Results 1 to 3 of 3
    Spider Comp max rear tire size?
    Does anyone know that largest rear tire that can be run on the Spider Comp? I'm planning to run a Light-Bike 35-25mm rim and Maxxis Icon 2.35 or Ardent 2.4. Thanks!!!
    Reputation: Ufdah's Avatar
    Sep 2012
    On the back of mine I have an Ardent 2.4 on a Wide Lightening rim that has 29.3mm internal width and there is plenty of room! It looks to me that 2.5's would even be ok.
    I have a pair of 2.35 Ikon's on Chinese 35mm rims w/ the titanium wire in the hook (from xmiplay) and they measure out to nearly identical width as the above ardent setup.
    I am thinking of going wide and currently I am looking at the Ibis 941 wheelset. The wheelset has a 35mm internal and 41mm external. Do you think this the bike will have enough tire clearance without rubbing on the chainstays?
  1. 2013 Stumpjumper Comp HT Max Tire Size?
    By Chris Smith in forum 29er Bikes
    Last Post: 05-07-2013, 01:56 AM
  2. Spider Comp Tire Clearance
    By smithrider in forum Intense
    Last Post: 03-01-2013, 06:26 AM
  3. Max tire size on the 2012 Camber Comp?
    By ja001son in forum Specialized
    Last Post: 10-30-2012, 04:18 AM
  4. Front tire and rear tire size comparison question help?
    By Yellowr6 in forum General Discussion
    Last Post: 02-21-2012, 05:50 PM
  5. Rear Tire Intense Spider 29?
    By SteveCompfs in forum 29er Bikes
    Last Post: 04-01-2011, 10:24 AM
