Results 1 to 6 of 6
    Reputation: ~Tease~'s Avatar
    Caution;  Merge;  Workers Ahead! Suspension Parts
    Hi All,
    I ride a 2010 UZZI VP, and am having a tiny issue with my suspension - basically one of the bolts keeps coming loose which leads to some clonking, and me having to retighten it mid-ride. The cause of the problem is the fact that one of the tiny screws that holds the bolt in place is no longer there. Does anyone know where I can get these screws, or what size they are?
    Any help would be appreciated.
    Cheers,
    Dean
    Reputation: bigkat273's Avatar
    McMaster-Carr is the greatest website ever!
    IIRC they are M2? Not 100% sure...I'd say call Intense and ask just to be sure.
    Reputation: rc-architect's Avatar
    I just use the same pins I use on my flats. I find the taller pins easier to clear mud out of in order get an allen key in there. I bought a box and I might never run out...
    Black Oxide 14.9 Alloy Steel Set Screw, Hex Socket Drive, Knurled Cup Point, M4-0.70, 8 mm Length (Pack of 100): Amazon.com: Industrial & Scientific
    Reputation: iRider's Avatar
    Even if you use a set screw in there I would still clean the threads of the pivot bolt and use blue threadlock on it. I normally also put a small dip of threadlock on the set screw to not lose it.
    Thanks Everyone for your quick responses. All great advise! Will be sorted in no time!
    Lord of the Chainrings
    Reputation: Mudd's Avatar
    Apr 2002
    Quote Originally Posted by rc-architect View Post
    I'd get the stainless steel version. Alloy will rust.
    Check any hardware supply store.
    Here's who I use: BOLTS, Fasteners, Screws, Nuts, for Wood or Metal – Buy at Ababa Bolt
    "Hesitation is the Mother of Failure!"
    ~~ 951 for Dirt & Roadster for Asphalt ~~
  1. Replies: 0
    Last Post: 11-17-2012, 02:51 AM
  2. Spraying GT85 on suspension parts and fork seals
    By aizen in forum Shocks and Suspension
    Last Post: 10-22-2012, 09:07 AM
  3. Full Suspension Build from Used Parts
    By johnnymtb7 in forum All Mountain
    Last Post: 09-28-2011, 11:42 AM
  4. Replies: 1
    Last Post: 09-24-2011, 12:30 AM
  5. Replies: 0
    Last Post: 02-12-2011, 11:52 AM
