Results 1 to 3 of 3
    Reputation: gotdirt's Avatar
    shock mount torque values?
    as i'm a new owner to a sweet '03 tracer i'm wondering how tight the bolts to the shock, both at the frame and the link, should be?
    unrelated (but also newbie question): i assume it is okay to have the seat post come down a bit (1.5") below the bottom of the seat tube (above the shock) since it appears there is no way it can make contact w/ the shock in the normal (i.e. non-failure) range of travel?
    thanks in advance.
    .And following our will and wind . . .
    . . .We'll ride the spiral to the end
    and may just go where no one's been.
    www.derbyrims.com
    Reputation: derby's Avatar
    hand tight
    Quote Originally Posted by gotdirt
    thanks in advance.
    I'm guessing about 15 ft.lbs. for those little bolts. I tighten with small wrenches by hand with no more leverage than my hand width distance from center, and not maximum possible effort.
    Yea, just leave over 1/2 inch seat post above the shock body or coil spring in case the post slips on a big compression.
    That reminds me I was thinking of drilling little holes for top height and a couple lowered heights in the back of my seatpost to slide a nail through the little post top-out view hole in the tube. It would help quickly measure height and center the seat and keep it from creeping down slowly over time under my near clyde weight.
    - ray
    Quote Originally Posted by derby
    hmmm, interesting thought. wonder though if that would affect the structural integrity of the post? (somewhere a thomson engineer is smacking his forehead-- "D'OH! warranty void!").
