Tracer 2 Builds
Printable View
  • 07-26-2013
    panzer103
    https://fbcdn-photos-g-a.akamaihd.ne...47154673_n.jpg
    https://photos-a.xx.fbcdn.net/hphoto...83860302_n.jpg
    Here is my T2. I Painted it but l cannot for the life of me find any real decals so l put some red line stickers on. Personally i think it looks badass.
  • 07-27-2013
    mint355
    Tracer 2 Builds
    ^^ when the redline stickers fall off I have some huffy stickers you can put on it..... WHY.
  • 08-02-2013
    azmxr177
    4 Attachment(s)
    My new sticker...
    I put it on my T2 late last night, pics aren't great but you get the idea. Its a sticker for a 275 down tube, I cut it into two pieces so my carbon fiber guard wouldn't cover it.
    Attachment 821386Attachment 821387Attachment 821388Attachment 821389
  • 08-02-2013
    MondoRides
    Nice touch. Where did you get the Tracer 275 decals from? I haven't see T2 or T275 decals online anywhere.
  • 08-02-2013
    azmxr177
    Thanks, check your PM.
  • 08-02-2013
    rudaripu
    Just say that you are a test pilot working on a prototype for redline
  • 08-03-2013
    panzer103
    Why, you ask because i cant find any REAL T2 decals. Even on the net i cant find any. Sure, perhaps Intense has some but they are not displayed in their store and im not going to pay 50$ for them either. Just so you know the Redline decals look great and are of good quality.
  • 08-03-2013
    Sallen4520
    Tracer 2 Builds
    Just go stickerless
  • 08-05-2013
    Sallen4520
    Tracer 2 Builds
    Hey has anybody had any trouble getting there front derailleur mounted and it not lining up with the chain line on a tracer 2 ?? Seems like the mount is off about a mm on my frame its not bent as far as I can see
  • 08-05-2013
    bridgestone14
    Naw, mine went on without a problem. Make sure you have the right der, mine is an SLX 3 speed. Set up just fine. If it is an angle problem not an in and out problem you might be out of luck.
  • 08-05-2013
    Sallen4520
    Tracer 2 Builds
    If say its an angle prob. Just wondering if there was anybody that has heard of this before with a t2
  • 08-07-2013
    Sallen4520
    Tracer 2 Builds
    Intense did have a batch go out with crooked derailleurs they are swapping me front triangles.
  • 08-07-2013
    azmxr177
    Nice!!
  • 08-08-2013
    mondrakerdune
    having to sell mine its too small :cryin:
    Intense Tracer 2 frame large - Pinkbike
  • 03-13-2014
    Never Enough Toyz
    Originally Posted by thekiff View Post
    Ok, hi all, quick question...does anyone know if the new fox shocks with the LV aircan will fit on a tracer 2, instead of the more traditional XV style aircan? I know that the LV has a larger top eyelet section and wondered if this would cause fit issues?
    I found out the hard way that new LV aircan will NOT fit! I tried it in both travel settings and it contacts near the bottom of travel.
    I considered shaving the mount slightly but hate having to do that to my painted frame. Have the old RP23 on for the time being.
  • 07-26-2014
    bridgestone14
    Not sure if anyone still rides 26in wheeled bikes anymore, but thought I would post a few updates to my Tracer 2.
    Crank bros handlebar
    some new rims
    Formula oro puros
    XO ten speed drive train in silver
    cbdb air
    Next sl ten speed crank
    Hoping to get it under 30 lbs, but didn't quite make it. Might have to find a cabine frame on ebay or and ibis. I still love this bike though.
    Attachment 911065Attachment 911066
  • 07-26-2014
    andy.l
    I'm still running 26" :)
    Made a few changes to mine, now running 10 spd with clutch mech and narrow wide. Biggest change was the frame shock, after the 2nd RP23 failed at the cap threads, Intense UK kindly admitted my frame shouldn't have had that shock fitted and upgraded me with a CCDB f.o.c which was amazing on their behalf.
  • 07-30-2014
    weescott
    Been a while since I have posted here. A few changes. XTR Shadow plus RM. Spank Oozy wheelset replaces the 2010 Crossmax SX with 2012 internals. 2nd freehub failure spoke nipples coming loose, and spoke corrosion. Spank wheels seem ok quality considering they cost half as much as the Crossmax's.
    Now for a Random T2 pic:
    :D
  • 07-30-2014
    bridgestone14
    That is an awesome photo, I hope it was a great ride.
  • 11-25-2014
    andy.l
    Little sneak pic of the latest tinkering on my Tracer
  • 11-29-2014
    andy.l
    Just got all my anodised parts back. Very happy with them,assembled the bike indoors as its horrid here in UK at the moment so apologies for poor lighting of pics. Heres my Tracer2.
  • 11-29-2014
    sadevil
    Those green parts are looking mighty spiffy.
    A quick question to any T2 owners with 135x10 dropouts: has anyone had any wheel alignment issues? When I seat my quick release axle all the way down in both dropouts, the wheel doesn't sit straight in the rear triangle. I have to have a space between the axle and one dropout for the wheel to sit right. Just wondering if it's normal, bad dropouts, or a bad triangle.
  • 11-30-2014
    MondoRides
    You may just have a badly aligned/welded triangle. The rear wheel on my T2 was also a bit out of alignment. Never really affected anything but bugged me nevertheless.
  • 12-01-2014
    bridgestone14
    yeah, if it is somehow still underwarrenty, I would send the rear triangle back to get it checked out.
  • 12-01-2014
    Ridnw/bear
    Is the hub off center or the rim off center? You may need to have the rear wheel dished over so that it is centered.
  • 12-01-2014
    sadevil
    Even if the rim was off centered and needed to be dished the wheel should still sit parallel when looking at the bike from the rear.
    In my case the wheel looks slightly angled.
  • 12-05-2014
    bridgestone14
    Well hopefully you got the bike through a good store that will set you up with an RA number so you can send the rear end back to intense and have them check the alignment. I was concerned about a weld on the rear end of mine and I sent it back and they ended up building me a new one. It took a little over two months. So get this done before spring comes. It will cost you shipping is all and time without your bike. Do you have a local shop that can take a look at it for you? Are you a pretty good mechanic in your own right? If you live in northern Colorado I might be able to meet you somewhere and help.
  • 12-05-2014
    sadevil
    Thanks. But, unfortunately, I'm in NorCal and got the bike second hand. I'll just have to deal with it. It's not too bad and I can offset one side in the dropout to make the wheel set straight. I just won't be able to upgrade to the 12mm thru axle or to 650b dropouts.
    Ride it till it breaks or until I can afford something else.
    Oh, I also checked with Intense and they said it could cost up to $600 to get a new rear triangle. Not worth it considering I got the frame for only $740.
  • 02-13-2015
    capin
    Flo yellow and blue
    Hey guys
    Here is mine. size Large
    I bought the frame as an upgrade for my 08 Prophet
    Its built very light now. it has 11kg. 24.2pounds
    It feels fantastic, how agile it is, but for this season i have to sacrifice some weight for better function.
    First thing that will unfortunatelly go is the lefty.
    I love how it looks and rides, but its just 130mm and it makes front end and BB too low.
    New 160 supermax would be kickass, but its too expensive for me right now. i dont know.
    (BTW LEFTY fits large frame perfectly!! No ugly spacers..)
    another change will be rims. these are ZTR olympics. They are holding up very well actually (no truing), but they r very narrow and i have to keep tire pressure too high to avoid burping
    The last change willl be dropper post. Probably thomson.
    cheers
    jan
  • 08-22-2015
    worldkaoz
    Originally Posted by superpd150 View Post
    My new Custom Intense Tracer 2!
    2013 Intense Tracer 2 - Small - FLO Orange
    Cane Creek Double Barrel Air (XV Air Can Soon)
    Fox 34 Talas 160mm - CTD (Frustrated w/ This)
    Mavic CrossMax SX Wheelset 15mm/142x12mm
    KS Lev 125mm Seatpost (Best Seatpost to date)
    Shimano XTR M988 Trail Brakes (Not pictured) w/ White Jagwire Hoses
    (Hayes Stroker Trail Brakes were shit. On my Girlfriends bike now)
    Shimano XTR M985 Rear Deraileur
    Shimano XTR SL-M985 Shifters
    Shimano XTR Cassette 11-36T
    Shimano XTR Chain
    Shimano XT Crankset - 38T x 28T
    Shimano XT Direct Mount Front Deraileur
    MRP 2x Chain Guide (Amazing, Never dropped a chain. Ever.)
    Easton Haven Carbon Low Rise Handlebars
    Easton Haven 70mm Stem
    Specialized Henge Saddle
    HT ME03T Pedals (Best Grip-to-weight I have tried)
    Schwalabe Hans Dampf 2.3 Tubeless Tires
    I have never weighed it, but I will next time I make it into a shop.
    FOR SALE. Just kidding. Im never selling this bike.
    starts to sob....it's just soo, so...beautiful
  • 08-22-2015
    worldkaoz
    3 Attachment(s)
    Here is my new to me 2011 T2, I ride it at least 4 days a week on local singletrack here in breckenridge, co.
    Marzocchi bomber 55 RC3 Ti 160mm special limited edition purple front fork, coil with air assist, super plush, only 50 made (5.5 lbs)
    Fox rp23 w/ boost valve rear shock
    Atomlab suprelite wheels w/ pimplite hubs (4 lbs)
    Maxxis Minion dh f rear tire
    Maxxis Ignitor front tire
    Shimano SLX crank
    Shimano SLX rear derailer
    Shimano XT front derailer, drivetrain set up as 3x10
    KS lev dropper post
    Shimano hydraulic brakes
    the only things I added were the dropper post and brakes, everything else was built by previous owner.
    Attachment 1010140Attachment 1010141Attachment 1010142
  • 08-22-2015
    trojans1993
    Right on @worlkaoz, looks like a fun ride and stoked you get so much singletrack time with it. My T2 has been going strong for 3 years now and still loving it.
  • 08-22-2015
    worldkaoz
    I'm actually taking it with me to Oahu 5 1/2 weeks at the end of the summer season here in colorado, super excited to ride the trails out there
    and I stumbled upon this video, if you read the description the rider is on a tracer 2 :)
    26" is not dead!
    https://www.youtube.com/watch?v=S971OYlslfM
  • 10-09-2015
    jmacovei
    Creaking When Pedalling - Not the intense ....
    Originally Posted by gomez1 View Post
    its the bottom link bearings that i wanted to have a look at. i have the top of the rear triangle free but the bottom link bearings dont seem to move very freely.
    but while stripping everything off the frame to see if i could find the creak i noticed that all the bearings seemed rough, this can't be right for a frame only 2 months old and never had a hose or power washer used on it. not impressed.
    i went through the same with my intense 951....at the end of the day's quest, it was not the frame, it was not the pedals or BB, it was not headset, it was not what you would think.....i took the hub shell of the wheelset (easton havoc dh and greased it and the hub body that it slides into as well as well as where the cassette slides on the shell.....VOILA....creaking gone. it is usually not the frame, but its moving parts when pedalling....so if you have not serviced your rear wheel hub for a while, give that a look....
