FAT BIKES
WINTER APPAREL
TRAINERS
Page 35 of 36 FirstFirst ... 25 31 32 33 34 35 36 LastLast
Results 851 to 875 of 900
  1. #851
    ah enough posts for pics
    Put on weight, up to just under 30lbs, swapped forks for both thru's so couple of new sets of wheels, swapped brakes to XT with big discs, went 10 speed
    light wheels, heavy tyres
    heavier wheels, lighter tyres
  2. #852
    My tracer with last updates. almost 4 years with me and still i love it.
    Attached Thumbnails Attached Thumbnails Tracer VP Photo Album-2012-03-16-18.39.46.jpg
  3. #853
    High in Colorado
    13,224ft
  4. #854
    Nov 2008
    Update to my Tracer VP - new wheelset and tyres
    Mavic XM719 on Hope Pro2 with Schwalbe Nobby Nic and Racing Ralph. Notcicably better pedaling compared to my old Kenda Nevegals on Spank Subrosa rims.
  5. #855
    Reputation: trojans1993's Avatar
    Good looking rig jeremy - I'm a big fan of that flat black. Do you have any room to drop to a shorter and slightly lower stem? (hard to tell but it looks like an 70-90mm on there) I noticed a marked improvement in overall handling when I went to a stiff 60mm zero degree stem with 760mm riser bars. But judging from the XL frame and post height you may need all the room you can get. At 6'2" im pushing the limits of my large T2 but find the stability benefits outweigh the initial cramped feeling. Just my $.02
  6. #856
    Nov 2008
    Thanks. Being 6'5" the riding position is good for my everyday riding, but i do feel a shorter stem for more steeper technical terrain would indeed help. I will get round to trying a shorter stem.
    Quote Originally Posted by trojans1993 View Post
  7. #857
    CTB
    CTB is offline
    Reputation: CTB's Avatar
    Ok, so maybe it isn't the best view of my bike, but I found this picture today on my GoPro and liked it a lot. Those are my buddies in front of me on our first time doing lift-assist riding in Pennsylvania.
  8. #858
    My Intense Tracer VP
    Here is my set up.. I just added the new 34 ctd fox float and the bike feels amazing! Bike weighs in at 27.5 pounds.
    Frame: Medium - Works Blue
    Fork: Fox Float CTD 34 160mm
    Shock: Fox RP23
    Headset: Chris King
    Handle Bar: Easton Haven Carbon
    Stem: Thomson X4 70mm
    Brake: Shimano XTR Trial
    Rotor: Ice Tech (7 inch front, 6 inch back)
    Crank: Raceface Sixc (double ring w/bash)
    Pedal: Loaded Flat Pedals
    Shifters: Shimano XTR
    Derailluers: Shimano XTR
    Cassette: Shimano XTR
    Saddle: Selle Italia SLR Ti
    Seatpost: Thomson Elite
    Wheelset: Easton Haven
    Tire: Schwalbe Nobby Nic 2.25
  9. #859
    Reputation: Christ D's Avatar
    Quote Originally Posted by stevevalenuela View Post
    Sweet !! How tall are you ?
  10. #860
    I'm 5'7.
  11. #861
    intense are the best looking bikes and makes unique the experience to own one of this beasts
  12. #862
    CTB
    CTB is offline
    Shock: Fox RP23
    Headset: Chris King
    Beautiful!
  13. #863
    Latest upgrades
    Tracer VP Photo Album-395492_10200335244250905_1306932991_n-1.jpgUpdated build: Replaced the RP23 and Talas with a DHX5 ti spring and a Van36. Huge difference in the ride. Also added some straitline AMPs and Atlas bars and stem and a set of Schwalbe HDs.
  14. #864
    Nice upgrades E203, i dig that matte black finish. Thinking about upgrading the RP23 on my T2 as well - how much do you suffer on the climbs going from air to spring on the TVP?
  15. #865
    Thanks, I live in FL where we ride mostly in reclaimed phosphate mines. The climbs are short and steep so I hardly notice the extra weight. The ti spring reduces the weight by about 1/2 pound. The bike is just under 31 pounds. The biggest difference was the coil in the front which now tracks much better and makes it easier to pop the front end up quickly over roots and rocks. The bike launches off of lips and wooden stunts much better with the coils on both ends. It just became a more responsive and funner ride for me.
  16. #866
    finally bit the bullet & went 1x10, cheap mrp in the chainreaction sale, mud tyres on the light wheels back down to 28.5lbs
  17. #867
    CTB
    CTB is offline
    I still love that swirl paint job. I gotta try that on something sometime.
  18. #868
    Reputation: Rojo Grande's Avatar
    Oct 2012
    I only have one ride on it but I love it! Replaced my 2001 Tracer.
    Attached Thumbnails Attached Thumbnails Tracer VP Photo Album-20130214-20130214-img_2511.jpg
  19. #869
    Looking to pick up a new old stock 2010 tracer VP in works red. My question is how dose a 150mm fork work with the 6.0 in the rear or would you run it in the 5.5 in the rear. Iím in So Cal and wanting to do some enduro racing.
  20. #870
    Dude, got any schwag?
    Reputation: TheSchwagman's Avatar
    Quote Originally Posted by motoknight View Post
    Run it either way, but for Enduro, definitely 6". What size are you looking for?
    Billy
    Speed is sweet, it's like an avenue to
    ... Shredtopia!
  21. #871
    im looking at a md
  22. #872
    moto - I ran my TVP in both 5.5" & 6.0" starting with a Fox 32 140mm then switching to a Fox 36 160mm (both TALAS). You can run it in either mode depending on the trail, the geometry works with either combination. In my experience, the 6" was more fun on the rough stuff but very tricky to eliminate pedal bob on the climbs. In 5.5" the bike is more responsive and a better climber but definitely not as plush. Do you already have the 150 fork? If not I would consider a 36 160mm for the TVP or the T2 - noticeably stiffer and more confidence inspiring than the 32 for rougher riding, but for racing with some good climbs the 32 is very capable.
  23. #873
    trojans1993 I have the 150mm and run the same trails you do. Do you feel that your T2 is a big step up over the TVP i saw it on STR. I have a wheel set that will let me run a 12mm to 10mm bolt on step down to work on th TVP to make it stiffer. Trying to way out the cost to go with the T2 over what I can get the TVP for. Im coming for a stumpy.
  24. #874
    The rear end is stiffer on the T2 compared to the TVP but I never tried it with anything other than a 9QR axle so your axles setup may help out there. Other than that, the G1 dropouts were nice because they gave me the option of converting to 650b. Other than that, I really liked my TVP and it rides very similar to the T2. If you are a bigger guy that cranks hard on the back end then a gently used T2 might be a better option. But if you found a killer deal on a TVP and you want a solid "do it all" bike the TVP is still a great option IMO. Hope it helps.
    BTW - I sold the TVP to my riding partner who is 6'1 200lbs and its still going strong and he loves it too.
  25. #875
    thx i pulled the trigger and here is my new ride.
Follow MTBR on Facebook
