Page 11 of 18 FirstFirst ... 7 8 9 10 11 12 13 14 15 ... LastLast
Results 251 to 275 of 434
Thread: Tracer 2 Builds
  1. #251
    The bearings you are after are these
    The new lower linkages use a 15mm axle not 12
    7902 2RS MAX
    The 7902 is a special ANGULAR CONTACT
    version of the 6902 bearing.
    It is only to be used on a hub or other component
    designed for its usage.
    DIMENSIONS .............................................. 15mm x 28mm x 7mm
    SEALS .................................................. .. Dual-lip medium/high contact
    BALL MATERIAL .................................................. .... Chromium Steel
    BALL GRADE .................................................. .............................. 10
    RACES .................................................. .................. Chromium Steel
    APPLICATION ................................. Wheel Bearing, Suspension Pivots
    GREASE ................................. Rock 'n' Roll Super-Web (in most cases)
  2. #252
    cheers buddy
  3. #253
    I make light things heavy
    Reputation: hrsjqb1's Avatar
    New Dropper post?
    Quote Originally Posted by esku View Post
    Best trail bike ever.
    @esku,
    What kind of dropper post is that you have there?
    @all,
    Beautiful bikes. This bike is the one that truly causes me to consider something other than the Mojo HD when I get the money saved. Any thoughts on the two bikes compared?
    Thanks in advance.
  4. #254
    ٩(͡๏̯͡๏)۶[$̲̅(̲̅ιοο̲̅)$]
    Reputation: MondoRides's Avatar
    KS Lev Seatpost
    Quote Originally Posted by hrsjqb1 View Post
    @esku,
    Looks like the Kind Shock Lev. Not available in the US I think until late-Spring/Summer? Give us some intel esku, where'd you get it?
    From MTBR Interbike coverage...
    KS LEV Adjustable Seatpost | MTBR Interbike Coverage
  5. #255
    Mine
    Intense Tracer 2 size M, RP23 shock
    BOS Deville forks
    2012 Formula R1 brakes
    Works components -2 angle cups
    XX Shifter
    XX Mech
    XX Casette (11-36)
    XT Cranks
    LG1+ with 34T ethirteen chainring
    KMC SL chain
    Rockshox Reverb
    Fizik Tundra 2 saddle
    Thomson 4x stem
    Renthal Fatbar (38mm rise), acros grips
    Stans ZTR flow on Hope 2, , tubeless, Specialized Eskar/Purgatory combo
    XTR Trail pedals
    darn, can't post a pic, some weird nti-spamming forum rule which requires me to have 10 posts
  6. #256
    Ideas Above My Station...
    Reputation: Orange-Goblin's Avatar
    For the record, changed my bearings all out (First upper, then lower, as upper ones didn't get rid of creak) used standard 6902 as couldn't get 7902 (Angular version). The creak instantly went and bike is running as if new again. So happy it doesn't sound like a chunk of crap considering how much it cost!!! Smooth as again!!!
    Its All Downhill From Here....!
  7. #257
    Reputation: geosnow's Avatar
    Nice. Will do as well.
  8. #258
    Boop!
    Feb 2012
    My build:
    Medium White
    20mm Front Axle, 142x12mm Shimano Rear Axle
    Rock Shox Lyrik RC2DH Fork 170mm
    Marzocchi Roco WC Air Shock
    Cane Creek Angleset .5*
    Loaded Headset Spacers
    Thomson 70mm 0* Stem
    Loaded AMXc Handlebars 710mm
    Loaded Grips
    Formula The One Brakes 200mm Front/180mm Rear
    Jagwire Hyflo Brake Lines
    SRAM X.0 Rear Derailleur Short Cage
    KCNC Ceramic Rear Derailleur Pulleys
    Jagwire Shifter Cable
    SRAM PG-990 9-Speed Cassette
    Truvativ Noir X.3 Carbon Crankset 175mm
    Loaded Pedals
    Salsa 36t Front Chainring
    MRP G2 SL Chain Guide
    Hope 36.4mm Seat Clamp
    Kind Shock i950 Seat Post
    Selle Italia Max Flite Gel Seat
    Chris King Hubs, Loaded AMX Rims, DT Steel Nipples, Titanium Spokes
    Maxxis High Roller 2.35" 60a
    **Stans Tubeless Setup
    **Custom Intense Stickers Vectorized and Re-cut By Ourselves
    31lbs.
  9. #259
    Reputation: bridgestone14's Avatar
    Mar 2005
    Wow that sounds pretty impressive, where are the pics?
    Live fast, Die young, Leave a good looking corpse!
  10. #260
    Reputation: trojans1993's Avatar
    Quote Originally Posted by Sweatypants View Post
    haha it won't let me post any. like 3 threads down in the Intense section... posted by Dynamicz.
    Try IMG code.
  11. #261
    Boop!
    Feb 2012
  12. #262
    Reputation: bike21's Avatar
    Feb 2006
    Finally got mine done! I'll have some more pics soon after I give it a bath
    Frame: Large White, rear 142x12 axle
    Fork: Fox Float 160 RLC w/ 20mm QR
    Wheels: DT 240/WTB Frequency i23 built with love by my LBS
    Bar: Race Face Atlas 740mm
    Stem: Race Face Turbine 50mm
    Brakes: Magura MT4 180mm front/160 rear
    Drivetrain: XX w/ XO front derail
    Pedals: Crank Bros
    Saddle: SDG
    Post: old Syncros for now, dropper soon!
    Tires: Kenda Nevegal UST 2.1
    Headset: Chris King
  13. #263
    Boop!
    Feb 2012
    Quote Originally Posted by trojans1993 View Post
    Try IMG code.
    forums.mtbr.com/intense/tracer-2-if-only-i-put-much-time-effort-pic-p0rn-784290.html
  14. #264
    Reputation: mtbnozpikr's Avatar
    Quote Originally Posted by bike21 View Post
    Wow, that's an impressive build. How much does it weigh?
    2012 Intense M9
    2012 Pivot Mach 5.7 Carbon
    2008 Look 595
    2007 Custom Litespeed Sewanee
  15. #265
    Pirate!!!
    Reputation: Captain Cobb's Avatar
    How do you guys keep crud out of that lower swing link? Mine gets packed with pine needles, sticks and rocks. Has anyone come up with a fender or deflector of some sort?
  16. #266
    Feb 2006
    Quote Originally Posted by mtbnozpikr View Post
    Thanks! Not sure yet, hoping to get it on a scale soon. I'm hoping I'm under the 30 range but we'll see.
  17. #267
    Reputation: mint355's Avatar
    Mar 2012
    Quote Originally Posted by Captain Cobb View Post
    I just cut up a inner tube and zip tied it to the seat tube and the lower triangle stays. Works great but dont look so great...
  18. #268
    Pirate!!!
    Quote Originally Posted by mint355 View Post
    That's about what I had figured, I was hoping someone had gotten fancy with it.
  19. #269
    AKA Mr.Habanero
    Reputation: panzer103's Avatar
    Panzers Tracer 2
    This is my T2. Its a pretty basic build but it works for me.
  20. #270
    Reputation: eurospek's Avatar
    You might want to route that front brake line inside the fork leg.
    konahonzo
  21. #271
    Mar 2005
    Ah yes, the age old question, inside or outside...
  22. #272
    Aug 2010
    Why would you route the brake cable outside?
    P.S. nice bike
  23. #273
    Feb 2006
    Quote Originally Posted by gretch View Post
    P.S. nice bike
    My old school methodology?
    I'll think about this, what is the argument for one way or the other?
  24. #274
    Fox routes the brake line between the wheel and the leg. I don't think there's any reason other than aesthetics.
    2012 Intense M9
    2008 Look 595
  25. #275
    Feb 2006
    Gotcha, looking at other pics it does look more 'clean' running through the inside. I need to shorten my front hose again anyway, so might as well make it happen.
