Results 1 to 3 of 3
    Jul 2013
    New question here. Tracer VP offset bushings?
    Has anyone tried running offset shock bushings on the Tracer Vp? Looks like a cheap way to lower the BB and slacken HA. If so, are there any issues with frame/tyre clearances etc?
    Dan
    Reputation: DJ Giggity's Avatar
    I'd say it's questionable. You can get tire contact on the seat tube in 6" mode and a large tire as is. Also, VPP is designed to have a specific sag point. My BB was about 13.75" with a Works Component -1.5 headset and a Float 36. I was quite fond of that bike.
    Only two infinite things exist: the universe and stupidity. And, I am unsure of the universe
    - Albert Einstein
    CTB
    CTB is offline
    Reputation: CTB's Avatar
    I'm doing it right now, but not for geometric reasons. It's the only way a CCDB Air fits on a size medium TVP in 6" travel mode. Mine are clocked so that they don't change the I2I length at full compression - they space the shock down from the top tube in this position. As Giggity said, I wouldn't use offset bushings in the 6" position to slacken the bike, as mine already buzzed the front D cable running along my seat tube at full jounce as-is (Conti X-King 2.4). There are photos of my setup over in the thread I made about the CCDBA, but I don't think they're relevant to what you're asking to do.
  1. Offset Bushings.
    By rpm100 in forum Nicolai
    Last Post: 04-19-2013, 07:38 AM
  2. offset bushings
    By fua in forum Turner
    Last Post: 03-17-2013, 04:01 PM
  3. Offset bushings with DB Coil on Tracer 2?
    By JimEG in forum Intense
    Last Post: 01-28-2013, 03:19 AM
  4. M9 with offset bushings
    By dans160 in forum Intense
    Last Post: 03-21-2012, 01:07 PM
  5. offset bushings fr 575
    By Torwood in forum Yeti
    Last Post: 11-18-2011, 05:49 AM
