Results 1 to 3 of 3
    Dec 2008
    uzzi vp cross chain
    Is this normal when using a single ring set up? i have the mrp mini g chain guide.
    lurker
    Quote Originally Posted by sherwinr
    I think its normal. As long as you can pedal it. Im using mrp, but the chain guide version only. Also planning to buy a mini g. Hows the mounting? Is the tensioner hitting the linkage? Can you post some pictures?
    Dec 2008
    Quote Originally Posted by jeg74
    I got the bb mount version, I mounted mine with a 2.1mm spacer before the guide,the tensioner bolt will not hit the linkage if you will put a spacer.
