Page 1 of 2 12 LastLast
Results 1 to 25 of 49
    Dec 2005
    Spider Comp Photo Thread
    I figured it was about time to start an official Spider Comp picture thread. Here is mine to start it off. No trail time yet but feels like it is going to rip on the downhills based on the pavement tests. Thanks to Jaydn at Fanatik for hooking me up with this sweet build. I highly recommend Jaydn or Dave at Redstone if you are looking to get one.
    Large
    Fox 34 Float 130mm
    Enve AM/DT Swiss 350/Aerolite
    XT Shifters/Derailleurs/Brakes/Cassette/Chain/Pedals
    XO 22/36 Crank
    Race Face Turbine 70mm stem
    Race Face Next Flat Wide bar
    Cane Creek 110 headset
    Reverb post (non stealth)
    WTB Rocket V SLT saddle
    ODI Ruffian Grips
    Schwalbe Hans Dampf 2.35 TS Front/Spec Purgatory 2.3 rear tires (2.35 Schwalbes are a tight fit in the rear due to height, plenty of room with the specie)
    Nice beauty!. Jadyn at Fanatik Bike is a great seller, this guy knows a lot of mtb!
    Nice build, you will love it. It rolls the chunk so smooth.
    question..I was going to go with XO instead of XTR but I was told that XO double hits the chainstay so I ended up going with XTR. How close is yours? One tooth of my outer ring hits when I not in sag.
    Dec 2005
    I have plenty of room with the XO crank and chainstay. With that said, I am running the 22/36 gearing on it. The 28/42 might hit but I have no intention of running that high of gearing on a 29er with the uphill slogs we have here in CO. I intentionally did not go with Shimano so I could get the lower 2x10 gearing.
    I have to say I have had many bikes but this bike rips so much more than all the others!!!
    Attached Thumbnails Attached Thumbnails Spider Comp Photo Thread-img_2764.jpg
    Nice ride!. How many chainring has the crankset?.
    Quote Originally Posted by ANDREW WHITE View Post
    Hi just the one a 32 T
    Quote Originally Posted by stejam View Post
    Thanks. I will put a XX1 on my newest Uzzi but I donīt know if for an enduro use 32t is to hard to move!
    I think it should be fine im finding the opposite I do not have enough top end speed when flat out
    OK,
    I was about to buy one of these, based on demos, then rode another 1 more time, and was bugged by a noise that i thought was from the internal cables, shaking inside the tube.
    since these are sweet looking rides, all well built, how is the cable routing working for you?
    solid, quiet? or a bit loose and rattley?
    thx,
    Holiday
    Dec 2005
    I haven't noticed it but I haven't really ridden it over any rough trails yet as everything in co is snowed over. I am sure I can wrap the cable in thin foam wrap or use some heavy grease if I end up hearing some rattles.
    You will be fine on XX1 with a 32. I am running a 38 for Enduro racing without issues.
    Quote Originally Posted by holiday View Post
    OK,
    thx,
    Holiday
    I dont have any cable rattle because intense have been good in using a carbon inserted tubes with a inside diameter not much bigger than the outer cable or hose.
    My road bike suffers from what you describe because the cables are lose within the main frame tubing.
    I have to say I have many bikes but this bike rips so much more that all the others!!!
    Are those 158 or 168 Q cranks? Will both work?
    Bikes!
    Reputation: Just J's Avatar
    Feb 2005
    Lovely bike!
    Whats it weighing in at please?
    Beautiful bike, what size is it and how tall are you?
    Thanks.
    Quote Originally Posted by Just J View Post
    Lovely bike!
    The bike is weighing in at 26.10 lbs
    Bikes!
    Feb 2005
    Thanks, good weight!
    Good news. I thought they had just put the cable through the tube, but it has a tube. in there to control the movement.
    thx,
    holiday
    Feb 2013
    Just built this up last week. First ride Saturday and its a beauty!
    Nice.... the small looks so different, it looks long because of the difference in the top tube but obviously its not
    Come keep the posting!!!
    Had my Stumpjumper ht stuff transferred over to the Intense 29 Spider Comp. Fork is 100, wheels Am Classic Tubeless, all XT andvthe bike is sweet. 25lbs 4oz. Eggbeater SL pedals.
    Mar 2013
    Be interested in build spec? Especially handlebar and stem specs please :-)
    Mar 2013
    Absolutely stunning, gotta have one!
    Could you post the build list please?
    Large
    Revelation
    POP/Sapim Xray/ carbon AM rims
    XX1
    Hansdampfs 2,35
    26.89lbs all complete
Hot Deals
Contests
Latest Mountain Bike Articles
