Page 18 of 19 FirstFirst ... 8141516171819 LastLast
Results 851 to 900 of 904
  1. #851
    ah enough posts for pics
    Put on weight, up to just under 30lbs, swapped forks for both thru's so couple of new sets of wheels, swapped brakes to XT with big discs, went 10 speed
    light wheels, heavy tyres
    heavier wheels, lighter tyres
  2. #852
    My tracer with last updates. almost 4 years with me and still i love it.
    Attached Thumbnails Attached Thumbnails Tracer VP Photo Album-2012-03-16-18.39.46.jpg
  3. #853
    High in Colorado
    13,224ft
  4. #854
    Nov 2008
    Update to my Tracer VP - new wheelset and tyres
    Mavic XM719 on Hope Pro2 with Schwalbe Nobby Nic and Racing Ralph. Notcicably better pedaling compared to my old Kenda Nevegals on Spank Subrosa rims.
  5. #855
    Reputation: trojans1993's Avatar
    Good looking rig jeremy - I'm a big fan of that flat black. Do you have any room to drop to a shorter and slightly lower stem? (hard to tell but it looks like an 70-90mm on there) I noticed a marked improvement in overall handling when I went to a stiff 60mm zero degree stem with 760mm riser bars. But judging from the XL frame and post height you may need all the room you can get. At 6'2" im pushing the limits of my large T2 but find the stability benefits outweigh the initial cramped feeling. Just my $.02
  6. #856
    Nov 2008
    Thanks. Being 6'5" the riding position is good for my everyday riding, but i do feel a shorter stem for more steeper technical terrain would indeed help. I will get round to trying a shorter stem.
    Quote Originally Posted by trojans1993 View Post
  7. #857
    CTB
    CTB is offline
    Reputation: CTB's Avatar
    Ok, so maybe it isn't the best view of my bike, but I found this picture today on my GoPro and liked it a lot. Those are my buddies in front of me on our first time doing lift-assist riding in Pennsylvania.
  8. #858
    My Intense Tracer VP
    Here is my set up.. I just added the new 34 ctd fox float and the bike feels amazing! Bike weighs in at 27.5 pounds.
    Frame: Medium - Works Blue
    Fork: Fox Float CTD 34 160mm
    Shock: Fox RP23
    Headset: Chris King
    Handle Bar: Easton Haven Carbon
    Stem: Thomson X4 70mm
    Brake: Shimano XTR Trial
    Rotor: Ice Tech (7 inch front, 6 inch back)
    Crank: Raceface Sixc (double ring w/bash)
    Pedal: Loaded Flat Pedals
    Shifters: Shimano XTR
    Derailluers: Shimano XTR
    Cassette: Shimano XTR
    Saddle: Selle Italia SLR Ti
    Seatpost: Thomson Elite
    Wheelset: Easton Haven
    Tire: Schwalbe Nobby Nic 2.25
  9. #859
    Reputation: Christ D's Avatar
    Quote Originally Posted by stevevalenuela View Post
    Sweet !! How tall are you ?
  10. #860
    I'm 5'7.
  11. #861
    intense are the best looking bikes and makes unique the experience to own one of this beasts
  12. #862
    CTB
    CTB is offline
    Shock: Fox RP23
    Headset: Chris King
    Beautiful!
  13. #863
    Latest upgrades
    Tracer VP Photo Album-395492_10200335244250905_1306932991_n-1.jpgUpdated build: Replaced the RP23 and Talas with a DHX5 ti spring and a Van36. Huge difference in the ride. Also added some straitline AMPs and Atlas bars and stem and a set of Schwalbe HDs.
  14. #864
    Nice upgrades E203, i dig that matte black finish. Thinking about upgrading the RP23 on my T2 as well - how much do you suffer on the climbs going from air to spring on the TVP?
  15. #865
    Thanks, I live in FL where we ride mostly in reclaimed phosphate mines. The climbs are short and steep so I hardly notice the extra weight. The ti spring reduces the weight by about 1/2 pound. The bike is just under 31 pounds. The biggest difference was the coil in the front which now tracks much better and makes it easier to pop the front end up quickly over roots and rocks. The bike launches off of lips and wooden stunts much better with the coils on both ends. It just became a more responsive and funner ride for me.
  16. #866
    finally bit the bullet & went 1x10, cheap mrp in the chainreaction sale, mud tyres on the light wheels back down to 28.5lbs
  17. #867
    CTB
    CTB is offline
    I still love that swirl paint job. I gotta try that on something sometime.
  18. #868
    Reputation: Rojo Grande's Avatar
    Oct 2012
    I only have one ride on it but I love it! Replaced my 2001 Tracer.
    Attached Thumbnails Attached Thumbnails Tracer VP Photo Album-20130214-20130214-img_2511.jpg
  19. #869
    Looking to pick up a new old stock 2010 tracer VP in works red. My question is how dose a 150mm fork work with the 6.0 in the rear or would you run it in the 5.5 in the rear. Iím in So Cal and wanting to do some enduro racing.
  20. #870
    Dude, got any schwag?
    Reputation: TheSchwagman's Avatar
    Quote Originally Posted by motoknight View Post
    Run it either way, but for Enduro, definitely 6". What size are you looking for?
    Billy
    Speed is sweet, it's like an avenue to
    ... Shredtopia!
  21. #871
    im looking at a md
  22. #872
    moto - I ran my TVP in both 5.5" & 6.0" starting with a Fox 32 140mm then switching to a Fox 36 160mm (both TALAS). You can run it in either mode depending on the trail, the geometry works with either combination. In my experience, the 6" was more fun on the rough stuff but very tricky to eliminate pedal bob on the climbs. In 5.5" the bike is more responsive and a better climber but definitely not as plush. Do you already have the 150 fork? If not I would consider a 36 160mm for the TVP or the T2 - noticeably stiffer and more confidence inspiring than the 32 for rougher riding, but for racing with some good climbs the 32 is very capable.
  23. #873
    trojans1993 I have the 150mm and run the same trails you do. Do you feel that your T2 is a big step up over the TVP i saw it on STR. I have a wheel set that will let me run a 12mm to 10mm bolt on step down to work on th TVP to make it stiffer. Trying to way out the cost to go with the T2 over what I can get the TVP for. Im coming for a stumpy.
  24. #874
    The rear end is stiffer on the T2 compared to the TVP but I never tried it with anything other than a 9QR axle so your axles setup may help out there. Other than that, the G1 dropouts were nice because they gave me the option of converting to 650b. Other than that, I really liked my TVP and it rides very similar to the T2. If you are a bigger guy that cranks hard on the back end then a gently used T2 might be a better option. But if you found a killer deal on a TVP and you want a solid "do it all" bike the TVP is still a great option IMO. Hope it helps.
    BTW - I sold the TVP to my riding partner who is 6'1 200lbs and its still going strong and he loves it too.
  25. #875
    thx i pulled the trigger and here is my new ride.
  26. #876
    Nice build, I dig that black - I'm positive you will love the way it rides in just about all conditions. Have fun and get it dirty now.
  27. #877
    Reputation: awai04's Avatar
    Update to my Tracer VP: swapped my Rockshox Rev for a Fox Float 34, then added TR Schwalbe Hans Dampf 2.35" Pacestar tires, F & R. Absolutely fantastic
    It's not dirt in my apartment --it's Earth.
  28. #878
    Scallywag
    Tracer Wannabe...
    <a href="http://s1206.photobucket.com/albums/bb451/JdubKC/?action=view&amp;current=IMAG1725_zpsc7b30f06.jpg" target="_blank"><img src="http://i1206.photobucket.com/albums/bb451/JdubKC/IMAG1725_zpsc7b30f06.jpg" border="0" alt="Uploaded from the Photobucket Android App"></a>
    <a href="http://s1206.photobucket.com/albums/bb451/JdubKC/?action=view&amp;current=IMAG1724_zpsc4fc311a.jpg" target="_blank"><img src="http://i1206.photobucket.com/albums/bb451/JdubKC/IMAG1724_zpsc4fc311a.jpg" border="0" alt="Uploaded from the Photobucket Android App"></a>
    5.5 Photo Album nowhere to be found
    _______________________________________________
    08 Intense 5.5
  29. #879
    My new tracer build
    Tracer VP MD
    Fox rp23 adaptive logic rear shock
    Fox talas 36mm with the rcl and fit
    Sun ringlet charger pro wheels with the thru axel rear bolt on
    XT 785 crankset 2x10 26-38
    XT 785 brakes with ice tech rotors and ti bolts
    XT 786 shadow plus rear derailleur
    XT 785 front derailleur
    XT 785 shifters
    XT 785 Cassettes 11-36
    KS dropper post
    Easton Haven stem 65mm
    Carbon handle bars
    Crank Brothers candy 3 pedals
    Bionic chain guide
  30. #880
    Reputation: RollingRevolution's Avatar
    Oct 2011
    Spent a few months getting the parts together to build this TVP up, and I am very happy,although it turned out a little heavier than expected but I don't feel it on the trail.
    Tracer VP Large
    Marzocchi 44 RC3 Ti
    Marzocchi Roco LO
    XM819 + CK hubs
    Panaracer CG ACAM 2.35 F/R
    XTR Brakes
    XTR Drivetrain
    Syntace bar/stem/seatpost
    Chromag Trailmaster LTD saddle.
    Tracer VP Photo Album-img_2799.jpgTracer VP Photo Album-img_2800.jpgTracer VP Photo Album-img_2801.jpg
    Love it!
  31. #881
    bye bye Intense
    the chainstay crack was getting too much - FAF - flexi as **** so has been resigned to the commuter bike with slicks
    hello Norco forum
  32. #882
    Reputation: Just J's Avatar
    Feb 2005
    That is cool! Killer B?
  33. #883
    CTB
    CTB is offline
    My rig as she stands today (literally - took this picture this afternoon).
  34. #884
    Made a few changes - why did I wait 3 years to get a CCDB???? even with the wrong size spring (500lbs rather than 550) giving me almost 50% sag it rode better than the fox ever did.
    Plus the Reverb makes life easy, but it didn't like being cooked in the shed in the recent UK hot weather!! (but my friendly not-so-LBS sorted it when they fitted my DB - few!)
    Pre Leigh Woods/Ashton Court blast, some proper ridding next time to work the shock!
  35. #885
    Added race face 32 tooth narrow-wide and dropped the front derailleur! Here you can see it poking out from underneath the Bash Guide because I couldn't see fit to get rid of that.
    I've long thought about going single ring. After today's ride, I love it! I may look at getting an 11-34 cassette out back, but the narrow-wide ring does its job. No upper guide needed. Combined with the C.Guide down low the ride was as quiet as it's ever been. I kept the C. Guide on because my rear derailleur isn't the clutch-type.
    I've got red elsewhere on the bike but they were out of the red ring when I was ordering. I also got to thinking, "why does my bike need to be based solely around the very much overused black and red palette?" I think it looks great, but I may be biased.
    Attached Thumbnails Attached Thumbnails Tracer VP Photo Album-img_20130804_151633.jpg
    You guys wanna ride bikes?
  36. #886
    Here is my toy...
    Nothing fancy, but it works:
    Lyrik 170mm
    Stock RP23 (better than expected)
    XT cranks
    XT brakes
    Saint rear der. / SLX front
    Alexrims Supra w/ Muddy Mary & Ardent
    Syncros headset and saddle
    Bionicon c-guide v2
  37. #887
    Aug 2013
    New (to me) 2010 Tracer VP!
    Just finished getting her built up today, and went on my maiden ride! This is what I'll call an eBay bike. Bought the frame/shock used, then searched and found mostly take-offs and slightly used components to complete the build.
    2010 Intense Tracer VP size small, with Fox RP23 shock
    Fork 2013 Fox Talas 34 CTD 160mm
    Wheels Easton Haven UST. Front 15mm through, Rear 10x135 QR
    Tires Kenda Slant 6 2.35" non UST, running tubeless
    Headset Cane Creek 40 series
    Handle Bar Easton Monkey Lite 690mm
    Stem Thomson Elite 70mm
    Brakes Shimano XT hydraulic disk
    Rotors Shimano SLX 160mm
    Rear Derailleur SRAM XO Type 2 med cage
    Front Derailleur N/A
    Crankset SRAM XX1 32t
    Cassette SRAM XO 11-36 10sp
    Chain KSG 10sp
    Rear Shifter SRAM XO trigger
    Pedals Crank Brothers Mallet 2
    Haven't had a chance to weigh it yet, but I'm thrilled with the build so far. I think I'm going to like the 1x10 set up. It was very quiet, smooth, chain stayed on and had minimal chain slap. I did have to hike a bike but not much more than I've recently had to do on this same ride with my lightweight hardtail. Without even trying, I set my PR on the downhill section of the ride. Awesome!
    I think the first pic is a more accurate depiction of the color...
    Here's my ride: Mountain Bike Ride Profile | New Bike bike-hike near Prescott, AZ, USA | Times and Records | Strava
  38. #888
    CTB
    CTB is offline
    Looks great! I hope to upgrade to XX1 or the level below that is coming out soon on mine. 1x seems like a great choice for my area. You will set many new PR's on the downhill sections, trust me.
  39. #889
    Nov 2008
    A few updates since my last post...
  40. #890
    Jun 2005
    Is that an XL?
  41. #891
    Nov 2008
    Yes XL - from the first batch to come to the UK.
  42. #892
    Nov 2008
    Pike fitted... what a fork this is!
  43. #893
    Looking good Jeremy!
    If I ever upgrade from my Lyrik, it would be to a Pike or a new Lyrik (lighter like Fox's new 36 - if you're listening SRAM). I've been running a 1 degree angleset to slacken the bike out and I really like how it feels. Can you say how much the addition of that bottom cup slacks out the HA? Looks like you're running a large, so in stock trim I'm estimating the HA was around 68degrees...
    Love my Tracer VP and with the reduced amount of riding I get to do anymore, it's all I need. I imagine someday I may be upgrading to a 275 wheeled bike (might not have a choice), but fork will likely come first. Are you running the 275 fork or the 26?
  44. #894
    Nov 2008
    Coming from 09 36 VanR which has always been overkill for me. A great fork though. Believe the hype this thing is like butter out the box... set up air pressure as per chart on fork and your good to go.
    Mines is 26" 150mm. I just don't think upgrading to 27.5" and carbon frame will give me more fun. As much as i like the look of the BronsonC or Nomad. Mines is XL frame. As for running a few spacers thats just to get the bars a bit higher to my liking.
  45. #895
    Nov 2008
    Pike stealth graphics
  46. #896
    Looks great Jeremy! Did you get a 26" Pike or did you go with a 27.5"? Can't really tell from the axle trail in the pic. Been thinking of lightening things up with a Pike myself, but I run a Medium frame w/ a 160 Lyrik and an angleset to get it to a 66.5 degree HA. I think the additional height w/ a Pike 27.5 would mean I could forego the angleset to approximate the geometry.
  47. #897
    Feb 2015
    Anyone want to sell their tracer vp? Size medium
  48. #898
    Quote Originally Posted by worldkaoz View Post
    If you want mint large Works Red frame, I have one.
  49. #899
    Feb 2015
    Thanks, but i have a large vp already and is just a tad bit too big
  50. #900
    Reputation: techt's Avatar
    May 2014
    Tracer 275C Pro Build with Cane Creek DB in SoCal trails.
    2015 Intense Tracer 275C
    2015 Santa Cruz 5010C XT
    2015 Niner RIP 9
    2012 Specialized Camber 29
    2003 Giant Warp DS3
