Page 6 of 6 FirstFirst ... 2 3 4 5 6
Results 126 to 148 of 148
  1. #126
    Jan 2009
    I am 5'8" and have a med. I love it. It feels tall when you first get on but then it just feels right. I have a 28" insm and 120 fork and it is great.
  2. #127
    Reputation: 426h's Avatar
    I am 6'1'' and have a large with a 90mm stem and 700mm bars. I have a straight seatpost right now, but will try a 15mm setback to get a slightly longer reach.
    Size is really good for me, this finetuning is just a matter of preferences.
  3. #128
    Quote Originally Posted by Brendan J View Post
    How is this bike performing with 140mm forks?
    I have been running a 140 talas for a while now. The bike handles tight turns great with the fork. It does wander a little on slow steep climbs. Dropping to 120 seems to help.
    What Issues were you thinking of with the 140?
  4. #129
    29eronline has posted a review on their site:
    Intense Cycles Spider 29 Final Review | 29er Online
  5. #130
    boomer
    Reputation: okie_calvin's Avatar
    Quote Originally Posted by 426h View Post
    Based on my wife's progression since she's got hers I totally agree with their assessment of this bike; it seems really good at everything without necessarily being great at anything.
    Calvin
  6. #131
    I've got barely used medium Spider 29 frame available in the classifieds if anyone is interested. See the ad here: 2011 Intense Spider 29 Medium - Buy and Sell and Review Mountain Bikes and Accessories
  7. #132
    Mine:
    Frame: 2012 Intense Spider 29er works raw, size Large. Shock: 2012 Fox RP23 Kashima Coat (upgrade).
    142x12 dropouts
    Fork: 2012 32 Talas RLC 120-90 15mm QR Kashima Coat
    Headset: Chris King Inset 3 gold
    Stem: Thomson X4 100mm
    Handlebar: ENVE AM 700mm
    Group: 2012 Shimano XT and XTR shifters.
    Hubs: Chris King ISO, front 20mm converted to 15mm, rear 142x12mm.
    Rims: Stan´s Crest 29er
    Spokes and nipples (gold): Sapim
    Tires: Front and rear Maxxis Crosmark 2.1
    Grips: Odi Lock-On Intense
    Seatpost: Easton EC90
    Saddle: Velo Intense
    Rear QR: DT 143X12
    Pedals: Speedplay frog stainless
    Weight complete bike: 12,6 Kg, 27,75 lbs
    Uploaded with ImageShack.us
    Thanks Jadyn of Fanatikbike.com
  8. #133
    Reputation: eurospek's Avatar
    ^ Beauty!
    konahonzo
  9. #134
    Quote Originally Posted by eurospek View Post
    ^ Beauty!
    Thanks,
    Ours bikes are more similar (and beauties), Works large, CK hubs and headset, enve handlebar, Stan´s, Thomson, XT group, and shop!!!
  10. #135
    Feb 2006
    @ Andrew White.
    May I ask how tall you are? I have a large in Works Red that I haven't built yet. I'm trying to decide between that and an Ellsworth Evolve. How do you find the fit? Is the top tube long enough for you? The bike looks nice and the setup looks like I'm envisioning it would when set up for myself. I'm 6'1".
    Thanks! b
  11. #136
    Quote Originally Posted by rbsride365 View Post
    @ Andrew White.
    Thanks! b
    I´m 6´2" and the top tube lenght (24,5") is perfect for me (Evolve has 25" in large size). I use 100mm Thomson stem and I would like to change for another little less longer, like 90mm. The bike rides awesome and with good choice of wheelset you can get a light weight trailbike 29er, and handmade in USA
  12. #137
    Feb 2006
    @ Andrew White.
    Thanks so much for the reply. One more question. Do you find the Talas was a good way to go? I was thinking about it but wondering if I would really use the shorter setting at all. Are you glad you spent the extra money on it? I normally ride a narrower bar than you have set because the trees are tight around here, but otherwise our setups will be very similar. I have a mix of XO, X9 and XT planned. Have you had any trouble with the triple dropping the chain? In a review on 29eronline.com the say something about dropping the chain and jamming it between the rings and the linkage but feeling that it may be rectified with a 2x setup. I'm planning on running the same crank set as you are with shimano chain and cassette, x9 RD and XO shifters. Thanks so much for the input.
  13. #138
    @ Andrew White.
    You welcomed!
    Really I think that the best fox fork for the Spider 29er is a 32 Float 29 120mm Fit. I don´t use the shorter travel on the talas, because it closes too much the head angle, even on hards uphills I rode with 120mm (long travel), but it´s my rode style!
    About the chainring, I think that the best options is double chainring, but I chose triple because Shimano shorter double chainring for 2012 has 26 tooth, (26x38) and the next season will be more shorter thinking about the 29ers; but Sram has two shorther options 36-22 and 38-24, most suitable for 29ers.
    SRAM 22/36 Double Conversion Kit: On Test
    At the last, I think that this 29er needs a minimun 68 centimeters of wide handlebar. Enve AM has 71 and you can cute it!, and I think that´s best choice for the AM and TrailBikes.
  14. #139
    Jan 2009
    I have tha TALAS and like for really step climes. That is the only time I use but I am glad I have it.
  15. #140
    Feb 2006
    Quote Originally Posted by ANDREW WHITE View Post
    You welcomed!
    Thanks for the reply (both of you). I'm not sure I'd ever use it. I've had one before on a 26" bike and never used it because I always thought it felt weird when I was climbing in the lowered setting. I had is mostly so that I could switch it onto a SS frame I was using in the winter which was lower travel. I'll probably just get the non-Talas RLC version. If I was short enough that my bars were inevitably higher than my seat then maybe, but I'm tall enough that my bars will be even or lower than my seat like yours are. That's how I prefer it. I'll take into consideration your thought on the wider bars. I just added 1.5 inches to my bar width this past year as it is now to get them to 63.5cm or so. I'm sure it will feel different on the 29er. Thanks again. I'll post a pic when it's all said and done.
  16. #141
    Mar 2011
    Hi!
    I´ve got another Spider29 here in Spain...but i´m not so proud of it.I´m having a lot of problems with the frame and the Spanish distributor told me tha t Intense doesn´t answer their emails.
    The frame has 2 problems:
    *the lower link hits the frame when i ride....(i´ve try 4 different shocks, many sags, etc...)
    *i must OPEN more than one centimiter the rear triangle to put the rear wheel on...
    I don´t know what to do....CAN ANYONE OF INTENSE STAFF HELP ME??
    MrIntense!I need your help!!!
    Bye!
  17. #142
    boomer
    Quote Originally Posted by YodaMae View Post
    Hi!
    Bye!
    My bike shop said Intense told them that their email system is down; have your dealer make a phone call.
    Calvin
  18. #143
    Mar 2012
    Very nice all
  19. #144
    In Can Am Yellow
    Just wanted to share some bikeporn...
    Build:
    Tower pro 120 fork
    King Headset
    Sun Ringlè Black Flag Pro wheels
    Geax Aka and Gato tires
    Thomson Masterpiece Seatpost with Hope clamp
    FSA OS99 80mm Stem
    Ragley saddle and wiser carbon handlebar (5mm rise 720mm width)
    ESI Chunky grips
    Hayes Stroker trail brakes with magura storm SL rotors
    XTR shifters, rear derailleur (trail) and chain
    XT front derailleur and cassete (11-36)
    Race Face Turbine 26-38 180mm Crankset
    Point1Racing Podium Pedals
  20. #145
    Loving the frame color, with the white fork and carbon bars. Looks like a great build.
    konahonzo
  21. #146
    Quote Originally Posted by mr intense View Post
    Spider 29 has been shipping for months & the top hole is the longer 4.75" travel setting , bottom hole @ 4,25" , Changing travel does not alter geometry but changing fork from 120 to 140 will.
    On my Tracer 2 and Spider 29 Comp the bottom hole is longer travel setting. Could you please confirm that the top hole in the longer travel setting on the Spider 29. I also have Spider 29 ;-) I am just a bit confused that this is different.
    Sorry my bad I got it wrong. Top hole is the longer travel.
  22. #147
    Pirate!!!
    Reputation: Captain Cobb's Avatar
    Quote Originally Posted by Danish Dynamite View Post
    The top hole is the long travel setting on your Tracer2 and Spider29 Comp as well.
  23. #148
    Yes - thanks. I just had a temporary brain meltdown and managed to forget the settings after leaving the basement with all my bikes :-) I am about to sell my Spider 29 so just needed to make sure I gave the correct information to the new buyer :-)
  1. Spider to Spider 2 Convert?
    By Rodeospokes in forum Intense
    Last Post: 09-06-2011, 06:13 PM
  2. Spider, Spider 2 rear tire size
    By jekyllrider in forum Intense
    Last Post: 02-06-2009, 04:55 PM
  3. Who still makes a 94/58 BCD five arm spider crankset? Difference btw 4/5 arm spider?
    By mrbubbles in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-07-2008, 10:04 PM
  4. Difference between Hutch. Spider UST and Hutch Spider UST light tires
    By twelve_volt_man in forum Wheels and Tires
    Last Post: 07-30-2007, 07:22 AM
