Results 1 to 79 of 79
    Reputation: mr intense's Avatar
    Spider 2 proto sneek peek
    Prototype "Spider 2" that will fit between the Spider FRO & Tracer vp in the line up, basically replaces the old Spider that was dropped.
    4.5" to 5" adjustable travel @ somewhere around 5.5 to 5.75 lb frame weight.
    2nd gen VPP & AC bearings w/ zerks same as on Tracer vp.
    120 / 130mm fork range with 70 degree HA & 13" bb.
    Intense sm, med ,large,XL sizing.
    Reputation: dvo1's Avatar
    Is it me, or does it have a tall stand over and short TT.
    very very nice .. needs to be a different color but it is sweet
    Feb 2005
    Will the Spider FRO have the 2nd gen vpp or is that staying the same?
    Reputation: esquire's Avatar
    Quote Originally Posted by saga
    Thats Generation 2.
    Lots of good additions and fixes going into this bike.
    Ole
    Ole is offline
    Quote Originally Posted by esquire
    Thats Generation 2.
    I believe the question was about the Spider FRO, not the Spider 2.
    Ole.
    ready for it now
    ready to order. I've been holding out for a new spider for a while.....
    I see that now...
    Quote Originally Posted by Ole
    Ole.
    I stand corrected. I have no idea on the Fro...
    Reputation: tacoma's Avatar
    No place to carry a water bottle on Spider 2 ?
    there will be water bottle bosses
    thats just a prototype to test full length cable housing as an option. I believe the next proto will have std xc routing and water btl bosses based on consumer feedback
    hopefully the bottle bosses will be on the topside of the down tube under the shock; not too many people will use a bottle if it is on the underside
    Feb 2005
    You will fit a bottle in that gap but taking it out on the move looks like it might be a squeeze
    i am curious about the same thing.
    You have to correct the position of the shock.
    I think the bike will look better when the shock is prallel to the toptube and the seat stays.
    that would hugely affect the compression curve, especially since it's travel adjust. Most likely it has to be that way even if it is a proto.
    Recovering
    Reputation: jbogner's Avatar
    Quote Originally Posted by woogie11
    Yep. Looks like the shock is parallel when mounted in the higher position on the swing link.
    Former New Yorker, now in Fort Collins
    http://www.nycmtb.com
    Just finished P3 should be out on the trail in a day or two. This one should be dialed!
    A crunchy treat
    Will the top tube/headtube junction be hydroformed (or whatever it is) like on the Tracer/new Uzzi?
    The Spider 2 will use our proprietory Spider Easton tube set as we are trying to keep the cost down on this frame. This has been one of our most reliable tube sets to date.
    Double butted EA 6X .
    Botox User
    I would hang that proto over my fireplace
    09 Tracer VP - "wtf, am I hovering?"
    curious
    S, me again... drooling. I've had the good fortune to have ridden a 5.5 FRO and spider XVP. This to me looks like a 5.5 FRO with VPP2
    are you looking for a pure xc ride characteristic or more relaxed? I'm thinking 120 mated to 4.5"=spider XC, 5" mated to 130 up front more 5.5 FROsh?
    I cant wait to order one in works red. Thanks for giving us an insight into the process.
    Quote Originally Posted by velez3000
    The Spider 2 fills the gap between the Spider FRO & the Tracer vp
    Nov 2006
    Quote Originally Posted by mr intense
    You might want to lay off the Patron until you finish getting it fully welded.
    Reputation: Stumpy_Steve's Avatar
    so this is the bad boy replacing the 5.5? looks good, expect since its build for a 120 fork, and the new tracer for 150/160, the 5.5 that filled the suspension/geo gap is gone?
    Quote Originally Posted by Stumpy_Steve
    The Tracer is designed for 140 to 160mm forks & the Spider 2 for 120 to 130mm forks & Spider FRO 80 to 100mm.
    The proto in the picture has a 130 Manitou on it HA is 69.5.
    [QUOTE=mr intense]The Spider 2 fills the gap between the Spider FRO & the Tracer vp[/QUOT
    Sounds pretty freaking perfect, Thanks again
    Reputation: rickthewelder's Avatar
    Quote Originally Posted by Stahr_Nut
    The Patron is for cleaning the frame before the welding.
    RTW.
    Answer to post #4 is missing!
    Will the Spider FRO have been updated to 2nd gen vpp or is it staying the same?
    Ole
    Ole is offline
    It would require a complete re-design of the frame, so my guess is the Spider FRO stays the same until it's time to make a Spider FRO2. Besides, with only 100mm of travel, I don't think the need VPP2 is that critical.
    Ole.
    Fearing the Reaper
    Reputation: GLIDE's Avatar
    Quote Originally Posted by rickthewelder
    RTW.
    Sep 2004
    Just because it has less travel shouldn't mean it doesn't need the new gen vpp.
    Intense were late getting the FRO spider into production so I imagine redesigning it now wouldn't appeal but still that's Intenses' fault and like Turner they should update all models no matter what travel they have.
    Head Angle
    It seems that the sweet spot for me on a xc oriented fun bike has the HA around 69degrees. I feel dumb giving this advice since I've never built a bike, just ridden a bunch and know what my favorite bikes have had in common.
    I think having the HA at 69 at 120 would be great then if you ran it at 130 up front you'd get something a tad less than 69. perfect for calming down handling on rocky Pisgah descents.
    One quick question. i did ride a custom bike that had a 70 degree HA that felt just as stable as a 68.5 HA bike I was riding at the time. How is that accomplished? Wheel base and seat tube angles? Thanks, I'm just a tad excited about this one.
    Recovering
    Quote Originally Posted by mezzanine
    No, they shouldn't. From a business perspective, there's a lot more value in doing it the way Intense and Santa Cruz do it- updating the models one by one (or two by two in Intense's case), tackling the projects as you have the resources and time to do it, rather than an all-at-once style.
    Intense is a small company that has to pace its new product roll-outs. They can't afford sweeping product line changes because they can't manufacture and sit on inventory of full lines of 6-8 different frames for an all-at-once new product rollout. That would be murder on the cash flow of a small company like Intense.
    Heck, even Trek didn't roll out all their new ABP bikes at once- it took them a year to cycle through from the Fuels to the Remedies and then the Sessions, and that's a company with resources several orders of magnitude greater than Intense.
    Reputation: zark's Avatar
    Dec 2004
    RTW.
    See, thats what I like about you guys. You could have cheaped out and used Cuervo for that, but you went the extra mile
    Intense-Hutchinson-Nema
    Botox User
    Quote Originally Posted by zark
    Something to remember with the VPP bikes is that you run 20 to 30 % sag and when the rear is set up properly the hA is always slaker than static. The 5.5 and 5.5 FRO HA was @ 70 static but with a 130 fork and the shock @ 25% the HA was at least 68.5 to 69.
    Dude, got any schwag?
    Reputation: TheSchwagman's Avatar
    RTW.
    The Patron is for prepping the WELDER before welding.
    And for post ride recovery.
    Billy
    Speed is sweet, it's like an avenue to
    ... Shredtopia!
    Reputation: falcon1984's Avatar
    when is this bike going to be available? Looking at a tracer now but this bike fits my riding a lot better for where I live.
    Mar 2006
    fork length
    can you run the spider 2 with a 32 140mm Fox fork?
    i think its a must.
    using this with the talas will create a perfect XC-trail machine..
    Ole
    Ole is offline
    If you must have a 140mm fork, then get the Tracer with the matching rear travel. If you want the Spider 2, get a 110-130mm fork.
    Ole.
    Quote Originally Posted by Igal sigal
    i think its a must.
    5.5 fits the bill. Unfortunetly in my eyes they eliminated the perfect inbetween for the spider 2 and tracer. a little outdated platform/design maybe, but the bike still rocks.
    Ole
    Ole is offline
    Spider2: 4.5" and 5" with 110-130mm fork. Tracer: 5.5" and 6" with 140-160mm fork. Don't know how you'd fit the 5.5 in between there without it becoming very intimate.
    Ole.
    German dude
    Reputation: Herbert's Avatar
    I think that bike is on the very top of my wish list.
    Nov 2006
    anybody knows when we can expect a spider 29er II with updated vpp, updated headtube angle and stiffer rear?
    Pre production Spider 2
    First Pre Production Spider 2 , very close to finished except for a few details that will lighten it up a bit.Will post complete build next week.
    Reputation: BillT's Avatar
    Looks very nice!
    looks really good. I like how beefy the seatstays are.
    Very nice,
    Specially the flush bolts on lower VPP link on the Drive side, really shows that you have listened to the feedback re the Tracer VP. Great Work.
    Love it
    Reputation: Christ D's Avatar
    Looks great!!!! Kawasaki green again?
    Fantastic Mr. Intense, have to say I really liked the seat stays on the previous Spider/Spider Fro! Just my opinion, is there a chance this will be available in Black Chrome?
    Looks great!
    What's the weight?
    Want to see it in Black Chrome!
    Feb 2005
    Can't wait to test this, I had a 5.5 sold it and now have a first gen tracer. Maybe this is going to be good enough to take over from the Tracer.
    you just need to do it ligher than old spider (not difficult) and improve the rear tire clearance (anf frame alignement) and I would go for it to replace my spider gen 1...
    Reputation: madelman's Avatar
    Kawasaki green again....yes!...
    Reputation: boogenman's Avatar
    i love that grren!
    On the picture of the pre-production green frame it seems that there's 2 positions for the rear shox on the mono link?
    What is the weight???
    And rear tire limit????
    The travel is adjustable between 4.5 & 5" and it uses the new generation VPP like the Tracer, also has the radial contact bearings with grease zirks.
    Will accept up to 2,35 & weight will be in the 5.5 to 5.75 pound range.
    Basically fits in between the Spider FRO & Tracer vp and replaces the Spider that was dropped.
    just another masterpiece! I really love what Jeff&Intense are doing!
    damn now I dont know which bike is right for me the Tracer or the Spider 2
    any word on the tt length for the large; same 24"? Im considering getting a new van 140 32mm 15mm wit 1 1/8 steerer for my current ride, but it sounds like its too much fork for this frame, and I would need reducers for the tracer when i want to upgrade...?
    Pre Production 2009 Spider 2
    First Pre production 2009 Spider 2 . Sizing will be standard intense sm, med, lrg ,XL.
    Travel 4.5" to 5" adjusable link 100 to 130 fork range, Ha @ 70 w/120 & 69 w/ 130mm fork.
    This one has our standard XT build kit w/ Fox F120 comes in at 26lbs.
    the power
    man, just looking at this bike is healing my shoulder. gonna go see my buddy Todd at reality bikes. should get this bad boy by the time i'm ready to ride again. Any idea on when a works medium could come over to GA? you'll be seeing an order asap....or maybe works red.....
    Looks...green!!
    Reputation: bikesinmud's Avatar
    Dec 2005
    I've got two gripes, Why not stick with the full length housing as was pictured in the first proto pic? Cables last longer, they're easier to replace and the shifting performance is a lot better. The weight savings is what, say 50g? First upgrade to do is to get some screw in Turner zerks and tap them in. Those press in type will eventually pop out with routine maintenace. Mine, as many other Turner owners have experienced this. I so badly want to come back to Intense esp with the new linkage, greasable bearings but these little things will keep me away, that is unless you are willing to do some custom work. If so, you'll have a customer again who will get the spider 2 and tracer vp.
    The Tracer and this new Spider don't have ISCG tabs for a Hammerschmidt. I'm still looking...
    Feb 2005
    I suspect they'll be glad to hear these comments. Think about what you're asking. In 14 years like so many of us hear we speak so often about bikes and what we want.
  67. #67
  68. #68
    Reputation: BlueRidgeRider's Avatar
    Dec 2004
  69. #69
    140 mm fork?
    So it'll be ok to run rev's and Talas! Oh that's freaking awesome. 120 at the trails and 140 in the mountains. Fun!
    So, Black Chrome please! And the burnt orange works on the Uzzi proto!!!! Don't know which one is nicer.
  70. #70
    Dec 2005
    Quote Originally Posted by BlueRidgeRider
    March '09 delivery, just in time for race season!
  71. #71
    ride
    Reputation: ignazjr's Avatar
    Here's the dealer communication re colors
    "Color options will be: Intense Red, Works, Kawasaki Green
    for sure, there will be 2 other options as well(works blue,
    baby blue, orange, stealth black, pearl white and brown are
    the candidates)"
    I would love to see a black chrome Spider2 as well.
    </PRE>
    Redstone Cyclery
    intense*transition*rocky mountain*turner
    web - tweet - FB
    Lyons, CO
  72. #72
    Mr. Intense
    black chrome please
  73. #73
    Dec 2005
    Mr. Intense (or anyone at Intense) what's the ETA for the large frames? Ordered my spider 2 just before x-mas and the waiting is the hardest part.
  74. #74
    pics?
    Are there any more pics intense guys? Need a fix
    Jun 2005
    I would also love to hear an answer to this question. Will the Spider 29er also get these updates, and if so when???
    Quote Originally Posted by hellocook
  76. #76
    Jan 2009
    Rear Shock Size?
    Anyone know the rear shock size? Thanks!
  77. #77
    Still no update on Spider 29 29er 2 ?
  78. #78
    May 2012
    Hello,
    I just picked up a used 2010 spider 2. I'm considering a few upgrades. Came with a Float R rear shock. Could I replace this with an RP23 of the same size of 7.5 x 2? How hard would it be to convert to 2x10 and remove the large ring? Is it fairly simple to do that and add a chain guide? Thanks for feedback.
  79. #79
    Nov 2008
    thats what i like about INTENSE
    you guys never stop thinking, tweaking, dialing the bikes in.
    Completely obsessed
    Just like INTENSE riders
    thank you
