    Dec 2005
    New question here. RS Vivid R2C coil on Uzzi - which tune?
    This is for my wifes 2011 Uzzi which will go through a gravity oriented make over this winter. One aspect is swapping the DHX air to a coil shock, most likely a Vivid R2C.
    Assuming the Uzzi has a leverage ratio of about 2.5:1 combined with a rising rate rear, which tune would work best? L or M?
    Anyone have actual experience with this shock on the Uzzi?
    Cheers
    Mar 2005
    I don't have experience with the Vivid coil but with the Vivid air. I would go for the low tune especially if your wife is fairly light. My Vivid air is a medium compression tune and it is a bit over damped.
    Dec 2005
    cheers, that's what i thought!
    Low tune, no doubt!
