Results 1 to 3 of 3
    Dec 2009
    New lower link for old uzzi y.2010 ?
    Will this :
    Intense Cycles Lower Box Link - For Alloy Bikes - Fanatik Bike Co. - Bellingham Wa fit in my old frame (y.2010) .
    I have new swingarm and I could love this frame but troubles with lower link make me crazy!
    I see to 2 problems with this new bearing system in my frame:
    1) how to grease bearings but I could make new grease ports in a frame (2x) and swingarm (2x);
    2) how to remove old bearing. These round plates Intense Cycles Lower Main Pivot Bolt Kit - Cup & Cone For Alloy Bikes - Fanatik Bike Co. - Bellingham Wa cover channels for removal tools
    Is this new bearing system worth it to spend so much money (180$ with shipping costs) ?
    Sorry for my EN
    topick
    topick:
    1) You can grease the bearings by removing the collet bolts (M6) and the locking collets and then back out the axles with an 8mm allen key. Once the axles are removed and the linkage is dropped out and side covers removed you can easily grease the bearings from the inside. I do this every few weeks when the bike gets really muddy or wet to clean up the pivots.
    You could probably get the grease fittings from Intense through Fanatik and add them to your frame by having a machinist drill the holes and threading them for you. It's one port on the frame and one on the swingarm. You can get the fittings here too:
    Zerk Fittings / Grease Fittings
    2) Once you remove the old linkage and bolts you can use a bearing puller tool (BEARING TOOLS FROM REAL WORLD CYCLING) or just hammer the old bearings out with a drift (punch). The new bearings should be inserted with a press tool but I've done it carefully with a vise and hardwood blocks.
    Call or email the guys at Fanatik, they know what parts you need for the 2010 Uzzi.
    Dec 2009
    I see that I dont understand how to install new link and how it work:|
    these plates
    Intense Cycles Lower Main Pivot Bolt Kit - Cup & Cone For Alloy Bikes - Fanatik Bike Co. - Bellingham Wa are installed outside bearings?
    Are sure this link will fit to my Uzzi. Fanatiks are not sure...
  1. Replies: 638
    Last Post: 01-07-2018, 07:22 PM
  2. 3rd generation lower link for 951?
    By Snowdog85 in forum Intense
    Last Post: 01-11-2012, 09:12 AM
  3. Intense Uzzi VP down link bearings
    By murphymax in forum Bike and Frame discussion
    Last Post: 12-30-2011, 09:44 AM
  4. Replies: 1
    Last Post: 07-09-2011, 04:34 AM
  5. Wanted to buy: 00-02 Uzzi SL link
    By Tracer in forum Intense
    Last Post: 01-09-2004, 12:55 PM
