Could have posted elsewhere but as I ride an Tracer thought I'd query in here 1st....
Can't make up my mind on length of Reverb, was gonna get a 380mm with 125mm drop although the 420mm 125mm drop is £20 cheaper at the German web site I'm most likely to by it from....
I'm on a large currently using a Thompson lay back at 220mm to rails at highest and as low as I can get it (limited by the lay back) when downhilling.
is there a worth while weight saving? or is should I go from the 420mm anyway?
cheers Dave
