Page 24 of 34 FirstFirst ... 14 20 21 22 23 24 25 26 27 28 ... LastLast
Results 576 to 600 of 831
  1. #576
    Reputation: wooyek's Avatar
    My 2010 Uzzi VP built to replace both DH and enduro bike. It's 2-in-1, so there are two setups for both types of riding:
    Enduro:
    DH:
    Unofficial Balfa Cycles website and forum
    Ibis Mojo HD / Giant Trance X / GT Karakoram
  2. #577
    wuss
    Reputation: dropadrop's Avatar
    Did you guys with hammerschmidts face the iscg tabs?
  3. #578
    Made some updates on my Uzzi ...
    Thomson Masterpiece Seatpost
    Nukeproof Warhead Bar
    Nukeproof Eleotron Flats
    Totem: Yellow coil
    Avid Elixir CR
    Mavic Crossline Wheels
    Manitou Evolver ISX6
    34 lbs
    Still love the red lady, i'd marry her if i could hrhrhr !
  4. #579
    Intense Uzzer
    Reputation: dopaminer's Avatar
    AWESOME looking rig, and great pics.
    I wouldn`t mind if your little lady gave me a little on the side......
    Great lookin` large. Mine`s raw; is that the factory red?
    2010 Intense Uzzi
    2009 Wilier Izoard
  5. #580
    making ideas into bikes
    Reputation: Modernape's Avatar
    Sub 30lb Enduro Uzzi
    This year I've been working on getting it down as light as possible for Euro enduros. This is how she's ended up.
    And reached my goal of sub 30lbs. In this set up it's 29.7lbs.
    Attached Thumbnails Attached Thumbnails Uzzi VP photo album-kingdom_uzzi2.jpg
    KingdomBike - A collective of bike junkies who make bikes to feed the habit. www.kingdombike.co.uk
  6. #581
    Quote Originally Posted by dopaminer View Post
    Yes its the original intense red !
  7. #582
    Intense Uzzer
    Sub-30, huh?
    Well that settles it - I`m getting rid of my 8 pound Dorado.
    2010 Intense Uzzi
    2009 Wilier Izoard
  8. #583
    Looks like i have given up hope on getting tge hadleys, gonna get ck instead....
  9. #584
    Aug 2010
    My contribution...just finished the build today... 37.2 lbs in freeride/bike park trim.
  10. #585
    Need rec for rims, 220lbs when geared mostly trails n am light dh at times.
    Rims will be laced with ck hubs, 20mm and 150x12, considering the following:
    Alex rims supra bh, atomlab pimplite or the lightweight spank subrosa?
    Used 729 with hope pros and sold them. Now building a new set.
    Advise pls.
    Thx!
  11. #586
    Intense Uzzer
    Gretch that`s beauty and the beast rolled into one machine....
    Right, fellas, I`m finally going to take the 180 Dorado off my Large Uzzi and put a new Float 160 on it, thereby dropping
    1 . 6 K I L O G R A M S
    off the weight of my darlin`. . .
    If anyone has a pic of a large Uzzi VP with a fox160, please post it!
    2010 Intense Uzzi
    2009 Wilier Izoard
  12. #587
    Aug 2010
    thanks... first ride today... this thing rips the chunder and is quite agile to boot. Love it.
  13. #588
    Sub-30, huh?
    and pony up some $800 for a 1650g wheelset
  14. #589
    Intense Uzzer
    OUCH! davet I had a set of i9s - the rear got destroyed by a GreatDane-sized stick. I still have`t got it rebuilt.... The spinergys I`m on now are great though, though not light.... I figure dropping 3.5 lbs off the front end should change the handling a bit !
    2010 Intense Uzzi
    2009 Wilier Izoard
  15. #590
    Nov 2008
    [QUOTE=dopaminer;8457830]
    If anyone has a pic of a large Uzzi VP with a fox160, please post it![/QUOTE']
    'nother pic of mine, few small upgrades from earlier pic. Fox float 160 on the front end.
  16. #591
    Intense Uzzer
    Whoa - that`s it! She`s a beauty. Thanks man. I was just curious what my bike will look like after the switch; now I know...
    2010 Intense Uzzi
    2009 Wilier Izoard
  17. #592
    wuss
    Any reason you're not going for the float 180? Easy to use spacers to set at the height you want and not a lot heavier.
  18. #593
    Intense Uzzer
    Coincidentally Drop I just got home from the LBS here in Tokyo. With the strong yen the 2012 Fox forks are about 20% cheaper than last year - a very pleasant suprise. They had the 180 in stock and I was surprised at 2 things: it is in fact only negligibly more expensive AND its only 300g heavier. I had gotten some bad info/misread something somewhere and thought the 180 was 2.9 kg; in fact it`s only 2.35. The 160 is 2.04 or something.... So to answer your question - I don`t know. 180 or 160 ? I thought there was a big weight difference. But as I`m thinking of going with the short positions on the G3 and rear travel, I thought the 160 made sense. More of an AM build. Now I`m confused, need to do more research.
    Any opinion Dropadrop? Anyone else? (Probably this has been discussed to death on other threads; I`ll start searching....)
    jstuhlman how about you? Why did you go for the 160 and not the 180 ?
    2010 Intense Uzzi
    2009 Wilier Izoard
  19. #594
    wuss
    When I modded my Lyrik from solo air to coil I expected the added weight would be bad, but actually I only feel it while picking the bike up, not while riding. I would imagine either fork will feel light compared to your current one?
    The 160 will feel good in the steepest G3 setting, but might cause problems if you go slacker. The 180 can me shortened to 160 if you want or kept at full length...
    I know which one I'd choose, but I don't ride the same trails etc so it's hard to say what you should go for...
  20. #595
    Nov 2008
    My fork was transferred over from my heckler . . . I've felt it to be quite well matched to the frame for my needs. I use it mostly for tooling around local trails, taking some small drops, etc., so I tend to keep the rear dropouts in the shortest position or else the steering slows down noticeably.
    The handful of times I've had it up in the mtns. on some steeps and more rugged terrain I put it in a slacker setting and felt that the fork was still able to keep up really well. I really didn't feel like it needed more suspension--the geometry of the bike was the bigger factor. So I'd consider a.) what type of terrain you'll be on most of the time and b.) what the axle to crown measurements are of each fork you're considering, as this will affect your geometry and thus the quickness of the steering and the feel of the ride.
    Just my uninformed 2 cents . . . I'm sure that a 180 would rock, esp. if you could dial it down to 140 if need be . . . but I've been happy enough with the 160 not to lust after a 180 quite yet . . .
  21. #596
    Intense Uzzer
    Thanks guys; I`m leading towards the 180.
    Pics will be up soon.
    Happy riding !
    d
    2010 Intense Uzzi
    2009 Wilier Izoard
  22. #597
    2004 intense uzzi sl
    Hi I'm new here and can't post a new thread yet, so just want to ask you guys I have 2006 trek 6500 disc and found a guy who is willing to trade with me a 2004 intense uzzi sl, my question is it a good trade for me, is the bike still worth to fix up? Thanks
  23. #598
    wuss
    Quote Originally Posted by amjp23 View Post
    You would have better luck either using the search function, or starting a dedicated thread for the question. This is about Uzzi VP's which is quite a different bike to what the Uzzi SL was.
  24. #599
    Reputation: Southbay Bomber's Avatar
    Quote Originally Posted by stepenliem View Post
    Frame: Intense Uzzi VP
    RearShock: Fox DHX 4 Coil.
    Fork: Totem soloair 180 1.5
    Brake: Magura Gustav M
    Brake: Magura Gustav-M disc brake, rear - 190mm
    Brake: Magura Disc pad set, Gustav-M - 1.2 endur pr
    Shifter: SRAM X.0 Trigger ESP 1:1 rear shifter, 9sp - right (sil)
    Shifter: Truvativ HSchmidt/X.0-Trigger front shifter, 2x - left
    Cable: Shimano Stainless
    Housing: Shimano Housing
    Crank: Truvativ HammerSchmidt FR
    BottomBracket: Truvativ HammerSchmidt FR
    Cassette: SRAM PG970 Red.
    RearDerailleur: SRAM X.O
    Chain: Shimano XTR 7701
    Rim: Azonic Outlaw RED
    Tire: Maxxis Minion-DHF UST K tire, 26 x 2.35
    Tire: Maxxis Minion-DHR UST K tire, 26 x 2.35
    Pedal: Crank brothers 5050
    Headset: Chris King 1.5 GOLD
    Stem: Transition Bikes - red
    Handlebar: Truvativ Hussefelt
    Grip: LizzardSkin, Transition Bikes end Cap - gold
    Seatpost: Thompson Elite
    Saddle: Selle Italia YUTAAK
    I just picked this rig up a few months ago and enjoyed Northstar for the first time in over seven years. I'm considering picking up a second fork for local trail riding. A 160mm Lyrik U-Turn has been offered to me. I'm looking for feedback on the fork and whether it's worth picking up or simply sticking with the Totem Air.
  25. #600
    mamadirt
    Reputation: mamadirt's Avatar
    Sep 2004
    Time for an Autumn Uzzi pic I reckon . . . another tiny one
    Welcome to the Hotel California . . .
