Results 1 to 3 of 3
    Nov 2008
    Cool-blue Rhythm replacing shock:Revox Ti on Socom frame?
    Soz for my newby question...there is a special linkage kit or anything else that i must have in order to put a Revox on a Socom frame to replace the stock Fox?
    Curently i have the Revox installed on RAM DHX 2007 frame.
    Thanks alot.
    If the shock is 9.5 x 3.0 it will fit the frame just fine, just get the mounting kit for the Socom, as Manitou use different diameter hardware then say Fox etc.
    Reputation: kntr's Avatar
    Id send the Fox into PUSH instead.
