    Reputation: grouan's Avatar
    Shock size for alloy Spider 29er?
    I think I need to replace or service my shock- can anyone tell me what size shock is needed for the frame? I may get a replacement while I send it off to get fixed.
    Thank you in advance.
    May 2013
    Quote Originally Posted by grouan View Post
    I'm also interested, been using the search function and google without any luck.
    Jim
    I fix your broken ****!
    Reputation: Sam-IntenseCustServ's Avatar
    If you are referring to the most recent version of the aluminum Spider 29 then the shock size will be 7.5"x2". First gen aluminum Spider 29's used a 6.5"x1.5" though. If you're not sure which version you have, post a pic and I'll be able to tell. You can also tell by the serial number, stamped under the bottom bracket- the more recent Spider 29 serial will start with "BE" while the original version will start with "J"
    Sam Wilson
    Things & Stuff Specialist
    Beer Drinker
    Intense Cycles, Inc.
    Sam@Intensecycles.com
    May 2013
    Quote Originally Posted by Sam-IntenseCustServ View Post
    Sam,
    Thanks for the info.
    Jim
  1. Replies: 1
    Last Post: 01-18-2014, 09:33 PM
  2. Intense Spider 29 (alloy) vs. Ibis Ripley
    By Danish Dynamite in forum 29er Bikes
    Last Post: 01-02-2014, 12:09 PM
  3. 2011 Anthem 29er rear shock size
    By mo6500 in forum Giant
    Last Post: 05-04-2013, 12:17 PM
  4. Replies: 6
    Last Post: 08-27-2012, 08:04 PM
  5. Replies: 6
    Last Post: 07-13-2011, 11:53 AM
