Page 2 of 2 FirstFirst 1 2
Results 26 to 34 of 34
Thread: Spider Comp
  1. #26
    Dec 2005
    Tough to give you a definitive answer as sizing is personal. Take a look at your current bike's top tube to give you an idea of where you should be.
    If you held a gun to my head and said guess, it sounds like you would run a medium with a shorter stem.
  2. #27
    Quote Originally Posted by smithrider View Post
    Thats the problem ive always ridden mediums with around a 23" top tube but 29r comp has a 23." and the small is 22.5", this may be different due to been a 29r but im not sure because ive only ever rode 26"
    What length stem are you riding and how tall are you?
    Quote Originally Posted by stejam View Post
    Could someone tell me what they think of the sizing of the 29 comp because they are only making three sizes and the top tube at 23.5" is long
    Im 5'9" and wounding if I should order a small or medium?
    I am 5'8" and I went with the 70mm stem. I think a small would just be to cramped for me.
    What bike are riding now and what size stem?
  4. #29
    Quote Originally Posted by cdsdad View Post
    [ATTACH]Attachment 751641[/ATTACH]
    These are my two ladies.
    Hi
    Ive had a carbine and i was not so impressed so could you tell me what you think is better about the Spider 29 comp
    Reputation: u0104940's Avatar
    Dec 2012
    What BB are you using with your RF Next cranks?
    When in doubt... Pedal it out.
  6. #31
    For the longer travel position should the shock be in the lower holes? Thanks.
  7. #32
    Reputation: Colin+M's Avatar
    upper mount holes I believe.
  8. #33
    Here are some pics of the finished product.(almost)
    I will post a longer review after I get a couple more rides in. I put about 65 miles on it so far and I want to make sure my opinions aren't clouded by "new bike syndrome".
    Are LBS tech is getting the new Scott 700 SL so we plan on doing a little back to back test and see what each other thinks about the others rides.
    I will say this about the Spider Comp though. This thing climbs the steep technical stuff like a scalded ape.
    Attached Thumbnails Attached Thumbnails Spider Comp-san-felasco-2013-006.jpg
  9. #34
    Dec 2005
    Quote Originally Posted by ccwaskier View Post
    Upper hole!
