Spider Comp Photo Thread
Printable View
  • 02-02-2013
    smithrider
    Attachment 767530
    I figured it was about time to start an official Spider Comp picture thread. Here is mine to start it off. No trail time yet but feels like it is going to rip on the downhills based on the pavement tests. Thanks to Jaydn at Fanatik for hooking me up with this sweet build. I highly recommend Jaydn or Dave at Redstone if you are looking to get one.
    Large
    Fox 34 Float 130mm
    Enve AM/DT Swiss 350/Aerolite
    XT Shifters/Derailleurs/Brakes/Cassette/Chain/Pedals
    XO 22/36 Crank
    Race Face Turbine 70mm stem
    Race Face Next Flat Wide bar
    Cane Creek 110 headset
    Reverb post (non stealth)
    WTB Rocket V SLT saddle
    ODI Ruffian Grips
    Schwalbe Hans Dampf 2.35 TS Front/Spec Purgatory 2.3 rear tires (2.35 Schwalbes are a tight fit in the rear due to height, plenty of room with the specie)
  • 02-02-2013
    ANDREW WHITE
    Nice beauty!. Jadyn at Fanatik Bike is a great seller, this guy knows a lot of mtb!
  • 02-04-2013
    mbernard71
    Nice build, you will love it. It rolls the chunk so smooth.
    question..I was going to go with XO instead of XTR but I was told that XO double hits the chainstay so I ended up going with XTR. How close is yours? One tooth of my outer ring hits when I not in sag.
  • 02-04-2013
    smithrider
    I have plenty of room with the XO crank and chainstay. With that said, I am running the 22/36 gearing on it. The 28/42 might hit but I have no intention of running that high of gearing on a 29er with the uphill slogs we have here in CO. I intentionally did not go with Shimano so I could get the lower 2x10 gearing.
  • 02-22-2013
    stejam
    I have to say I have had many bikes but this bike rips so much more than all the others!!!
  • 02-22-2013
    ANDREW WHITE
    Nice ride!. How many chainring has the crankset?.
  • 02-22-2013
    stejam
    Hi just the one a 32 T
  • 02-22-2013
    ANDREW WHITE
    Thanks. I will put a XX1 on my newest Uzzi but I donīt know if for an enduro use 32t is to hard to move!
  • 02-22-2013
    stejam
    I think it should be fine im finding the opposite I do not have enough top end speed when flat out
  • 02-23-2013
    holiday
    OK,
    I was about to buy one of these, based on demos, then rode another 1 more time, and was bugged by a noise that i thought was from the internal cables, shaking inside the tube.
    since these are sweet looking rides, all well built, how is the cable routing working for you?
    solid, quiet? or a bit loose and rattley?
    thx,
    Holiday
  • 02-23-2013
    smithrider
    I haven't noticed it but I haven't really ridden it over any rough trails yet as everything in co is snowed over. I am sure I can wrap the cable in thin foam wrap or use some heavy grease if I end up hearing some rattles.
  • 02-23-2013
    Salespunk
    You will be fine on XX1 with a 32. I am running a 38 for Enduro racing without issues.
  • 02-24-2013
    stejam
    Originally Posted by holiday View Post
    OK,
    thx,
    Holiday
    I dont have any cable rattle because intense have been good in using a carbon inserted tubes with a inside diameter not much bigger than the outer cable or hose.
    My road bike suffers from what you describe because the cables are lose within the main frame tubing.
  • 02-24-2013
    Salespunk
    I have to say I have many bikes but this bike rips so much more that all the others!!!
    Are those 158 or 168 Q cranks? Will both work?
  • 02-24-2013
    Just J
    Lovely bike!
    Whats it weighing in at please?
  • 02-24-2013
    Colin+M
    Beautiful bike, what size is it and how tall are you?
    Thanks.
  • 02-24-2013
    stejam
    Originally Posted by Just J View Post
    Lovely bike!
    The bike is weighing in at 26.10 lbs
  • 02-24-2013
    Just J
    Thanks, good weight!
  • 02-25-2013
    holiday
    Good news. I thought they had just put the cable through the tube, but it has a tube. in there to control the movement.
    thx,
    holiday
  • 03-26-2013
    adam199999
    Just built this up last week. First ride Saturday and its a beauty!
  • 03-26-2013
    stejam
    Nice.... the small looks so different, it looks long because of the difference in the top tube but obviously its not
    Come keep the posting!!!
  • 03-26-2013
    rakerdeal
    Had my Stumpjumper ht stuff transferred over to the Intense 29 Spider Comp. Fork is 100, wheels Am Classic Tubeless, all XT andvthe bike is sweet. 25lbs 4oz. Eggbeater SL pedals.
  • 03-28-2013
    mr_fish
    Be interested in build spec? Especially handlebar and stem specs please :-)
  • 03-28-2013
    mr_fish
    Absolutely stunning, gotta have one!
    Could you post the build list please?
  • 03-28-2013
    muggel
    Attachment 785302
    Large
    Revelation
    POP/Sapim Xray/ carbon AM rims
    XX1
    Hansdampfs 2,35
    26.89lbs all complete
  • 03-28-2013
    Colin+M
    beautiful bike. Intense nailed this one, currently loving mine.
  • 03-28-2013
    danglingmanhood
    Those are beautiful bikes guys!
  • 03-29-2013
    mr_fish
    Just ordered a Large for a build I'm 6' with long reach, could do with some advice on stem and handlebars as I want the shortest stem length I can get away with.
    So what are you lucky spider comp owners using? Flat or riser bars? What width and sweep?
    What length and angle stem are people using?
    I'm thinking of this Mcfk bar
    and this stem in 60mm
    Thoughts?
    Thanks in advance
  • 03-29-2013
    stejam
    Fox 34 TALAS 140mm Forks
    XX1 Group set
    Mavic ST 29 Wheels
    Reverb Stelth Seat post
    Fizik Gobi XM Seat
    Thomson 70mm Stem
    XTR Trail Brakes
    Easton Havoc Carbon 750mm Bars
    XTR Trail Peddles
    schwalbe nobby nic tyres tubeless
    Crisk King Head set
  • 03-29-2013
    mr_fish
    XX1 Group set
    Mavic ST 29 Wheels
    Fizik Gobi XM Seat
    Thomson 70mm Stem
    XTR Trail Brakes
    XTR Trail Peddles
    Crisk King Head set
    Thanks stejam,
    I'm trying to decide between Formula R1 and XTR trail brakes, how do you find the XTR's?
    How tall are you? I'm trying to work out what stem length I need!
    Am I right in saying the rear brake line is externally routed? Could it be internally routed at all?
  • 03-29-2013
    stejam
    Thanks stejam,
    Ive had both sets of brakes and I would go with XTR ever time.... the R1 are under powered and have no modulation to them and they fell just on or off! The XTR are unreal so much power and the control is modulated, I also now use the new style Shimano brakes on my DH bike, the only bad thing is that they pull back to much before biting but this is good for them never rubbing even when they get full of mud.
    Im 5' 10" and I normally like a short top tube and I feel the 70 is perfect for me, i tried a 50 a few weeks a go but didnt like it to much for climbing.
    The rear brake is internally routed through the front end of the frame but the external on the rear
  • 03-29-2013
    smithrider
    I am 6'1 with avg reach (longer torso but avg arms). I have the new Race Face next flat wide bar on mine. In reality, I believe it is a 1/4 inch degree rise and 8 degree sweep. Its a 720mm width. My stem is a 70mm, 6 degree rise. Feels pretty good but will probably swap it for a 60mm this summer. Not sure yet.
  • 03-29-2013
    mr_fish
    XTR Trails it is then! To be honest I only like the Formula's for the looks, not the best reason for choosing a set of stoppers :D
    I tried out a Large SA Tallboy LTc which fitted me nicely, but the Spider has a slightly longer top tube according to the geometry spec sheets. Thanks for the info, much appreciated.
  • 03-29-2013
    mr_fish
    Thanks for the info smithrider.
    I'd be interested to hear from people who have rode both the Spider 29 Comp and the Tallboy LTc as it was the LTc all the way for me until I laid eyes on a Spider frame on the wall of my LBS. Not ridden the Spider yet, waiting for them to build it up before I can demo it. As the Spider has a slightly longer top tube than the LTc I was considering getting a Med Spider.
  • 03-31-2013
    snipes1
    Im 5 11ish ordered a large, will that work with a 50mm tem
  • 03-31-2013
    Worm0898
    Bikes look sweet! I have a quick and possibly odd question but are the decals on the top tube under clear coat or can you remove them?
  • 03-31-2013
    TheSchwagman
    Under clear.
  • 03-31-2013
    muggel
    Jep this is the only thing on the Intense I do not like so much - the decals. Too many too big and no other choice.. however having a dream of a ride I can live with that - would love to see custom painting - or just a boring matte black white theme..
  • 03-31-2013
    Worm0898
    Yeah that is the only thing I am not taken by on this frame. For me if you are spending this much I want a custom paint option Intense, Santa Cruz, Yeti, Ibis take note! :-)
  • 03-31-2013
    snipes1
    Mr fish did u get a large or med being that ur 6ft
  • 03-31-2013
    snipes1
    So I think I'm gonna sale the large I just bought and get a medium any one interested 2300 and uninstalled headset
  • 03-31-2013
    confused
    How about some ride reports/comparisons on this bike, not much info out there yet!
  • 04-01-2013
    mr_fish
    +1 for boring matte black instead of too many gaudy gold graphics! Although didn't stop me from ordering one!!
  • 04-01-2013
    mr_fish
    ordered a Large in the end, not arrived yet though so don't know how well it fits!
  • 04-02-2013
    squealer
    My build:
    1 x 10 Xtr Group (with shadow + XT rear mech because that's what i already had)
    Hope press fit BB
    RS Sid XX 120mm solo air
    Roval Control SL carbon wheels, 15mm front, 142 rear
    100mm Reverb
    Fizik Gobi
    Ritchey C260 stem 60mm
    Crank bros cobalt 11 720mm carbon bar
    Xtr M985 race brakes
    XTR pedals
    nobby nic 2.25
    KMC SL gold chain
    Hope headset
    Weighed at my local shop at 26.1lbs with pedals and tubes in the tyres.
  • 04-25-2013
    stejam
    New Wheels
    Attachment 793808
  • 04-28-2013
    Ethan F
    Had to post review!
    Not one to post reviews of bikes, but this one is just to damn fun.
    Had the SCTBLTc in medium, just too big for me at 5'6". This is a small and not only does it fit better, but rides circles around it!
    It's a all about geometry! this bikes is superior in corners and switchbacks as well as all around a far easier bike to handle. The 17.5 chainstays and 67d H/A make it able to do anything you throw at it.
    The key is not to use the Fox 140, go X-Fusion Trance all the way. It has a 15mm shorter axle to crown measurement compared to the Fox still at 140mm travel. This sets the bike up to perfection and not Fox!
    Same on the Rear, the RS Monarch Plus greatly help the tunability, while the piggyback version does eliminate the h20 btl, going the standard Monarch and will be the way to go.
    I'm not a big fan of the VPP, but this big had less pedal feedback than the SCLT, very noticeable to me. Just a really fun, doesn't feel like big wheels, bike!
    Small Spider
    X-Fusion Trace 140mm (soon to be black)
    RS Monarch Plus
    Enve Am
    Sram XO trail
    WTB Weir-wolves 2.3 (new version)
    Bionicon C-Guide (do not do Sram Type 2, it will knock from chain pull)
    About 27.5lb but who's counting!
  • 04-28-2013
    smithrider
    Good looking bike Ethan. I hear ya on keeping the axle to crown height in check on the fork. I went the route of getting a fox 34 float and lowering it to 130mm to accomplish something similiar to yours. However, I think the one advantage the 34 has right now over other 29er forks is the 51mm offset which really helps the handling on slacker 29ers. I may be off 10mm in travel, but it has a lower axle to crown height and a good offset.
    Enjoy the ride! Looks great.
  • 05-01-2013
    stejam
    If your using a standard 140 travel for not a fox 34 then your head angle won't be 67 deg more like 68 deg
  • 06-06-2013
    JDaugherty
    Finally got my new frame after a 9 week wait.
    Attachment 805838
  • 06-17-2013
    prealps
    my ne spidey
    Attachment 808814
    My new spidey, xx1, fox float lowered to 125, enve am tune king kong, thomson, reverb stealth, fizik goby xm braided, hope race, bontrager xr2. 25,55 lb
  • 06-17-2013
    pyrofighting
    4 Attachment(s)
    My new Spider
    Just got my new Intense Spider Comp last week, got two rides and love it!
    Intense Spider Comp Large with Gold Links and Drop Outs
    XX1
    2014 Fox 34 140mm Fork
    Formula T1 Brakes
    I9 24 Spoke Torch Wheels
    Schwalbe Hams Dampf and Nobby Nic Tires
    Reverb Stealth 125mm Dropper Post
    All the gold parts we could find!
    27llbs
    Attachment 808881Attachment 808882Attachment 808883Attachment 808884
  • 06-17-2013
    smithrider
    Two great looking bikes! Still loving mine. My Uzzi and Big Top seem to be collecting dust these days.
  • 06-18-2013
    Captain Cobb
    Any long term ride reports? Your previous review was quite nice.
  • 06-18-2013
    Ethan F
    Have tons of rides, just a couple notes: check rear upper linkage bolts, mine loosened up several times before i nipped with new blue locktite. Watch for the Hans Dampf ripping rocks in the bottom chain stay lug! And i have found for a 140lb rider a super low compression shock to work best, IMO! But damn fun bike!
  • 06-18-2013
    mr_fish
    Another one....
    Thought I'd throw my 10 pence in.....
    Attachment 809089
    Fork: Fox Talas 34 140mm
    Wheels - Front: Chinese Carbon with Hope EVO Hubs
    - Rear: ZTR Crest & Tune Kong
    Groupset:XX1
    Bars & Stem: Thomson
    Seat Post: Reverb Stealth
    Saddle: Mcfk Carbon
    Brakes: XTR Trail
    BB: Hope
    Headset: Chris King
    Weight: 11.3kg - 24.9lb (in lightest trim i.e. ZTR & Tune wheelset F&R)
  • 06-18-2013
    smithrider
    My opinion really hasn't changed. Fortunately, I haven't had the linkage loosening Ethan reference below or any serious issues with the frame. I do have a few scratches on it that have made me pucker, but I think its just getting comfortable with the damage a carbon frame can bear - more of a personal issue than anything.
    I had the occassion to spin a Niner again a few weekends ago and the contrast between how the bikes handle is quite pronounced. This Spider really does do a fine job of combing more of an aggressive 26 inch bike feel with the 29er rollover benefits. This thing jumps, wheelies and flies down the mountain with the best of them. The three compromises on this frame are 1) you do have to muscle it around tighter corners (its not too bad though and actually find it engaging and enjoyable to a certain extent), 2) manualing has gotten better as I have adapted but it still isn't as intuitive as a short chain stay 26er and 3) it isn't going to handle big drops given its limited travel, but that isn't really what it is designed for.
    It is a heck of a fun and fast bike and one I will be holding onto for the next four years or so. I highly recommend it as long as you don't need to huck it off huge drops or are on the shorter end of the spectrum.
  • 06-18-2013
    smithrider
    Sorry to sound ignorant, but what is the bottom chain stay lug? I want to make sure I keep an eye on it, whatever it is. Thanks!
  • 06-18-2013
    Captain Cobb
    Thanks for that smithrider, I should have mine built up by the first of next week. I'm really looking forward to it. Coming from a Tracer29, should be an interesting comparison.
  • 06-21-2013
    vice grips
    XX1
    Formula T1 Brakes
    27llbs
    I had a black and gold v10 and never really fell in love with the looks. But, man your bike look sweet. Very PIMP!
    After reading smithriders review and now seeing your bike really makes me want one more.
  • 06-21-2013
    vice grips
    Got any pics of the damage?
    My wife on her 2nd ride of her new carbine put three or four digs in the chain stay, I have to stop looking at it, it's making me sick to my stomach.
    I'm glad I'm not riding it. :)
  • 06-21-2013
    smithrider
    Here are two pictures for you. I have more. The only thing that made my stomach turn was there is no reason for these areas to be scratched to my recolection (ie no crashes, no improper transport, hard rock strikes yet on downtube etc). I took it to my LBS and they tapped all around on it (scientific, right?) and said its good. It was in my head for a moment or two but all's good now. I have not really heard any Intense carbon breakage stories. They seem to have done very well so far.
    That said, I have added a heavy dose of helicopter tape to the downtube for further protection against any rock strikes.
    Intense has been fantastic with customer service in the past so I have no worries there either incase something ever does go wrong. All's well and I am a happy Spider ownerAttachment 809803!
  • 06-21-2013
    smithrider
    Attachment 809810
  • 06-29-2013
    Captain Cobb
    Good job Intense!
    I transferred most the parts from my Tracer29. I've only put two rides on it, and I'm impressed! I'll elaborate more once I've put a little more time in the saddle. Attachment 812021Attachment 812022
  • 06-30-2013
    yoterryh
    Me too!
  • 07-01-2013
    Captain Cobb
    Don't know if this helps, but here's a picture of that area.. Sexy curves eh
    Attachment 812608
    Attachment 812609
  • 07-02-2013
    cebv84
    besides the nice setup of all spider comp posted, those owners of a very nice bike, what they can told us about riding feelings? climbing, descent, drops, pedal bob, cornering. i'm very interested in this bike!!
  • 07-02-2013
    Captain Cobb
    Smithrider did a great review, here. http://forums.mtbr.com/intense/spide...ew-849638.html
  • 01-28-2015
    biketavioumaximus
    nice bikes?
  • 02-14-2015
    twistedlizard720
    4 Attachment(s)
    My 2013 after it was purchased.
    Attachment 964455
    Sarah Park, Lake Havasu, AZ
    Attachment 964456
    I converted to a 1x10 rather early on. Photo taken at Dash Point State Park, Seattle.
    Attachment 964459
    And this one Tiger Mountain with my Best Bud's '99 M1.
    Attachment 964460
    Since then I have added a dropper post, which has failed already, and a new saddle.
    Otherwise, this is the best bike I have owned to date and it's light enough for XC duty, but stout enough for light park riding. I've had the opportunity to ride in multiple states from PNW to Desert SW and the bike just rips it all. Love this bike!
  • 02-15-2015
    biketavioumaximus
    6 Attachment(s)
    My Contribution
    My Contribution;
    Hi there, this is my latest build. It is the 2013 Spider comp.
    Specs;
    Frame: large set at 130mm
    Fork: Pike RCT3 150mm
    Cranks: RaceFace cinch 30t front
    Brakes: XT
    Drivetrain: XT 10 speed 11/42 cassette
    Bars/Stem:RaceFace 750mm/50mm
    Post: Reverb 125mm
    Saddle: Fizik Gobi carbon rails
    Wheelset: Stand crest with XT hubs
    Tyres: F/R Maxxis Ardent 2.4s
    Pedals: Generic SPD?
    Weight: 13kg neat, with pedals
    It took me a few rides to get used to the big wheels but they are growing on me!!!
    Attachment 964489
    The unboxing is always exciting! ;)
    Attachment 964483
    Attachment 964484
    Shazam....
    Attachment 964485
    And so the build commences
    Attachment 964486
    First shake down of finished build
    Attachment 964487
    Fork stickers removed (replaced with pimpage) enduro fender added
    Attachment 964488
    In it's natural environment.
  • 08-31-2015
    jtforester
    Hi everyone,
    I'm building a Large Spider Comp as my all around trail bike in the northeast. I'll be lowering a Pike for the front. I have both the 130mm and 140mm air shafts. Is there any noticeable disadvantage with going with the 140mm vs. 130mm?
    Have a DB Inline on the back. I climb for the downhills but also appreciate an efficient climber that can keep a line. Thanks!
  • 08-31-2015
    slcpunk
    Originally Posted by jtforester View Post
    Hi everyone,
    I have 140 in front. Climb for the downs too. I wouldn't have it any other way. If it's really long and smooth I will activate the climb mode on the fork - but only so I can stand up. It works best in descend mode, just like the rear shock, I think.
  • 09-01-2015
    biketavioumaximus
    If you end using the 140mm is your 130mm air shaft for sale?
  • 09-01-2015
    jtforester
    It may be but it could be a while before I get enough ride time to make a decision (new born baby in the house).
  • 10-28-2015
    jtforester
    Finally got my Spider 29c built up. Got two rides on it. So far, I'm liking what it delivers.
    Sent from my VS980 4G using Tapatalk
  • 10-28-2015
    jtforester
  • 02-05-2016
    jtforester
    Anyone try to put 27.5+ tire on the back? What was the outcome?
  • 02-07-2016
    biketavioumaximus
    Anyone try to put 27.5+ tire on the back? What was the Outcome lk
    A2.4 ardent is probs the largest I'd run back to there. I imagine a 2.8 won't fit.....id like to try it but don't want to drop coin for an experiment.
  • 02-11-2016
    jtforester
    2.4 29er or 2.4 275?
  • 02-11-2016
    biketavioumaximus
    Oops, yeah 29er 2.4. What is the actual width of a 27.5 2.8? I''d imagine it's at least 10-15mm wider?
