Page 4 of 5 FirstFirst 12345 LastLast
Results 301 to 400 of 439
Thread: Tracer 2 Builds
  1. #301
    I'm going to purchase a T2 frame this week but I don't know what frame size I should be getting?
    I'm 5'10" with an inseam of 32". I come from a downhill background and prefer a shorter cockpit, though I have taken 10 years off and forget everything about bike sizing
    Any help would be great! I'm thinking medium or large?
  2. #302
    Reputation: trojans1993's Avatar
    Quote Originally Posted by Jason419 View Post
    Sounds like you're right on the cusp of a M or L so you could probably make either work. Just keep in mind you probably want to run a shorter stem (~50mm) so just make sure a Medium isn't going to be too cramped, but if you like a tighter cockpit it might be just right.
    You will love the T2 - great AM rig that can be setup for almost anything.
    Good luck.
  3. #303
    Quote Originally Posted by trojans1993 View Post
    Good luck.
    Thanks for getting back to me, i almost pulled the trigger to buy it last night, then I saw the ad for the Tracer 275 on the side of the screen, tracer 275 here we come haha
  4. #304
    now I also have a ti spring and a black bash
  5. #305
    huck to flat
    Reputation: The Trail Bum's Avatar
    T-deuce kills trail!
    here's my 2012 in raw
    31.5lbs
    Tubeless
    142mm rear end
    Truvative Boo Bars 780mm
    Tompson elite x4 50mm stem
    straitline silentguide
    34t raceface chainring
  6. #306
    Reputation: andy_n's Avatar
    That would be a weapon. No drop post?
  7. #307
    huck to flat
    Quote Originally Posted by andy_n View Post
    at the moment no, but I'm planning on getting a Spec. Command Post soon!
  8. #308
    My new do it all bike. On the trail or in the bikepark - massive fun!
    Attached Thumbnails Attached Thumbnails Tracer 2 Builds-intense_tracer_2.jpg
  9. #309
    Quote Originally Posted by berlinmatte View Post
    Great looking T2. You're definitely right about that - I've ridden my T2 in a wide variety terrain and it has performed flawlessly and more fun every time - perfect do-it-all bike IMO.
  10. #310
    Oct 2012
    Hi all, new to the forums. Im looking to buy a T2 in the near future as it has been highly recommended for the type of riding I do, but have come across several threads on other forums about cracked /broken frames/rear arms Is this due to abuse/misuse or process control during mfg? Older design? I still plan on buying just wanted to know what to expect. Thanks in advance.
  11. #311
    Hey mash,
    I'm pretty sure most of the rear end issues were solved when the Tracer VP became the Tracer 2 with a much beefier rear end. I started with a TVP and now a T2 and haven't had an issue with either one. I really like the stiffer triangle of the T2 and personally have put it to the test with some pretty rough riding and the T2 always amazes me with how well it handles whatever I throw at it.
    Intense is always making improvements based on design issues and the Tracer 2 is a result of improvements from the TVP. IMO the T2 is a perfect balance of strength and weight and has been an absolutely awesome AM bike that can climb like a goat for how capable it is on the downs. Unless you are bigger 225+ guy that likes to ride really hard gnar terrain then i don't see any anticipated issues with the T2.
    Mine is paired with a Fox 36 up front, 60mm stem, and 760mm bars and it rides like a dream for AM riding.
    Post some pics once you get your bike together, would love to see it. Feel free to PM me if you have any questions regarding setup or the T2 in general - I'm pretty confident you will be very happy with your purchase once you get it on the trail. Welcome to the Intense crew (almost).
  12. #312
    Tracer 2
    Just built up my Flo Green Tracer 2. Jake and everyone at Intense have been super helpful and truly stoked about people riding their bikes! The tracer 2 kills it as an All Mountain Assault Machine! If I had more posts I would post a picture
  13. #313
    Reputation: bridgestone14's Avatar
    Mar 2005
    My race face deus is rubbing on chainstay on the drive side. Is anyone else having this problem?
    Live fast, Die young, Leave a good looking corpse!
  14. #314
    i still have the tracer vp i´m planing in sale it in a near future to buy the tracer 2 it looks much stiffer in the rear triangle so you can ride more agressive
  15. #315
    Race Face Deus crank on T2
    Quote Originally Posted by bridgestone14 View Post
    I'm using an older Atlas 3x9 crankset (X type interface like the Deus) and the arm clearance on the drive side was very tight. I ended up having to run two more of the white plastic spacers on the crank spindle between the spider and the bearing face to space the crank outbound a bit. Your LBS can probably supply a few of those spacers from Race Face.
    FWIW - after spacing the crank out this way I had my chain drop and jam in between my granny ring and the ISCG tabs as I run 2 x 9 with a bash and no chainguide. I ended up having to loosen off the crank arm to get the chain free. I later fabricated a little aluminum plate to fit in the gap between the granny ring and the ISCG tabs. Works a treat now and no chain drops or jams since. I'll post up a pic of the plate when I get a chance (got the idea from something I saw on a review of a Scott carbon Am bike)
  16. #316
    Mar 2005
    I have some old spacers from an xtr splined bb, I think they are about a mm or so each.
  17. #317
    Ya those XTR spacers should work, sandwiched between the rubberized race face ones. On mine there is an orange spacer inset on the spider and a black one against the bb bearing face
  18. #318
    Reputation: borodulin's Avatar
    Feb 2006
  19. #319
    Mar 2005
    Where do you ride that you need that much rock protection? Because I feel like the picture is of a forest in the midwest or the Appalachian mountains. Notoriously rock free.
    Great looking bike.
  20. #320
    Feb 2006
    A forest near Moscow, Russia, in fact ) but the bike regularly rides in the Crimean mountains, where many rocks.. Frame protection just isn't removed.
    Sorry for bad english, I hope you understand me..
  21. #321
    Feb 2006
    A final iteration: new bar, higher and wider.
  22. #322
    Mar 2005
    That is a lot better English than my Russian. Great looking bike.
  23. #323
    Feb 2006
    well.. russian language is pretty difficult ) Thank U
  24. #324
    Quote Originally Posted by borodulin View Post
    That's a perfect combination for the Tracer 2 - my bike became twice as fun after going with a wider, higher bar and shorter stem. Nice.
  25. #325
    Mar 2005
    Your crankset doesn't rub against the drive side chainstay? Mine is a slightly older version of that crankset, so maybe that is the problem. I am trying to figure out what would work and be light, but I am a little low on cash right now.
  26. #326
    Feb 2006
    No rub, they give a correct gaps. Don't remember details, but I tried to follow the instructions for installation.. maybe chainline incorrect in your case ? Сheck the spacers under bb's caps.
    Anyway, Shimano XT is better choice for quality and trouble-free cranks, if price is important, IMO
  27. #327
    Feb 2006
    Having tried finally, I completely agree with this )
  28. #328
    Reputation: Sallen4520's Avatar
    Tracer 2 Builds-imageuploadedbytapatalk1355673371.630317.jpgafter the first build and what she looks like nowTracer 2 Builds-imageuploadedbytapatalk1355673437.029621.jpg
  29. #329
    Nice Sallen - What's the gearing on your T2, kind of hard to tell just by the photo 1x10 with 11-36?
  30. #330
    Yea that's what it is. all e thirteen except the SRAM cassette I've got a rockshox monarch plus on the way
  31. #331
    Quote Originally Posted by Sallen4520 View Post
    I really like the idea of swapping my 2x9 for a 1x on the T2 but not sure if my legs could handle some of the steeper sections around here. Is that a 34t up front? Thanks - it's got me thinking.
  32. #332
    Mar 2005
    Why would you want to go to one gear in the front? Are you dropping chains that often?
  33. #333
    No dropped chains I just like the simplicity of it. Less moving parts means less chance of somthing messing up 32t ring up front lets u climb
  34. #334
    Feb 2006
    Less is more, simplicity is attractive. But steep and tricky climbs impossible with single front gear, sadly.
    Well frozen T2: http://content.foto.mail.ru/inbox/spin69/842/s-1250.jpg
  35. #335
    It's not bad Climbing tecky rocky rooty stuff and where I'm from that's 80 percent of the trails unfortunately. The bike is a lot of fun on the downs and climbs. Yea a 24 t granny would make it easier. But riding the single 32t has made me a better rider for sure.
  36. #336
    Reputation: Just J's Avatar
    Feb 2005
    Looks like such a nice bike!
    Fix foot pain, gain skills you forgot you had and have more fun whilst doing it!
    http://www.mcssl.com/app/?af=1681397
  37. #337
    Am I Cheating?
    Because after the second ride on my new Tracer 275 today, it felt like I was cheating. The thing just floats downhill, begging for more speed. Think I've got the suspension dialed in pretty close now. Love the new XT Shadow Plus rear derailleur. Makes for a nice quiet ride, and doesn't seem to scratch the frame. As you can see, I'm still running my White Brothers Loop set at 150mm (which is what I used on my Ventana El Bastardo at 140mm). I'll be replacing it with an X-Fusion Slant when they come out in February sometime. I've been running X-Fusion on my 650B hardtail (Soma B-Side) for a couple of years, and they work great. I want to support them because they were hip to 650B early on, and their fork is almost a quarter pound lighter than a Fox 34. Current build comes in at 28lbs, 14oz.
  38. #338
    Sweet I like it. nice choice with the x fusion
  39. #339
    Feb 2012
    What weights are people getting these days? With an Enduro style set-up?
    (1x10, Reverb etc)
  40. #340
    Feb 2012
    Also, how are people routing their reverbs that have had them for a while? Just picke dmine up and not sure which is the best routing choice.
    Thanks.
  41. #341
    Feb 2012
    My 2012 Tracer2
    *Now fitted with a 2012 Reverb*
    Intense Medium 2012 Frame
    CCDB
    Fox Van 160mm 2012
    Hope ProII Evo with Stans ZTR Flow Rims
    Shimano Saint M820 Chainset
    Shimano Saint M820 Brakes
    Shimano Saint M820 Rear Derailleur
    Shimano Saint M820 Shifter
    Shimano Saint Cassette
    Hope 34T Chainring
    E13 LG1+ Guide
    Raceface Atlas FR Bars
    Thomson Elite Stem
    Hope Headset
    KMC SL 10 Gold Chain
    Maxxis Minions 2.5 UST
    DMR Vaults
    Don't have a weight unfortunately.
  42. #342
    Feb 2006
    Quote Originally Posted by GSuperstar View Post
    Thanks.
    Hi
    As an example, my method of routing here:
    http://content.foto.mail.ru/inbox/spin69/842/s-1034.jpg
    http://content.foto.mail.ru/inbox/spin69/842/s-993.jpg
    This worked well until I change reverb on a LEV
  43. #343
    Feb 2012
    Hi
    This worked well until I changed reverb on a LEV
    Thanks for thos epics mate.
    I think I might try running my cable exactly like yours but through the suspension link so I can use the under TT hose mounts.
    Purely as I dont want the hose getting caught in my coil.
    Will hopefully not kill anybody in attempting to bleed and cut the hose tonight
  44. #344
    Feb 2006
    As you can see, I used the reverb and ссdb together. They do not interfere with each other with these routing, so you can just try it. Before the cutting procedure etc
  45. #345
    Feb 2012
    Wow, I totally missed your 2nd picture!
    It's hard to tell, is the reverb hose run through your suspension black pivot point when used with the CCDB?
    I only run 1 x 10 so I wont have the luxury of using the little holder to keep the hose to a rear mech hose. (Thus letting the hose dangle a bit close to the spring for my liking)
  46. #346
    Feb 2006
    Routings on a both pics are equivalent. Just see the first pic for another view.
    And yes, plastic holders is the key here.
    1x10, i miss.. In your case, I would try to hold the reverb hose on the left,
    beside the rear brake line.
    damn google translate
  47. #347
    Feb 2012
    Now with Reverb :)
  48. #348
    Nice setup GS ^^ If I only could have one bike for all types of mountain riding it would be done very very similar. I like the Saint brake choice, I don't think it's overkill at all if you really like to ride the T2 hard - good job.
  49. #349
    Feb 2012
    Thank you mate!
    The Saint group set is probably the best choice I've made, the weight isn't that much I'm the grand scheme of things over XTR, but the performance is so noticeable.
  50. #350
    My Tracer 275 weighs 28lbs, 14oz., so basically, just under 29. Build includes Thomson seat post (not a dropper), and 2x10, XTR cranks, XT derailleurs.
  51. #351
    Reputation: Duncan1104's Avatar
    Quote Originally Posted by titus247 View Post
    Nice 275! I also have a Tracer 275 and was interested in the X Fusion Slant too. I emailed X Fusion to see when it will be available. I was told that the 650b and 26" versions of this fork were different and that the 650 version wouldn't available until mid year instead of mid February for the 26" only version.
    On a side note, how do you like the White Brothers? I'm thinking about getting one since I can't get a Slant for a while. That and my Revelation is a piece of junk.
  52. #352
    Hey Duncan: Yeah, I'm sure X-Fusion is tired of taking calls on the Slant for 650B. I spoke to them last week and got the same info, June/July release. I don't know why they don't just put that info on their web-site. Since it's taking so long for them, I went ahead and pulled the trigger on a Fox 34. Should be here in another day or two.
    I like the White Brothers Loop. It's a very good fork. I've not ridden any Fox forks in the last few years, so I can't compare the two. I can only say that it works well. And, I know where you can get a good deal on one! I was planning on selling it on eBay. Let me know if you have any interest. It does have a small surface scratch on the left stanchion, but it doesn't affect the ride.
  53. #353
    Thanks for the info, Titus. Thanks for the offer too, but I think I will get one from the shop I work at.
  54. #354
    Could any tracer 2 owners please post a picture of their XL bikes if you have them, and please add your height and riding style. Thanks
  55. #355
    May 2012
    Ive defected from Ibis and gone Intense this build,freshly finished yesterday. Pedals are on other bike
  56. #356
    Mar 2011
    bike looks great. what kind of rock guard is that?
  57. #357
    May 2012
  58. #358
    Quote Originally Posted by andy.l View Post
    nice build. l or xl frame? which ibis were you on before?
  59. #359
    May 2012
    Its an XL,i had a 2008 Ibis Mojo before this
  60. #360
    How tall are you and could you give a bit more specifics regarding the build kit? (stem length, handlebar, seatpost etc.)?
  61. #361
    May 2012
    Sure,Im 6'6,havnt weighed the bike yet so unsure how heavy
    Spec:
    Frame: X-Large Tracer 2 (Works Raw) Fox RP23 shock
    Headset: Hope 1.125-1.5
    Fork: Fox Float 34 Special edition Blacks
    Bottom Bracket: Hope Ceramic
    Brake Front/Rear: Shimano XTR,Goodridge cables 203f,180r Ice rotor
    Cassette: Shimano XT 9spd 11-34
    Chain: Shimano XT
    Chainset: Shimano XTR,Renthal 32t chainring,MRP Chainguide
    Rear Mech: Shimano XTR Shadow
    Shifters: Shimano XTR 9spd
    Chain: Shimano Yumeya
    Handlebar: Easton Haven Carbon 720mm
    SeatPost: Rockshox Reverb dropper
    Stem: Easton Haven 70mm
    Seat: Specialized Toupe Ti143
    Wheel Front: Hope Pro2 Evo 15mm Maxle,Sapim CX-Ray spokes,Stans ZTR Flow Ex,Schwalbe Hans Dampf
    Wheel Rear: Hope Pro2 Evo 12 x 142 Syntace Axle,Sapim CX-Ray spokes,Stans ZTR Flow Ex,Schwalbe Hans Dampf
  62. #362
    Feb 2013
    Spec:
    Chain: Shimano XT
    Nice bike! I'm 6'5 350#, I doubt that'll work for me til I lose about 50-60 lbs huh? I'm trying to plan ahead on a FS bike after I use a HT to drop weight.
  63. #363
    AKA Mr.Habanero
    Reputation: panzer103's Avatar
    Okay, im sure this has been answered a million times already but how do you reassemble the lower link. I took my t2 apart in mid december to paint it (looks nice btw) and now l cant remember how it goes together. I took pix of the take down but my pc crashed with the info. I cant find what lm looking for anywhere. The bearings are in but where does the metal ring go in the order?
  64. #364
    Quote Originally Posted by panzer103 View Post
    I have a PDF titled "VPP Bearing Replacement" that might help. PM me your email and I'll send you all the T2 stuff I have you want it.
  65. #365
    old biker
    beautiful cockpit , borodulin !!!
    what rise is your bar ? 30 or 38 mm ?
    thank you .
    bye
  66. #366
    Mar 2013
    That rock guard is a nice idea
  67. #367
    Reputation: bullit43's Avatar
    Dec 2010
    Don´t you have problems with the chain comming of the chainring with only a upper guide??I problably going to use that set up but with a Shadow Plus derailleur.
  68. #368
    May 2012
    No not yet,took it out Friday evening for some red trails and it stayed on well
  69. #369
    Boop!
    Feb 2012
    new shoes and some other things for this season... i love this damn bike so much.
  70. #370
    Tracer 2 Builds
    Sweet! I like the skulls
  71. #371
    After riding my Tracer 2 for two years it is time for an upgrade: I bought a CCDB coil.
    What I heard so far about the performance I can't wait for the first rides.
    But I am not sure which mounting kit I do need to fit the shock into frame.
    The kit from the Fox RP23 is so tight I do not want to damage it while trying to get it off.
    So does anyone know which kit fits?
    Thanks in advance
    Matthias
    P.S.: As I am on a business trip I can not measure it by myself.
  72. #372
    Thanks to the all knowing internet and a digital caliper here are my measured datas:
    Frame:
    Intense Tracer 2 from 2011
    Shock:
    Cane Creek Double Barrel Coil from 2012 or newer (215mm x 63mm/8.5in x 2.5in)
    Shock eyelet: 24,6mm x 6mm/0.97in x 0.23in
    End eylet: 30,0mm x 6mm/1.18in x 0.23in
    So far so good. What confuses me a bit is that the measurements differ from the usual options you get from cane creek or tf tuned.
    Is this such a rare format or is that the usual variation in production?
  73. #373
    Tracer 2 Builds
    anybody have a set of tracer 2 bearings laying around they want to get rid of? Where can I get a set from any way
  74. #374
    Tracer 2 Builds
    Found bearings at fanatik bikes all makes and models
  75. #375
    Mar 2005
    Sweatypants, I was thinking that you explained somewhere how you got the skulls on your bike, but I can't seem to find it. And did you anodize the bolts yourself?
  76. #376
    Dec 2009
    Ok, hi all, quick question...does anyone know if the new fox shocks with the LV aircan will fit on a tracer 2, instead of the more traditional XV style aircan? I know that the LV has a larger top eyelet section and wondered if this would cause fit issues?
  77. #377
    Salad Days
    Reputation: jparker164's Avatar
  78. #378
    Salad Days
    Price reduced, only $1000 now!
  79. #379
    Shock Update
    Got my Tracer 2 a new shock: CCDB Coil
    Such a great performance! It's a different bike in comparison to the rp23 I rode before.
  80. #380
    Reputation: RollingRevolution's Avatar
    Oct 2011
    Love the Can-am yellow, my favourite for the T2. Great photo as well, where is that?
  81. #381
    Thanks! The pic was taken during last week when we were in Vinschgau, Italy.
    Great place to ride with good weather conditions also in april and a lot of great trails. Some of them are marked and man made others need to be found with a gps which is provided by local bikeshops including different routes.
    There is a gondola which brings biker in the morning and in the evening up the mountain.
    Additionally there are a lot of good shuttle service options.
  82. #382
    Cool-blue Rhythm Sexy in Flo Orange
    My new Custom Intense Tracer 2!
    2013 Intense Tracer 2 - Small - FLO Orange
    Cane Creek Double Barrel Air (XV Air Can Soon)
    Fox 34 Talas 160mm - CTD (Frustrated w/ This)
    Mavic CrossMax SX Wheelset 15mm/142x12mm
    KS Lev 125mm Seatpost (Best Seatpost to date)
    Shimano XTR M988 Trail Brakes (Not pictured) w/ White Jagwire Hoses
    (Hayes Stroker Trail Brakes were shit. On my Girlfriends bike now)
    Shimano XTR M985 Rear Deraileur
    Shimano XTR SL-M985 Shifters
    Shimano XTR Cassette 11-36T
    Shimano XTR Chain
    Shimano XT Crankset - 38T x 28T
    Shimano XT Direct Mount Front Deraileur
    MRP 2x Chain Guide (Amazing, Never dropped a chain. Ever.)
    Easton Haven Carbon Low Rise Handlebars
    Easton Haven 70mm Stem
    Specialized Henge Saddle
    HT ME03T Pedals (Best Grip-to-weight I have tried)
    Schwalabe Hans Dampf 2.3 Tubeless Tires
    I have never weighed it, but I will next time I make it into a shop.
    FOR SALE. Just kidding. Im never selling this bike.
  83. #383
    Boop!
    Feb 2012
    i dunno if i did. a guy i know that's been painting motorbike helmets for like 20 years did it. airbrushed em' on, a ton of clear over top with gold glitter flake in it. 3M clear in the most frequent spots. he's done like, my last 3 helmets, so i figured why the hell not. hopefully i don't throw it down a mountain too bad at any time, i guess it can always be touched up though if i did.
    most of the bolts on the bike are now gold titanium. got them from some canadian ti bolts seller. just measured them all myself and replaced with the equivalent. the gold shoulder bolts were bought that way from here:
    Intense Cycles Shoulder Bolt NCS - Fanatik Bike Co. - Bellingham Wa
  84. #384
    Mar 2005
    Awesome, thanks.
  85. #385
    GOD SPEED # 58 # 69 RIP
    Reputation: pvflyer's Avatar
    Dec 2004
    Great lookin bike....orange on white = nice. Also good work on parts picking.
    "My GREATEST FEAR is that one day I will die and my wife will sell my watches for what I told her I paid for them."
  86. #386
    Reputation: mint355's Avatar
    Mar 2012
    Tracer 2 Builds
    Hey guys here is my tracer 2
    Fox rp23
    Fox float34 ctd
    Rock shox reverb
    Xtr derailuer f&r
    Xt brakes
    Xt 2x cranks
    Xtr cassette
    Hope pro 2 evo hubs
    Dt champion spokes
    Stans flows
    Schwalbe hans dampfs evo SS
    Cane creek angle set-1
    Flexxy race face turbine 70mm stem
    Renthal fatbars cut 710mm
  87. #387
    Mar 2012
    Tracer 2 Builds
    Fox rp23
    Fox float34 ctd
    Rock shox reverb
    Xtr derailuer f&r
    Xt brakes
    Xt 2x cranks
    Xtr cassette
    Hope pro 2 evo hubs
    Dt champion spokes
    Stans flows
  88. #388
    Quote Originally Posted by mint355 View Post
    Some great looking rides ^^^ well done - hope you all dig your as much mine - fantastic do-it-all bike for sure.
  89. #389
    May 2013
    Little problem
    have anyone else problem with little rocks stucked in frame and scratching? How to solve it?Tracer 2 Builds-20130518_105816.jpgTracer 2 Builds-20130518_105836.jpg
  90. #390
    Mar 2012
    Tracer 2 Builds
    Quote Originally Posted by Alois Rössler View Post
    have anyone else problem with little rocks stucked in frame and scratching? How to solve it?Click image for larger version.
ID:	800084Click image for larger version.
    Yes it's happened to mine I was worried at first. I had a inner tube zip tied from the seat tube to chain stays worked well. But then I just learned to deal with it and accepted the grinding of rocks in thereTracer 2 Builds-imageuploadedbytapatalk1369278239.185911.jpg
  91. #391
    May 2012
    Yes mine too gets filled with mud/small stones /general trail debris,not the best of designs but just clean it out regular on long rides with a stick
  92. #392
    Feb 2006
    Guys, it's VPP design - no options here. Don't worry, take it easy )
  93. #393
    just stuff it with foam and velcro it, as I always do, eversince I had my 5.5, T1, T2, and uzzi. It'll bounce off those small rocks out in those area.
  94. #394
    Tracer 2 converted 650b/27.5
    Tracer 2 small converted 650b/27.5 @ 30lbs
    - Marzocchi 55 Ti 160mm travel
    - 650b/27.5 tubeless wheel set WTB Frequency i23 rims with Hope evo pro 2 hubs
    - 650b/27.5 Vee Rubber Mission 2.1 tubeless tires
    - SRAM XO type 2 derailleur
    - SRAM X9 2 x 10 shifters
    - MRP 2X Guide 39-42T ISCG
    - KS Lev seat post
    - Avid CR disc brakes
    - Crank Brothers Candy 3 pedals
    - Eco friendly integrated fenders (my kids father’s day gift cutout from plastic milk jug) minimizes dirt & mud buildup
  95. #395
    Dec 2004
    BOS fork
    Nice fork. have u tried any other fork so you can compare?
  96. #396
    [QUOTE=freeclimb1;10478674]Tracer 2 small converted 650b/27.5 @ 30lbs
    - KS Lev seat post
    QUOTE]
    Nice job! How do you like it so far?
  97. #397
    Tracer 2 Builds
    Quote Originally Posted by freeclimb1 View Post
    -Marzocchi 55 Ti 160mm travel
    -650b/27.5 tubeless wheel set WTB Frequency i23 rims with Hope evo pro 2 hubs
    -650b/27.5 Vee Rubber Mission 2.1 tubeless tires
    -SRAM XO type 2 derailleur
    -KS Lev seat post
    -Avid CR disc brakes
    -Crank Brothers Candy 3 pedals
    -Eco friendly integrated fenders (my kids father’s day gift cutout from plastic milk jug) minimizes dirt & mud buildup
    Awesome those are some excellent kids you havej
  98. #398
    alright guys, excuse the username! The dune cracked and was replaced with a tracer
    here's mine-
    And my solution for the getting stuff stuck in the vpp
    As i'm in the UK it's more for keeping the gritty mud out rather than stones but has worked quite well so far
  99. #399
    Hi pvflyer,
    before the BOS I had a Fox 36 Talas.
    After riding the fork on local trails, in bike parks and in the Alps for one year I can say that the BOS is performing excellent. Way better than the 36. So smooth on little bumps as well as on the heavy stuff. No matter how fast or hard you go. Plus it's lighter. No technical problems so far.
  100. #400
    Reputation: azmxr177's Avatar
    Just built up my new T2 frame, still need good pedals (Spank Spikes). Weighs 32.01 lbs. I just put a Rockguardz carbon fiber guard on the down tube (not pictured) but looks pretty good.
    Tracer 2 Builds-t9.jpgTracer 2 Builds-t7.jpgTracer 2 Builds-t8.jpgTracer 2 Builds-t5.jpgTracer 2 Builds-image.jpg
Members who have read this thread: 4
