Page 7 of 9 FirstFirst ... 3456789 LastLast
Results 301 to 350 of 439
Thread: Tracer 2 Builds
  1. #301
    I'm going to purchase a T2 frame this week but I don't know what frame size I should be getting?
    I'm 5'10" with an inseam of 32". I come from a downhill background and prefer a shorter cockpit, though I have taken 10 years off and forget everything about bike sizing
    Any help would be great! I'm thinking medium or large?
  2. #302
    Reputation: trojans1993's Avatar
    Quote Originally Posted by Jason419 View Post
    Sounds like you're right on the cusp of a M or L so you could probably make either work. Just keep in mind you probably want to run a shorter stem (~50mm) so just make sure a Medium isn't going to be too cramped, but if you like a tighter cockpit it might be just right.
    You will love the T2 - great AM rig that can be setup for almost anything.
    Good luck.
  3. #303
    Quote Originally Posted by trojans1993 View Post
    Good luck.
    Thanks for getting back to me, i almost pulled the trigger to buy it last night, then I saw the ad for the Tracer 275 on the side of the screen, tracer 275 here we come haha
  4. #304
    now I also have a ti spring and a black bash
  5. #305
    huck to flat
    Reputation: The Trail Bum's Avatar
    T-deuce kills trail!
    here's my 2012 in raw
    31.5lbs
    Tubeless
    142mm rear end
    Truvative Boo Bars 780mm
    Tompson elite x4 50mm stem
    straitline silentguide
    34t raceface chainring
  6. #306
    Reputation: andy_n's Avatar
    That would be a weapon. No drop post?
  7. #307
    huck to flat
    Quote Originally Posted by andy_n View Post
    at the moment no, but I'm planning on getting a Spec. Command Post soon!
  8. #308
    My new do it all bike. On the trail or in the bikepark - massive fun!
    Attached Thumbnails Attached Thumbnails Tracer 2 Builds-intense_tracer_2.jpg
  9. #309
    Quote Originally Posted by berlinmatte View Post
    Great looking T2. You're definitely right about that - I've ridden my T2 in a wide variety terrain and it has performed flawlessly and more fun every time - perfect do-it-all bike IMO.
  10. #310
    Oct 2012
    Hi all, new to the forums. Im looking to buy a T2 in the near future as it has been highly recommended for the type of riding I do, but have come across several threads on other forums about cracked /broken frames/rear arms Is this due to abuse/misuse or process control during mfg? Older design? I still plan on buying just wanted to know what to expect. Thanks in advance.
  11. #311
    Hey mash,
    I'm pretty sure most of the rear end issues were solved when the Tracer VP became the Tracer 2 with a much beefier rear end. I started with a TVP and now a T2 and haven't had an issue with either one. I really like the stiffer triangle of the T2 and personally have put it to the test with some pretty rough riding and the T2 always amazes me with how well it handles whatever I throw at it.
    Intense is always making improvements based on design issues and the Tracer 2 is a result of improvements from the TVP. IMO the T2 is a perfect balance of strength and weight and has been an absolutely awesome AM bike that can climb like a goat for how capable it is on the downs. Unless you are bigger 225+ guy that likes to ride really hard gnar terrain then i don't see any anticipated issues with the T2.
    Mine is paired with a Fox 36 up front, 60mm stem, and 760mm bars and it rides like a dream for AM riding.
    Post some pics once you get your bike together, would love to see it. Feel free to PM me if you have any questions regarding setup or the T2 in general - I'm pretty confident you will be very happy with your purchase once you get it on the trail. Welcome to the Intense crew (almost).
  12. #312
    Tracer 2
    Just built up my Flo Green Tracer 2. Jake and everyone at Intense have been super helpful and truly stoked about people riding their bikes! The tracer 2 kills it as an All Mountain Assault Machine! If I had more posts I would post a picture
  13. #313
    Reputation: bridgestone14's Avatar
    Mar 2005
    My race face deus is rubbing on chainstay on the drive side. Is anyone else having this problem?
    Live fast, Die young, Leave a good looking corpse!
  14. #314
    i still have the tracer vp im planing in sale it in a near future to buy the tracer 2 it looks much stiffer in the rear triangle so you can ride more agressive
  15. #315
    Race Face Deus crank on T2
    Quote Originally Posted by bridgestone14 View Post
    I'm using an older Atlas 3x9 crankset (X type interface like the Deus) and the arm clearance on the drive side was very tight. I ended up having to run two more of the white plastic spacers on the crank spindle between the spider and the bearing face to space the crank outbound a bit. Your LBS can probably supply a few of those spacers from Race Face.
    FWIW - after spacing the crank out this way I had my chain drop and jam in between my granny ring and the ISCG tabs as I run 2 x 9 with a bash and no chainguide. I ended up having to loosen off the crank arm to get the chain free. I later fabricated a little aluminum plate to fit in the gap between the granny ring and the ISCG tabs. Works a treat now and no chain drops or jams since. I'll post up a pic of the plate when I get a chance (got the idea from something I saw on a review of a Scott carbon Am bike)
  16. #316
    Mar 2005
    I have some old spacers from an xtr splined bb, I think they are about a mm or so each.
  17. #317
    Ya those XTR spacers should work, sandwiched between the rubberized race face ones. On mine there is an orange spacer inset on the spider and a black one against the bb bearing face
  18. #318
    Reputation: borodulin's Avatar
    Feb 2006
  19. #319
    Mar 2005
    Where do you ride that you need that much rock protection? Because I feel like the picture is of a forest in the midwest or the Appalachian mountains. Notoriously rock free.
    Great looking bike.
  20. #320
    Feb 2006
    A forest near Moscow, Russia, in fact ) but the bike regularly rides in the Crimean mountains, where many rocks.. Frame protection just isn't removed.
    Sorry for bad english, I hope you understand me..
  21. #321
    Feb 2006
    A final iteration: new bar, higher and wider.
  22. #322
    Mar 2005
    That is a lot better English than my Russian. Great looking bike.
  23. #323
    Feb 2006
    well.. russian language is pretty difficult ) Thank U
  24. #324
    Quote Originally Posted by borodulin View Post
    That's a perfect combination for the Tracer 2 - my bike became twice as fun after going with a wider, higher bar and shorter stem. Nice.
  25. #325
    Mar 2005
    Your crankset doesn't rub against the drive side chainstay? Mine is a slightly older version of that crankset, so maybe that is the problem. I am trying to figure out what would work and be light, but I am a little low on cash right now.
  26. #326
    Feb 2006
    No rub, they give a correct gaps. Don't remember details, but I tried to follow the instructions for installation.. maybe chainline incorrect in your case ? Сheck the spacers under bb's caps.
    Anyway, Shimano XT is better choice for quality and trouble-free cranks, if price is important, IMO
  27. #327
    Feb 2006
    Having tried finally, I completely agree with this )
  28. #328
    Reputation: Sallen4520's Avatar
    Tracer 2 Builds-imageuploadedbytapatalk1355673371.630317.jpgafter the first build and what she looks like nowTracer 2 Builds-imageuploadedbytapatalk1355673437.029621.jpg
  29. #329
    Nice Sallen - What's the gearing on your T2, kind of hard to tell just by the photo 1x10 with 11-36?
  30. #330
    Yea that's what it is. all e thirteen except the SRAM cassette I've got a rockshox monarch plus on the way
  31. #331
    Quote Originally Posted by Sallen4520 View Post
    I really like the idea of swapping my 2x9 for a 1x on the T2 but not sure if my legs could handle some of the steeper sections around here. Is that a 34t up front? Thanks - it's got me thinking.
  32. #332
    Mar 2005
    Why would you want to go to one gear in the front? Are you dropping chains that often?
  33. #333
    No dropped chains I just like the simplicity of it. Less moving parts means less chance of somthing messing up 32t ring up front lets u climb
  34. #334
    Feb 2006
    Less is more, simplicity is attractive. But steep and tricky climbs impossible with single front gear, sadly.
    Well frozen T2: http://content.foto.mail.ru/inbox/spin69/842/s-1250.jpg
  35. #335
    It's not bad Climbing tecky rocky rooty stuff and where I'm from that's 80 percent of the trails unfortunately. The bike is a lot of fun on the downs and climbs. Yea a 24 t granny would make it easier. But riding the single 32t has made me a better rider for sure.
  36. #336
    Reputation: Just J's Avatar
    Feb 2005
    Looks like such a nice bike!
  37. #337
    Am I Cheating?
    Because after the second ride on my new Tracer 275 today, it felt like I was cheating. The thing just floats downhill, begging for more speed. Think I've got the suspension dialed in pretty close now. Love the new XT Shadow Plus rear derailleur. Makes for a nice quiet ride, and doesn't seem to scratch the frame. As you can see, I'm still running my White Brothers Loop set at 150mm (which is what I used on my Ventana El Bastardo at 140mm). I'll be replacing it with an X-Fusion Slant when they come out in February sometime. I've been running X-Fusion on my 650B hardtail (Soma B-Side) for a couple of years, and they work great. I want to support them because they were hip to 650B early on, and their fork is almost a quarter pound lighter than a Fox 34. Current build comes in at 28lbs, 14oz.
  38. #338
    Sweet I like it. nice choice with the x fusion
  39. #339
    Feb 2012
    What weights are people getting these days? With an Enduro style set-up?
    (1x10, Reverb etc)
  40. #340
    Feb 2012
    Also, how are people routing their reverbs that have had them for a while? Just picke dmine up and not sure which is the best routing choice.
    Thanks.
  41. #341
    Feb 2012
    My 2012 Tracer2
    *Now fitted with a 2012 Reverb*
    Intense Medium 2012 Frame
    CCDB
    Fox Van 160mm 2012
    Hope ProII Evo with Stans ZTR Flow Rims
    Shimano Saint M820 Chainset
    Shimano Saint M820 Brakes
    Shimano Saint M820 Rear Derailleur
    Shimano Saint M820 Shifter
    Shimano Saint Cassette
    Hope 34T Chainring
    E13 LG1+ Guide
    Raceface Atlas FR Bars
    Thomson Elite Stem
    Hope Headset
    KMC SL 10 Gold Chain
    Maxxis Minions 2.5 UST
    DMR Vaults
    Don't have a weight unfortunately.
  42. #342
    Feb 2006
    Quote Originally Posted by GSuperstar View Post
    Thanks.
    Hi
    As an example, my method of routing here:
    http://content.foto.mail.ru/inbox/spin69/842/s-1034.jpg
    http://content.foto.mail.ru/inbox/spin69/842/s-993.jpg
    This worked well until I change reverb on a LEV
  43. #343
    Feb 2012
    Hi
    This worked well until I changed reverb on a LEV
    Thanks for thos epics mate.
    I think I might try running my cable exactly like yours but through the suspension link so I can use the under TT hose mounts.
    Purely as I dont want the hose getting caught in my coil.
    Will hopefully not kill anybody in attempting to bleed and cut the hose tonight
  44. #344
    Feb 2006
    As you can see, I used the reverb and ссdb together. They do not interfere with each other with these routing, so you can just try it. Before the cutting procedure etc
  45. #345
    Feb 2012
    Wow, I totally missed your 2nd picture!
    It's hard to tell, is the reverb hose run through your suspension black pivot point when used with the CCDB?
    I only run 1 x 10 so I wont have the luxury of using the little holder to keep the hose to a rear mech hose. (Thus letting the hose dangle a bit close to the spring for my liking)
  46. #346
    Feb 2006
    Routings on a both pics are equivalent. Just see the first pic for another view.
    And yes, plastic holders is the key here.
    1x10, i miss.. In your case, I would try to hold the reverb hose on the left,
    beside the rear brake line.
    damn google translate
  47. #347
    Feb 2012
    Now with Reverb :)
  48. #348
    Nice setup GS ^^ If I only could have one bike for all types of mountain riding it would be done very very similar. I like the Saint brake choice, I don't think it's overkill at all if you really like to ride the T2 hard - good job.
  49. #349
    Feb 2012
    Thank you mate!
    The Saint group set is probably the best choice I've made, the weight isn't that much I'm the grand scheme of things over XTR, but the performance is so noticeable.
  50. #350
    My Tracer 275 weighs 28lbs, 14oz., so basically, just under 29. Build includes Thomson seat post (not a dropper), and 2x10, XTR cranks, XT derailleurs.
