results 301 to 400 of 833
  1. #301
    Reputation: stuffshredman's Avatar
    Thanks for the feedback!
    To answer a few questions:
    My height: 5'6" (and an eigth ~8^)... the small is perfect for me.
    Bike weight.. unofficial is 33.5lbs
    HA with Fox 36 Van should be 66 with slack G3 and 67.5 with steep G3.. but I haven't measured it
    Why Van over Float? I'm a coil guy and willing to pay the weight penalty to get it.
    Why not a 180mm with drop seat? The best reason is this bike is to fill a gap in my garage. I have a Santa Cruz VP Free with Marz 888 and a Fifth Element, Mav 729's with 2.6" on them.. this is my big hit bike... so I wanted to build a lighter, more nimble all mountain rig in the Uzzi.
    The shock is a CCDB 8.75x2.75 with a Manitou Ti spring, 400lbs and 1.43" id.
    There is one downside to the bike. The other night, during a romantic interlude with the wife, I said "you're so Uzzi".. she didn't like that. Afterwards, I said "wow, that was Intense".. she didn't like that either. I'm pretty happy sleeping in the garage, tho, now my precious little Uzzi is out there
  2. #302
    My leg feels funny
    Reputation: liqwid's Avatar
    Quote Originally Posted by stuffshredman
    at least you didn't call out 'oh uzzi!' in the middle
  3. #303
    Dec 2005
    I think they measured the headangle with a flush headset so your's might be slightly slacker with the Chris King bottom cup on there (nominal difference though). Looks real nice!
  4. #304
    Reputation: nanhar's Avatar
    Dec 2004
    Recently swapped the coil for an air shock and took it out for a DH race!
  5. #305
    Reputation: kondi's Avatar
    Quote Originally Posted by nanhar
    amp;d=1264437019[/IMG]
    tell me something more ab. difference between coil vs. air ?
    I see that you have gravity dropper ... cool show more pic how it looks
  6. #306
    Dec 2004
    Quote Originally Posted by kondi
    The Fox coil was just too soft and ineffective for climbing for me, not being a strong climber (due to knee injury). I tried stiffer springs and more air and could never get it to where I needed it to be (there was just too much sag and riding G-outs and switchbacks uphill was just too draining). I tested it with the Fox Air shock and found it to be very plush on the downhill and much easier to climb with. I am running 300lbs in the main chamber and 200# in the smaller one.
    Yes, I am running the GD Turbo and love it. I have the 1"/3" version.
    I don't have any close up pictures of the mods yet, I will have to take some.
  7. #307
    Reputation: Hiramson's Avatar
    Some more pics
    Has been raining long weeks here & at last went out the street.
    Can't wait to taste in his truly place.
  8. #308
    More details:
  9. #309
    wuss
    Reputation: dropadrop's Avatar
    Nice shots, what camera / lens?
  10. #310
    Exactly this:
  11. #311
    wuss
    Ok, I'll just be jealous about the bike then
  12. #312
    I'm sure this has been covered but couldn't find answer quickly so maybe y'all can help. Which hole on the Uzzi's shock mount is for short travel? Lower or upper hole? It really would be nice if Intense published a bit more information on their website.
  13. #313
    Edit mistake.
  14. #314
    Dec 2005
    I think it is the other way around.
    I think the upper is for longer travel and the lower is for shorter travel. Not sure about the math behind it but I am pretty sure that is how it goes.
    Edit: Here is a link with Intense stating the lower hole on the Tracer is 5.5 and the upper hole is 6.0. I assume it is the same for the Uzzi
    Tracer VP Sag/Pivot Bolt Location
  15. #315
    Ideas Above My Station...
    Reputation: Orange-Goblin's Avatar
    Hmmm, Hiramson's logic is correct so hows it Jeff says its the other way around, does the ~VPP movement do something weird to the math there?
    Its All Downhill From Here....!
  16. #316
    Dec 2005
    I think the logic is that when you have a longer lever (bottom hole) it moves the shock an increased amount for a given travel in the rear wheel. The shorter lever (top hole) doesn't actuate the shock as much.
    There are multiple threads explaining that the lower hole is the reduced travel setting.
  17. #317
    I'll side with you smithrider the upper hole is the long travel position and lower is the shorter travel position.
    I agree with richiban how about a quick guide on the website. Positions, part diagrams, dissasembling instructions, front derailler and chain guide compatability and torque settings. Just for the people out there who are silly enough to work on our own bikes.
  18. #318
    Reputation: dreicha's Avatar
    Aug 2005
    Quote Originally Posted by Hiramson
    Upper (short linkage radius) = short travel
    Lower (longer linkage radius) = long travel
    Let me correct you..
    The longer linkage radius takes more travel from a shock stroke at the same wheel travel than the shorter linkage radius, it means that the stroke will end faster & the wheel travel will be shorter. And vice versa.
  19. #319
    Just a quick graphic to demonstrate, Upper hole is longer travel, as Smith and others said.
    I was tired when i read this ha ha!!
    Upper bolt hole shows less shock travel for the same wheel travel due to the shorter swing-link radius. So, the shock has got more compression left available for more wheel travel.
    Sorry about the crude vector. Hope it helps.
  20. #320
    Intense Uzzer
    Reputation: dopaminer's Avatar
    Awesome, man. Thanks!
  21. #321
    Jan 2009
    This is my extraordinary Uzzi:
    -Frame: Intense Uzzi Vp Blu works taglia M;
    -Rear Shock: Fox DHX Air 5.0;
    -Fork: Fox Talas RC2 Fit;
    -Brake: Hope V2 Tech;
    -Discs: Braking semiflottanti->203mm e 184mm
    -Group: XTR -> Crankset 172,5 22-32-44, rear derailleur shadow medium cage, front derailleur 34,9, chain, pedals, shift levers, cassette sprocket 12-34;
    -Wheels: Spinergy Xyclone Enduro 24 rims;
    -Tyres: Michelin All Terrain 2.35-2.20 ;
    -Saddle: Selle Italia SLC
    -Seatpost: Thomson Masterpiece;
    -Stem: Thomson X4 70mm;
    -Handlebar: Easton MonkeyLite Xc Hi-Rize 68,5
    -Headset: ChrisKing devolution 1,5-1-1/8;
    -Bottom Bracket: ChrisKing;
    -Handlebar grips: Odi Rogue;
    -Seat collar: Hope
    -Rear QR: Hope
    Weight: 14,4 Kg...
  22. #322
    Quote Originally Posted by Orange-Goblin
    That's was just the confusion subject for me.
    I thought partial and in abstract: radius length as compression capability (less lenght = less compression).
    Apologizes.
  23. #323
    Just one thing still confuse me about the graphic:
    How is you are talking about the SAME WHEEL TRAVEL?
    Aren't we talking about to change this wheel travel by changing those bolts in the linkage?
    Thanks in advance.
  24. #324
    We're talking about the same in comparison, Hiramson, ha ha!
    The first 5" or equivalent are still moving through almost exactly the same curve, but the short travel will end quicker because the shock is compressing more in the first 5", whereas in the long travel position, the shock compresses less, and so when it gets to 5.5" it still has a little ways to go, allowing the full 6" or whatever.
  25. #325
    Orange-Goblin, thank you very much indeed about clarify. All uderstood. (Bad day).
    Upper = long & Lower = short. Graphics express that very clear.
    Look forward to prove that on downhills & taste reactions on that. Couple of days ago I came out to go fitting with the bike riding trhough the city and fits really really maneuverable (lower bolt anchor & relaxed angles dropouts).
    If this proved getting a very equilibrate bike (at 1st sight, awainting to getting offroad), I look forward to prove too how will it rides with upper anchor + relaxed dropouts for downhill and with lower anchor + vertical angles dropouts for more relaxed long routes pedaling.
    Really is a very versatil bike all mountain/freeride riders aimed.
  26. #326
    hello i have an uzzi vp with coil (i will post photos soon)and i want to learn how the uzzi works with the dhx air? advantages and disadvantages
  27. #327
    So, I went and ordered on of these. Let's see how how and when it turns out.
  28. #328
    Dec 2004
    Quote Originally Posted by kostas
    For me, it climbs much better with the air shock. I have not found any disadvantages yet.
  29. #329
    wuss
    http://www.socaltrailriders.org/foru...p;d=1265986699
    Better then what? Due to the weight advantage or you feel the dhx air is just a superior shock to the ccdb?
  30. #330
    Dec 2004
    Quote Originally Posted by dropadrop
    I can only compare the Fox shocks. I had the coil and it was great for descending but crap for climbing, no matter which spring, air pressure, rebound, etc., I could never get it stiff enough for climbing. The 2 shocks themselves weigh almost the same, then add the weight of your spring. My bike in it's current configuration weighs 32.5lbs.
  31. #331
    uzzi se
  32. #332
    Quote Originally Posted by swiss intense
    Is this your intended colour scheme?
    Would like to see the bike actually done like that, have you bought one yet?
  33. #333
    uzzi se
    hi
    i'm intense dealer in switzerland and this one is my 3. uzzi, first works than works blue and now ultra violet.
    the paintjob is made by intense cycles usa. with signature from mr.intense
    so believe it or not.
    you can visite my shop to see the bike live.
  34. #334
    wuss
    I love the purple uzzi <3
    What's the wheelset, dt tricon?
  35. #335
    uzzi se
    the wheels are dt ex 1550 carbon
    my intense bikes
    family
    uzzi, tracer, 951 and 3 ms racing prototypes tazer ht, m6, 6.66
    have fun
  36. #336
    Reputation: iRider's Avatar
    I dunno about the color....and the wheels + tires. They look more trail bike/all mountain to me.
  37. #337
    Reputation: ir12daveor's Avatar
    I've met Swiss Intense's Ultraviolet Uzzi in person. It's a sweet looking bike.
  38. #338
    uzzi
    hi ir12daveor
    cooper i love it
    mt vo horgen
  39. #339
    My leg feels funny
    One more for the list
    Specs:
    Frame: Large Uzzi VP, raw,
    Rear shock: Cane Creek Double Barrel
    Fork: Lyrik U-turn with 2010 MiCo DH and rebound
    Headset: Cane Creek XXc Flush II
    Stem: Thomson, 50mm
    Bars: Easton Monkey Lite DH
    Brakes: Avid Elixr CR, 185mm front, 160mm rear
    Shifters: SRAM X.0 triggers
    Front derailleur: Shimano XT
    Rear derailleur: Sram X.0 med cage
    Cranks: Shimano XT, Gammut P30 bash / Blackspire Stinger Guide
    Wheels: Chris King hubs w/Fun bolts, 135 x 12mm rear, 20mm front
    Rims: Mavic 819
    Pedals: Deity Decoy
    Weight: 34.5 lbs
  40. #340
    Quote Originally Posted by iRider
    Well he does have a 951 too!!! A lot of the Uzzi type trails over here have a bit of pedalling to do to get to them. I have my Uzzi set up in a similar way (not quite as light as Swiss Intense's though) and its a bike I'll do 3000+ feet of climbing and 10000+ feet of descending on in a day.
    Any more climbing and I'll use my 5.5. (Speaking of which... My wheels ready yet Swiss Intense? Only kidding, no hurry.)
    Horses for courses!
  41. #341
    hi
    Seeing your 'intense family' pic i don't doubt it exists, but you've messed with the colour in that pic so much that it looks badly ps'ed.
    The Red on the DT Swiss wheels, and decal on the X0 mech are now Pink because of the changes, thats what makes it look PS'ed.
    In the picture of all your bikes its clearly red as usual, and the Violet is far more realistic.
    Sorry for doubting ya, but that pic does the bike no justice....or favours!!
  42. #342
    Who went from a Slopestyle to the Uzzi...
    I am on the verge of buying an Uzzi and would love to hear that it rides very similar to the Slopestyle. This is going to be my only ride
    so I want it to handle jumps and corners well.
    I realize that it will climb better and handle other areas well.
    Will I even notice a difference with a 1/4 to 1/2 inch rise in the BB?
    Thanks for any info
  43. #343
    TBH, the top picture is actually how the bike looks. The saturation looks like it is pumped up a bit in the picture, but the colour is quite accurate.
  44. #344
    Quote Originally Posted by ir12daveor
    All I am saying is that if the terrain calls for a coil shock and a Totem normally Nobby Nics are not the tires I want to use. Especially not paired with carbon rims. Fat Alberts or Big Bettys FWIW.
  45. #345
    uzzi
    hi
    i ride the noby's in normal trail use and i like them. my uzzi weight 14.2kg trail use.
    hc ride i change to 909 or edge.
    dh ride sorry i go with my 951 and intruders.
    see you @ clown shoes this summer.
    mt
  46. #346
    OT - i am thinking about refinishing the totem, is that anodized or powder coated? any special prep required?
  47. #347
    uzzi totem
    hi
    totem color is genuine rock shox. powder coated
    special color for bike company, oem
    the casting is magnesium so by careful!
  48. #348
    Reputation: Pedalhead's Avatar
    Hey Hiramson, any idea what kind of weight your Uzzi is coming in at? Looks fantastic!
  49. #349
    Quote Originally Posted by Pedalhead
    There you have...
  50. #350
    Great thanks. I thought it would be fairly similar to mine (and it is). How's the CCDB?
  51. #351
    How's the CCDB?
    Sweet, veeeeery sweet, smooth... because his hidraulic work.
    Amazing shock.
    Love it.
  52. #352
    Amazing shock.
    Love it.
    Now, imagine the day when you star to use it..............properly
  53. #353
    Quote Originally Posted by sas2
    Will you teach me?
  54. #354
    Will you teach me?
    You donīt need teaching............what you need is encouraging
  55. #355
    Wow!
    I asume that... er.... mmm... will you teach me?
  56. #356
    Mine has made some changes over the past few months.
    Attached Thumbnails Attached Thumbnails Uzzi VP photo album-4369286540_af10b020a2_b.jpg
  57. #357
    My leg feels funny
    Quote Originally Posted by davet
    So did you ever get your dual ring to mount? I gave up on mine, I think I could have spaced out the guide with washers on the back and the cranks with a 1mm spacer but I decided to just run a BB mounted Stinger and save me some pain.
  58. #358
    Quote Originally Posted by liqwid
    Not yet. I smoked the Gamut on a log and bent it to to crap so I put the Stinger back on (which works perfectly) and recently put the Gamut P30 on to test it out. The P30 is a perfect fit by the way, just make sure you order the one for a 951 as it has a flush mount roller axle.
    I do have a new Gamut dual backplate, and I had a buddy mill the granny side of the dual roller back a couple of mm's, so that should solve the chainline issue. I'll put it back on next week and see how it fits.
  59. #359
    My leg feels funny
    I wish I had friends that had access to milling machines.... so many solutions to so many problems
  60. #360
    Hi guys, first of all sorry for my bad english!
    I have a question and I need your help:
    Uzzi VP frame is compatible with a 150 mm hub and cassette from 11/34 with Hammerschmidt?
    It can give some problems at the chain line since the hub (of 150 mm) moves the cassette to external?
    Thank for your help
  61. #361
    Reputation: mtnbikerx's Avatar
    Nice photo, you got some camera skills there.
    What is that chainstay protector? Smooth looking.
    Everybody dies, but not everyone lives
  62. #362
    wuss
    I quite like the look of these TI springs which are very sparse and fat. Is that Obtainium (at least comparing to crc nuke proof pics and what I find in google it seems that way)?
  63. #363
    The chainstay protector is velcro. I silences any chainslap, is light, looks good and cleans easy.
    The Ti spring is a Manitou. Keep an eye out on Ebay, they come up every once in a while. They are much lighter than anything else. Since Obtanium only makes one length of spring, in the 450 they aren't much lighter than a 400x2.75 steel spring, once you throw in the adapters. The Manitou is only 275g and requires no adapters.
  64. #364
    question for all you uzzi riders. I have a tracer that i had a 36 van on. I dont like the way it felt for freeride applications. I am looking at an uzzi and about to drop the $$ but would like to know how a 160 fork feels for FR. I understand everyones oppinions are different, but would like some imput anyway.
  65. #365
    The SRAM guy
    Reputation: bama's Avatar
    Feb 2010
    I took my new Uzzi out to southridge #4 this weekend and had a great time. First DH Race i have done since 97! This forum was a great help to me when building it up. It's not built for DH runs, more of a big-time trail bike. I ride it up and down hills. Managed a 3rd in expert, thanks to the bike.
    Photo by Mike Lord.
    http://picasaweb.google.com/CycleWor...89124281422466
    Chris Hilton
  66. #366
    Intense Uzzer
    "Managed a 3rd in expert, thanks to the bike."
    Love your style: humility, no pads, going up against all those doublecrowns....
    much respect, and I doubt it had that much to do with the bike!
  67. #367
    The SRAM guy
    Feb 2010
    I felt like a jackass in the starting line. Looked like a world cup starting line!
    Gotta get a sharpie and put my name on my jersey.
    Chris Hilton
  68. #368
    Ok. That's enough of that banter guys. Keep posting those photos of your bikes. I wan't to raise the fever before my frame arrives.
  69. #369
    wuss
    Yeah, more pics of bikes built around raw frames, I need inspirarion for my build.
  70. #370
    Updated Uzzi build
    Have been running this set-up for a few months now still luvin the uzzi hope to find a mini DH build that works just as good for the spring.
  71. #371
  72. #372
    I just wanna go fast!
    Reputation: bdamschen's Avatar
    Quote Originally Posted by wee_ry
    What fender is that out back?
  73. #373
    Intense Uzzer
    Quote Originally Posted by Captain Future
    That`s a large, yes? What`s it weigh with that 40? Nice build!
  74. #374
    Quote Originally Posted by bdamschen
    Its a modified no name plastic carbon effect mudguard, think it was originally part of a fork mounted fender couple hours with a dremmel and heatgun to modify it for the Uzzi.
  75. #375
    My leg feels funny
    Thats pretty slick, I dig it
  76. #376
    It`s a large! 17,7 kg.
  77. #377
    Dec 2008
    My Uzzi with CCDB and Fulcrum Red Zone.
  78. #378
    Dec 2005
    Here is my new Uzzi (built on the AM side). All of the parts were transfered from another bike except for the E Type derailler. Sorry for the poor quality of the photo; it was a camera phone. It looks a lot better in person!
    -Frame: Intense Uzzi Vp Works - Large
    -Fork: Fox 36 Talas RC2 1.5 '09
    -Brake: Elixir CR 203 / 160
    -Cranks: XT
    -Pedals:XTR
    -Deraillers: XT
    -Cassette: XT
    -Wheels: I9 Enduro
    -Tyres: Maxxis DHF 2.5 single ply front, Schwalbe Fat Albert 2.25 R rear
    -Saddle: WTB Devo
    -Seatpost: Thomson
    -Stem: Thomson 1.5 45mm
    -Handlebar: Race Face SIXC
    -Headset: ChrisKing 1.5
    -Handlebar grips: GA1
    -Rear QR: Salsa
    Weight: 32.75 lbs on digital bike scale
  79. #379
    Reputation: DrEVS's Avatar
    Apr 2005
    Lots of nice bikes in here.
  80. #380
    Intense Uzzer
    LOOOOOOOOOOVE IT. Love the custom paint. IT WORKS.
    Is that a large? I`m only interested in looking at larges: MORE LARGES, PLEASE!
    2010 Intense Uzzi
    2009 Wilier Izoard
  81. #381
    Reputation: nmtim's Avatar
    Oozy
  82. #382
    Intense Uzzer
    Nice bike. Nice DOG!
    My Oooooozy should be here in a few days..... Can`t frikkin wait!
    2010 Intense Uzzi
    2009 Wilier Izoard
  83. #383
    Apr 2005
    Quote Originally Posted by dopaminer
    Is that a large?
    Thanks! It's a Medium...
  84. #384
    Loving it! Mine will be pretty much the same. When it arrives....
  85. #385
    What's with the buzzilion spacers under your stem?
  86. #386
    36 talas, flush headset, runs around 67.5.
  87. #387
    wuss
    Quote Originally Posted by richiban
    What settings for the dropouts?
  88. #388
    My Uzzi medium
    Hi,
    I've just finished it of and possibly will hit the track today.
    I can't wait. Couple of photos before getting her dirty.
    Cheers,Aris
  89. #389
    Dec 2008
    Just thought I'd post some recent pictures of my bike as it's changed a bit since last time.
  90. #390
    Feb 2010
    One more for the list in medium size
  91. #391
    Dec 2008
    Man that looks fricking awesome!!! Whats it ride like with the boxxer and 7.5" rear travel?
  92. #392
    Looks awesome,congratulations.
    I have a question as well. I saw that you have a double crank set in front,how is your pedalling with the Boxxer in front?
    I was thinking the same set up as well for mine,but finally didn't dare.
    Stick with the Totem DH Coil.
  93. #393
    Feb 2010
    Quote Originally Posted by jamesl3ell
    The Uzzi is a real DH bike!!
  94. #394
    Feb 2010
    Quote Originally Posted by aris_172
    well...since I mount the Boxxer I have not pedalling, only DH
  95. #395
    Dec 2005
    I took my uzzi through its paces this weekend in Moab. Really pleased with the downhill handling, even with the DHX-A. It just ate porc rim and all the side features/drops up.
    It seems to pedal very well (pedaled soviergn and slick rock) for what it is and hides it weight well. I think the DHX-A propedal helped out alot with this. I will hold out final judgement on climbing until I crank up some real mountains and do some longer rides in colorado but I am pleased thus far. I really don't think I am giving up much climbing performance vs my Tracer with CCDB. Again, true uphill performance is yet to be tested.
    The biggest suprise was the bottom bracket height. I have not measured it but it felt appreciably lower than expected which is a positive. I just have to concentrate on managing pedal strikes on the tech climbs.
    I was running it in seven inch travel setting.
  96. #396
    My leg feels funny
    Quote Originally Posted by smithrider
    I've been getting in as many rides as I can with my Uzzi and a CCDB around the front range and am totally digging it so far. I'm love how it behaves on trails like Dakota Ridge/Belcher Hill (White Ranch)/Apex. I don't know if you've had time to hit any trails out here since it has finally thawed but my only complaint about the Uzzi in CO is I tend to hit the trails a little faster than I should
  97. #397
    Dec 2005
    I haven't yet but am really looking forward to it. I just had shoulder surgery so Moab was my first go at it. I am also excited about the new bike park in Buff Creek as well as in Golden.
    We are always looking for guys to ride with who pedal relatively slow uphill but rip it down. Give me an email if you want to hit a front range Uzzi ride sometime. I am in Highlands Ranch. (mattrsmith@hotmail.com)
  98. #398
    My leg feels funny
    Email'd
  99. #399
    Copper
    Looks much better in person: I tried my black Totem Air on the bike but for the forest slogging I do here in Maine it's overkill.
    Attached Thumbnails Attached Thumbnails Uzzi VP photo album-2010-uzzi-edit-big-1-.jpg
  100. #400
    My leg feels funny
    Quote Originally Posted by mtnbikerx
    What happened to your old one?
