Results 1 to 5 of 5
    May 2010
    Raw finish retouching
    Hi all,
    while transporting my uzzi raw finish bike on a bike holder, clamp had removed the raw finish on a part of the frame just over the bottom bracket.
    It is a "shiny" polished alluminium patch surrounded by opaque raw finish. Touching with the finger no difference can be feeled.
    Any idea about how to restore raw finish in the area? Some chemical treatment? Any help will be apprecited.
    Thank you
    Enrico
    Reputation: -jes's Avatar
    Fine wire brush will take some of the polish out, perfect for the brushed raw finish.
    For the smoother mottled acid finish not sure, from experience with removing anodizing with chemical etching, something alkaline/caustic (ph 9+) will give a matt finish but you need to be quite careful what you use and how long you leave it on for.
    May 2010
    Thank you jes for the response,
    i will try first with a wire brush to see if the polish one just got "confused" with the raw. Will eventualy try to take some diluted sodium hydroxide diluted solution from the laboratory where i work to try to reat a small spot with a brush to test the effect.
    Reputation: trojans1993's Avatar
    A Scotch Bright pad is all you need - kind of looks like the little pad for doing dishes, but it's grey instead of green. No chemicals or solutions needed.
    May 2010
    Quote Originally Posted by trojans1993 View Post
    Hi trojans1993, thank you for your contribution. Look like a need a scotch brite heavy duty, it's done in several colors will loog for the grey one.
  1. Galvanized Finish?
    By Duncan1104 in forum Cannondale
    Last Post: 06-02-2012, 02:22 PM
  2. Issues w. XX finish?
    By Odnis in forum Brake Time
    Last Post: 01-29-2012, 10:55 PM
  3. When to try and get a top 5 finish?
    By Jwbmtb29er in forum XC Racing and Training
    Last Post: 07-13-2011, 01:13 PM
  4. Raw Finish
    By 2xPneu in forum Turner
    Last Post: 07-01-2011, 09:26 AM
  5. On One Raw finish
    By jscusmcvet in forum All Mountain
    Last Post: 01-09-2011, 11:20 AM
