    Reputation: pinchflat's Avatar
    Sep 2004
    Tire rub on a '03 Uzzi when landing
    I got a used '03 Uzzi and I really love it except for a stupid problem with the tire rubbing
    against the chain stays (I think) whenever I land off any kind of jump (even a 2-foot drop will do).
    It's a 2.35'" tire (IRC Kujo) and there seem to be enough clearance (about 1/4" on each side).
    I thought maybe it's happening because I am running a regular hub with spacers instead
    of a wide 140cm hub that the frame is designed for. But it seems weird that the wheel
    would flex so much just because of the spacers.
    Also, my chaistays are in the short position (the long position seems to have less
    tire clearance).
    Any ideas?
    rain rain go away...
    Reputation: peachy-B's Avatar
    pictures?
    have u tried grabbing the wheel and forcing it side-to-side?
    I had this same issue..........intense said not to run the shock on the last hole/furthest hole down on the swing link. After setting it in the center hole the problem was resolved.
    Sep 2004
    Quote Originally Posted by tahoe-pilgrim
    That's likely it. I am using the last hole right now. Will switch to the middle one.
